Question about Microsoft Windows XP Professional for PC
Recovery CD-Image Error: Installing windows xp Home SP2
I tried installing windows xp Home SP2 using a set of 4 cds, however,when I get a prompt for installing the fourth CD into the drive, upon doing so, an Error Message appears:"Error reading CD image" and something about installing the right CD for windows xp Home SP2.
I have run that CD on another computer, it turns out that the "4th CD" name is surprisingly named "RecoveryCD3"! Shouldn't it be "RecoveryCD4"?
so...
Who knows what is wrong?
Thanks.
  • thaoyeu Mar 18, 2008
  • edcbe Mar 19, 2008
    Thank you krihard for your helpful suggestion.
    Thaoyeu, I'm having problem accessing the link you've provided.
    Anyway, I thought I'd better run all 4 CDs on my other computer, turns out I was wrong, the first CD is named "System CD", so logicly the remaining ones would start at number 1 and end at number 3... so the problem is not the name, I'm starting to think there's something wrong with the CD it self just as krihard thankfully suggested.
    Any other suggetions?
    Thank you again.
  • 407 Answers
Hope your 4 cd is error....plz ask your near vender or microsoft.com about to your sp 2 .
Posted on Mar 19, 2008
How do i fix error ofoo:0244 and ofoo:1a44 (msg block 16867582, 46028639 & 111595250), please? I get these codes when I start my pc
I would suggest you first try the Start Up Repair for Windows XP.
1. Just insert the Windows XP installation CD that came with your computer then restart the computer.
2. You should get a prompt to start the computer from the CD drive, if not you need to enter BIOS settings to set the start/boot up mode so that your computer will boot up first from the CD.
3. When you see the blue screen, let the computer load everything and when it's done choose "To set up Windows XP now, press ENTER"4. Press F8 to agree to the License Agreement 5. Choose "To repair the selected Windows XP installation, press R"
Windows will then start the repair process. Do not worry all your data and settings will be retained.
If above solution does not work then,Use Recovery Console.
1. Just insert the Windows XP installation CD that came with your computer then restart the computer.2. You should get a prompt to start the computer from the CD drive, if not you need to enter BIOS settings to set the start/boot up mode so that your computer will boot up first from the CD.3. When you see the blue screen, let the computer load everything and when it's done press R to repair Windows XP using Recovery Console4. On the Recovery Console, choose the installation you would like to log on to (for example c:\Windows)5. Type Chkdsk /p /r on the Recovery Console and your computer will begin to check the hard drive for error and recover data.6. Once Chkdsk is completed, type exit then press Enter. Computer should restart. No need to boot from CD at this point. You can take out the Windows installation CD.
Hope this helps. Glad to be of service.
Nov 23, 2011 | Microsoft Windows XP Home Edition
Tip
How to solve NTLDR is missing issue in windows XP
Using Windows recovery console.
The Windows 2000 and Windows XP CDs supplied by Microsoft has a tool called the Recovery Console which can be used to repair errors that prevent Windows XP from starting using the command line. OEM versions of Windows XP, including computers that were supplied with Windows XP preinstalled, may not have this utility.
This problem may occur if the basic input/output system (BIOS) on your computer is outdated, or if one or more of the following Windows boot files are missing or damaged:
Ntldr
Ntdetect.com
Boot.ini
Check your drives for floppy,USB storage devices,CDs and any other bootable media.Because sometmes these things makes problems.Then go to BIOS and do the BIOS settings to boot from the source where the OS is installed.
1: Insert the Windows XP bootable CD into the computer.
2: When prompted to press any key to boot from the CD, press any key.
3: Once in the Windows XP setup menu press the "R" key to repair Windows.
4: Log into your Windows installation by pressing the "1" key(most of the cases it will be "1" only) and pressing enter.
5: You will then be prompted for your administrator password, enter that password.
6: From the command prompt, copy NTLDR and NTDETECT.COM from the i386 folder of the CD to the root folder of the hard drive. In the example commands given below, C: is the hard drive and D: is the CD-ROM drive. You will need to change the drive letters if appropriate:
COPY D:I386NTLDR C:
COPY D:I386NTDETECT.COM C:
Once both of these files have been successfully copied, remove the CD from the computer and reboot.
on Mar 03, 2010 | Microsoft Windows XP Professional
I has delete file on memory's intermec cn3, How to recovery file ?
