Question about Acer Aspire 3100-1405 Notebook
Help with notebook!!
My dvd drive is loose because some of the screws have snapped, i was wondering how to remove the casing to access the dvd/cd drive to put new screws it, otherwise i do not have use of the drive. My Notebook is a Acer Aspire 3100
  • 4 more comments
  • Shay Pierce Mar 18, 2008
    Oh yeah i guess i should include the dvd drive works fine, my computer isn't recognizing it tho, it cant find it because the drive it loose and it keeps pulling the plugs out just enough to not work. yet it still has a power source because it still spins/loads discs and it can eject and everything even the light still comes on... rather irritating because i cant create backup discs or anything. i would take it back to acer but its 3 months past its warranty and i cant afford to pay the extra to get it shipped fixed and shipped back.
    Hmmm bit iffy bout doing that because i attempted it earlier and it wasnt coming away all that easily. but i will attempt it again, just hope that it doesnt crack at all, im not rough with anything but yeah just anxious lol.
    yeah tried taking the case off but above the right speaker wont budge so im not going to attempt that again. just cos i dont want it ruined or have to replace the casing.
    yeah, im not planning on taking it apart anymore, ill just have to put up with my dvd drive being disconnected cos i certainly dont have the money to get it fixed. thanks anyway :)
  • Shay Pierce Mar 20, 2008
    hey all, i didnt take it to a professional, i got a screwdriver set a pair of rubber surgical gloves and sat down on my non conducting mat.i removed the casing, i removed the disc drive i replaced the screws (i just happened to have the right ones here) and i gave it a dusting... TA DA!!! it works the computer is detecting it and it can run discs. thanks for all your help :)
  • Anonymous Jan 23, 2009
    i have the same problem..I just bought a dell for a lot cheaper..stupid acer
    Problem Solver:
So it got fixed the way I suggested, Way to Go!
Glad you saved the money, I was wondering if you would reconsider the rating that you gave my solution?
Thank you and have a good day
Posted on Mar 26, 2008
  • wowoas Mar 26, 2008
    good job bro
  • 871 Answers
I would suggest that you dont touch your laptop anymore, you might damage something there that will lead you to yet another problem. bring it to a computer shop and have them replace the casing for you, if they damage it, well, youll get the replacement for free.
Posted on Mar 18, 2008
  • 3,037 Answers
You should just be able to remove all of the screws from the bottom of the laptop and then the casing around the keyboard, the keyboard and any extra casing on the bottom will come off and you should be able to get to the drive and put some new screws in, make sure they are exactly the same though. Any screws you try to take out will most likely have locktight on them and so it will take a little force to get them out
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri Mar 18, 2008
    there may be a seal that I a missing but I have taken my laptops apart and as long as you pry little by little and keep the covers from bending to the point of cracking, everything will come apart fine
  • Benjamin Patri
    the speaker must have some kind of adhesive holding it in, I'm sure that it should come apart, maybe take it to radio shack or another place where they can remove the parts you are having trouble with or ask for visual advice on the specific parts, I hope this helps, but laptops can be a pain to take apart sometimes
  • Benjamin Patri
    Benjamin Patri Mar 26, 2008
    so it got fixed the way I suggested, Way to Go!
Lose Hinge
You might have to remove the Palmrest and keyboard to tighten the screws on the hinges. Have some cups with labels on them so you will know where the screws came from. Turn the laptop over and remove the screws on the bottom. Remove the battery and remove any screws inside the battery case or compartment. Notice some screws might have the icon of a keyboard besides them, if so they hold the keyboard in place. Remove the covers for the hard drive, memory and any other devices then remove them and look for screws inside the case where they came from. Remove the dvd drive and look for screws in the dvd drive compartment that hold the palmrest to the frame.
Turn the laptop back over and remove the strip that is above the keyboard very carefully because there might be a cable under it. You will just have to pry it loose because it snaps in place. The lcd hinges might be exposed enough so that you can tighten them without removing the keyboard and palmrest.
Next remove the keyboard. The strip that was above the keyboard might have screws under it that hold the keyboard in place so remove the screws. Sometimes the keyboard has little catches that hold it on the sides, so just work with one side first by bending it a little to get past the catches. Once you get one side loose you can carefully lift the keyboard because there is a cable that is under it that attaches to the board that you want to remove from the board. Now the LCD Hinges might be exposed so you can tighten them.
