Question about Sony CDX-L350 CD Player
Wiring What does each color wire mean! I don't have my book to it and I don't have a clue what wire is which!
    Brigadier General:
  • 6,966 Answers
To my knowledge a Sony CDXL350 would have the below wiring arrangement:
Yellow - always on B+12 (such as the positive terminal of the battery)
Red - switched B+12 (such as the ACC terminal of the IGN switch)
Black - chassis/GND
Blue - power antenna
Blue/White - trigger for external amplifier
White - Left Front +
White/Black - Left Front -
Gray - Right Front +
Gray/Black - Right Front -
Green - Left Rear +
Green/Black - Left Rear -
Purple - Right Rear +
Purple/Black - Right Rear -
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 18, 2008
2 Suggested Answers
  • 17 Answers
SOURCE: wiring
Here you go:
[POWER]
Red: 12 Volt switched
Yellow: 12 Volt Constant (FULL TIME FOR SETTINGS MEMORY RETENTION)
Black: Common ground
IF YOU HAVE AN ORANGE, it is for DASH BOARD lighting sense to dim the radio similar to the stock radio. (Best if snugly covered and isolated. and not used.)
Blue: System Power on sense for any amplifiers, also known as "P.CONT.", "rem.", or "remote wire"
Blue White: Power antenna up/down
[FRONT SPEAKERS]
White: Left Speaker POSITIVE (+)
White Black: Left Speaker NEGATIVE (-)
Grey: Right Speaker POSITIVE (+)
Grey Black: Right Speaker NEGATIVE(-)
[REAR SPEAKERS]
Violet: Left Rear POSITIVE (+)
Violet Black: Left Rear NEGATIVE (-)
Green: Right Rear POSITIVE (+)
Green Black: Right Rear NEGATIVE (-)
Posted on Oct 07, 2008
The wires are a different color on the new speed sensor conector
i guess you dont know that only the main harness colors are standard (jeep) Jeep does no dictate sensor wires.
if the sensor has pig tail wire they are not standard colors. (only pinout matters)
just like the oxygen senors made by all companies.
the sensors are made by many a company and the colors are not standard. only the pin plug are standard.!!! a fact.
see?
why not just plug it in, like it was day one.
my guess, is you dont know the fact above and are worried only?
or is the connector harness all hacked to H3LL. (not stated)
92 wrangler.
NO ENGINE STATED, so we can really help , see?
a/t or m/t trans, 4wd or 2wd?
answering for rear VSS sensor on YJ (tail shaft speed is what it really is, no matter if 2wd or 4wd its rear sensor.
YJ jeep
it is.
I have the books.
chapter 8w covers all wiring.
ill post the pins. now. for VSS it just plugs in, why are you worried.?
pdf page 69
page YJ-12 actual
free book is here 93, (same)
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
it just plugs in.....
Jun 20, 2015 | 1992 Jeep Wrangler
I need Only color coding for wiring diagram for cdx-gt550
If you are planning to install your radio, I recommend you purchase a wiring harness specific for your vehicle. All aftermarket radios are standardized in wiring colors. The harness will have the diagram to hook your radio to the harness. The problem with hardwiring a radio is the wiring colors don't match, and hooking it up wrong could fry your entire electrical system. You can find a harness at www.crutchfield.com Hope this helps.
Aug 23, 2011 | Car Audio & Video
I have a 1997 Aerostar and would like to wire for trailer lights. I opened the panel on the left side just in front of the tail lights and found a couple wiring receptacles. Are these for trailer...
if they have color coded wires that are brown,green,yellow and black then its possible.but i don`t think so.you can buy a trailer wire adapter that just plugs into the car factory wiring so you don`t have to splice(solder) the wires into the car wiring and it will show you the area for the connection and picture.if you don`t want to go that route then the tail light wires colors are brown.the left signal color is yellow and the right is green and the ground wire on the car is black but on the trailer wire harness it is white.
Apr 12, 2011 | Ford Aerostar Cars & Trucks
Dodge 2007 ram 1500 5.7v8 ....need wiring diagrams for trans and ecm/tcm also connector views with wiring colors and pin numbers and locations vin is:1d7hai8237j552470
autozone or O'relly's carries books Chiltion or Haynes in the back of the book it has electrial diagrams it is NOT in color, However it labels the wires and states each color.
Dec 06, 2010 | 2007 Dodge Ram Truck
Wiring color cod i don.t know witch wire go to the break switch to make the Dvd play
if you mean which wire to put to earth so you can watch dvd's while u drive its the light green one
Aug 11, 2010 | Car Audio & Video
Hello, Im trying to rewiremy transmission on a 92 GMC 3500 vandura box van. My don chewed the wiring that plugs into the transmission The plug has 11 wires coming out of it but some of them that he didnt...
Hello tnvolsfan32,
Use the FREE drawing available on the
BBB Industries site to trace out your wiring...
BBB Industries Premium Alternators Starters Power Steering Products
First put the wires together that
DO PERFECTLY MATCH... Then go
back to the drawing and find out what
DEVICE, CONNECTOR or PLUG got
disconnected or swallowed.
Generally wires DON'T CHANGE COLORS
in a wiring harness run... So you definitely
need to look for a LOGICAL EXPLANATION.
Registration is required... these are real
wiring documents...
Each time you return from a WIRING page
make sure you have not
defaulted back into TSBs...
(technical service bulletins)... While usually
quite useful... they don't begin to address any
WIRE-EATING-DOG problems...
If you get confused comment me back...
I can recommend some great tools to help
SPLICE everything back together
Tone Tracer being PRIMARY
Extech TG20 Wire Tracer and Tone Generator Amazon com
Helpful hint: wire must be ISOLATED to trace correctly
(pulled fuse or chewed through works).
Hope this helps
Carnac the Magnificent
Sep 23, 2017 | GMC Cars & Trucks
Stereo wireing color codes for 2004 suzuki forenza
you are a ******* idiot you+this answer= you are ******* stupid we don't want to know what our best bet is you damn inbred **** we want color codes!!!!! God you are dumb what color means what its like putting the caps back on the right markers in your coloring box with your little books that you cant even color inside the lines cause you are so stupid!!!!!!
Dec 09, 2008 | 2004 Suzuki Forenza
Does anyone have a wiring diagram for an 86 El camino
You can pick up a Haynes manual on it at like Auto Zone and it has wiring diagrams in the back. Shows color codes on wires and where they run. Hope this helps
Oct 03, 2008 | 1986 Chevrolet El Camino
Audio wiring
One way would be to look at a Chilton's or Haynes repair manual. Wiring diagrams should be in the back of the book and you can compare the wiring diagrams to see if they're the same. Pay particular attention to the color of each wire and its placement in the connector.
Jul 16, 2008 | 1993 Subaru Impreza
Sony CDX-L350 CD Player Logo
444 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