REPAIR YOUR OPERATING SYSTEM AS FOLLOWS
Download the operating system from this link: http://www.microsoft.com/downloads/en/details.aspx?FamilyID=2fcde6ce-b5fb-4488-8c50-fe22559d164e&displaylang=en
or
if you have it, install it using the procedure below:Boot From the Windows XP CD
  • You must boot from your XP . Please make sure it is the same version of Windows that is currently installed on your computer (ex. XP Home cannot repair XP Professional). Place the CD in your CDROM and start your computer. Newer versions will work as well (ie. Windows XP Pro SP2 CD will work on an older WinXP Pro SP1 installation)
    you will be asked to press any key to boot from CD, so do just that.
    Step 3: System repair steps
  • A blue screen will appear and will begin loading XP setup from the CD.
    simply let the CD load without pressing F6.
    Once completed, you will be confronted with "Windows Setup". You will be asked to setup up Windows, or repair Windows with the recovery console. Choose the FIRST option, NOT recovery console.
Choose F8 to continue.
  • Next, Windows Setup will find existing Windows XP installations. You will be asked to repair an existing XP installation or install a fresh copy of Windows XP.
    If no installations are found, then you will not be given the option to repair. This may happen if the data or partition on your drive is too corrupted.
That should be it. Windows XP will appear to be installing itself for the first time, but it will retain all of your data and settings. Just follow the prompts
  • If this solution helped Never go to drive C: again. Vote for this solution and rate it
Apr 20, 2011 | Computers & Internet
My ksuser dll for windows xp profesional
Just boot from the xp professional cd and run the recovery console.
or
Apr 19, 2011 | Microsoft Windows XP Professional
Xp recovery
You need to download all the drivers installer files from manufacturer website first, and also all the software you want to install automatically with Windows. Then you build a Windows Xp boot CD with all the software setup embedded.
See the links below:
Build an XP-SP2 Recovery Disc - Solutions by PC Magazine
Geek Repair: Create Your Own Ultimate Recovery CD :
Bart's way to create bootable CD-Roms
Slipstream a Windows XP SP2 Recovery CD
Build your own XP SP3 Recovery Disk -
Build an XP SP3 Recovery Disc
Apr 18, 2009 | Microsoft Computers & Internet
Windows XP SP2 Repair
Solution: Rename the C:\WINDOWS\SYSTEM32\CATROOT2 folder to something such as catold to prevent WinXP's Setup program from locating the folder and halting the installation. If you are still in Setup, press SHIFT-F10 to launch a command prompt from within Setup. At the command prompt, type cd\win dows\System32 to open the System32 folder and then type rename CATROOT2 catold, press ENTER, restart the computer, and attempt the upgrade again.
If you cannot reach a command prompt from Setup, reboot the computer from a Win95, Win98, or WinMe startup disk and rename the folder from the command prompt. You can also launch a command prompt by booting from the WinXP installation CD and running the Recovery Console.
Mar 25, 2009 | Toshiba Satellite 5105-S501 Notebook
HELP ME
hi there my friend,
we have the hard way and then we have the easy way...
the hard way is to bootup with your bootable xp cd .follow the installation guide ..then.put in your key when you get the chance to ..and finish the installation. then apply service pack 2 to your installation .. and you're done...
the easy way would be to make a Slipstream Windows XP Service Pack 2 CD....which you can use each time you need to fix your system.
1 - Download the (full) "Network Install" of the Service Pack (English version [266 MB]), and save it to a directory (folder) on your hard drive (in my case D:\XP-SP2). Other languages can be downloaded from the Microsoft Download Web site.
Note: do not use spaces in the folder name!
2 - copy your Windows XP CD to your hard drive. Just create a folder (I used \XP-CD), and copy all the contents of your Windows XP CD in that folder.
3 - , open a Command Prompt (Start > Run > cmd), and go to the folder where you downloaded SP2 (cd \foldername). Type the command: servicepack filename /integrate:drive/path. In my example the command is WindowsXP-KB835935-SP2-ENU /integrate:D:\XP-CD.
Extract SP2 files
If you get the error:
This service pack can't be integrated error
This is caused by the fact that your Windows XP CD contains updates that will be automatically installed when you run setup. This type of CD's will usually be from larger OEM suppliers (like Dell, HP, or others).
You cannot use this type of CD to create a slipstreamed SP2 install.
First, the files will be extracted, and next they will be integrated in your Windows XP files:
Updating Windows Share
When ready, you should get a confirmation. Windows XP Service Pack 2 has now been Slipstreamed into your original Windows XP files.
Slipstream Completed
Creating a Bootable CD
For this part I used IsoBuster and Nero Burning ROM 6
After you install IsoBuster, you can choose to use only the product's free functionality for what we want to do, IsoBuster will look like the image below (you need to have your original Windows XP CD in the CD-ROM drive).
Start to extract the boot loader from the original Windows XP CD. Using IsoBuster, select the "folder" Bootable CD, and right-click Microsoft Corporation.img. From the menu choose Extract Microsoft Corporation.img, and extract it to the folder on your hard drive where you have your Windows XP files (D:\XP-CD in my case).
Extract Boot Image
Next, start Nero Burning ROM, and choose CD-ROM (Boot) in the New Compilation window. On the Boot tab, select Image file under Source of boot image data, and browse to the location of the Microsoft Corporation.img file. Also enable Expert Settings, choosing No Emulation, and changing the Number of loaded sectors to 4 (otherwise it won't boot!)
Nero Boot Settings
The ISO tab should be configured correctly as shown below:
Nero ISO Settings
If you have an older version of Nero you won't have the option Do Not Add ";1" ISO file version extention under Relax ISO Restrictions. You won't be able to boot your new CD, so update Nero!
You can configure the Label tab to your liking, I would however recommend that you keep the Volume Label the same as on your original Windows XP CD. Here are some (English) Labels:
* Windows XP Professional: WXPCCP_EN
* Windows XP Home: WXHCCP_EN
* Windows XP Professional OEM: WXPOEM_EN
* Windows XP Home OEM: WXHOEM_EN
Nero Label Settings
Next press New, and from the File Browser window, select the files and folders from your slipstreamed location (in my case D:\XP-CD). Now drag & drop the selected files in the ISO1 window.
Copy Files
Next, burn your new CD.
Burn
You now have a Bootable, Slipstreamed Windows XP Service Pack 2 CD!
Apr 28, 2008 | Computers & Internet
Error report
  1. You've probably got in your hands some recovery/restore CD's from your PC vendor. BEWARE. For example, Fujitsu laptop CD's are only used to restore the HDD to its original factory state! Fuji will not give you a XP CD to 'recover' the hard disk, only to 'restore' it. Nice huh?
  2. Use a Windows XP retail CD ,better than having to use the OEM's restore CD and lose all your data.
    • IMPORTANT: if you've got Windows XP SP2 installed, you CANNOT use a Windows XP SP1 CD. The recovery console from the SP1 CD will not accept even the correct admin password when run on a Windows XP SP2 HDD. You must run the recovery console from a modern SP2 CD, then you'll be able to correctly login to your Windows XP install on the HDD.
  3. Pop in the Windows XP CD, reboot, making sure to select boot from the CD option. On some PC's you'll have to hit DEL on reboot to enter the BIOS and select boot from CD ROM. Other PCs you hit F12 while booting up.
  4. WIndows XP will start to load. Eventually you will be prompted to select between Setup Windows and Repair Windows. Hit 'R' for Repair Windows. The RC (Recovery Console) will look for existing Windows XP installs to repair. Usually you have just the one, listed by the RC after it has scanned your disk, so type '1'. If the RC doesn't find any Windows Installs...you're in trouble. Note: Windows RC can find a Windows install when Windows Setup can NOT find one, so the RC seems more low level and reliable.
  5. Usually your admin password is blank, so just hit a return when prompted for a password.
  6. Type 'help' for the commands that the RC can run. You won't be able to access any folder other than C:\Windows and C:\ top level. The next two steps are probably only safe if you have a single partition on the whole disk.
  7. Try 'fixboot'. This re-writes the boot record.
  8. Try 'fixmbr'; again, this may damage a partition table that it doesn't understand, so be wary of taking this step... you may want to use this as a last resort and only if you have a single partition on the disk.
  9. Run CHKDSK /P C:
  10. If you get errors still, rerun or also do a CHKDSK /R C:.
  11. If the CHKDSK finally succeeds without errors, then you should be able to exit from the RC and reboot OK.
Feb 11, 2008 | Computers & Internet
Microsoft Windows XP Professional for PC Logo
126 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