May 23, 2012 | Toshiba Satellite A25-S207 Notebook
Tsunami 710-lk/premium computer case how to remove front dvd/cd & floppy drive bay case panels
To remove the DVD/CD in your computer case. First turn off your computer. Remove the power cord, open the left side of your computer case. Then remove the connectors of your DVD/CR ROM then unscrew all the screws that screwed in your DVD/CD ROM. After you loosen your DVD/CR ROM push it out and pull it out in your casing. Hope this procedures will help you.
Jul 17, 2011 | Computers & Internet
I have an Acer laptop, but my dvd rom drive does not appear in the My Computer folder and in that case I cannot use it to open Cd or Dvd. I need help to solve this problem. Thanks.
It's actually a manufacturing problem. The dvd metal case atually touches the the interior metal case of the laptop causing a shortcircuit. Solution: Remove The DVD drive from its place by removing the screw of the drive from the back of laptop and then pull the drive gently out from the laptop case. At the end of DVD case you can see the metalic extension, with a little hole. Cover that entire area with something, i used a sticker, but let that hole free, so you can put the screw back in once you put the DVD drive back in to the laptop case. That's it. If your DVD drive has no other defects, it should work
Oct 27, 2010 | Acer Aspire 5520-5908 Notebook
How to remove the CD rom drive in a HP Pavalon slimline client?
See the panel on the side of the DVD Drive? remove that by lifting it backwards, it has a black button on top of it, remove it and now you have access to the screws on the side of the DVD drive, after unscrewing there's a button on the opposite side, push it sideways to unlock the drive and push the DVD drive out of the casing. Hope you figure it out.
Nov 25, 2009 | HP S3120N Pavilion Slimline Desktop...
Acer 5100 laptop dvd/cd player is broken,how do I remove it?
Remove the access cover on the bottom of the case that houses the heatsink, wireless card and RAM memory. No components have to be removed to remove the cd drive. Now look at the cd bezel and then back toward where the RAM memory is installed in thier slots. There is a screw marked by a circle with what looks like a wedge taken out. This is the holding screw for the cd player. Once you remove this screw, there is agap next to the screw hole that you can stick the screwdriver in and push the cd player part way out of the case. Once you do that, grip the front of the drive and pull it free of the case. Refer to page 60 of the service manual I have included the link for below. Make sure you have a PDF file reader like Adobe or Fox-It Reader.
http://tim.id.au/laptops/acer/aspire%205110%205100%203100.pdf
Oct 28, 2009 | Acer Aspire 5100 Notebook
Cd/dvd combo drive problem
Pry up the long, thin plastic panel above the function keys. Remove the 2 screws that secure the keyboard (up top, under where the panel was). The cd has a couple of screws that I have seen work their way loose in the past. If you remove the screws and slide your cd out, you will see a black connector. Make sure the screws that secure the connector are tight too. Then reassemble. If your cd is seated properly, you should see it listed as a storage device on "my computer" from your start menu.
Oct 28, 2009 | Toshiba Satellite Pro 4600 Notebook
How do i remove the DVD cdrom from an acer 503
On te back side of your laptop you will see a sign on a screw like cd , unscrew this screw and pull the cddrive.
Sep 01, 2009 | Acer TravelMate 2300 Notebook
Replace DVD/CD drive on Satellite A105 notebook.
Ther is probably a single swcrew that releases the entire DVD/CD drive and it pulls out. Check your owner's manual or go to Toshiba's website and download the repair/trouble shoooting/owner's manuals and they will tell you exctly what to do.
DELLS usually have a screw insode of the memory access plate or under the battery after it is removed, but I odmn't know where they are on Toshibas.
Don Jones
Jan 28, 2009 | Toshiba Satellite A105 Notebook
How do i remove the dvdrom drive in my hp pavilion slimeline pc.
The DVD drive has to come out the front of the tower. To remove the front panel there are 4 snap tabs that allow you to pull the front panel off. There is a sequence to this. First you have to remove the media bay by pushing the black tab on it and sliding the bay free. Next comes the HD, raise the snap bar and removing the one screw securing it right beside the snap clip. Unplug the connector labeled P3 and the HD will slide straight out. Now you can access the snap tabs for the front panel. Once the panel is off there is one black screw just above the HD bay that needs to be removed. Disconnect the 2 cables from the DVD drive. On the opposite side of the DVD drive theres a tab that you need to push outward and the DVD will slide out the front.
Nov 13, 2008 | HP Pavilion s3020n (882780985063) PC...
Replacing CD-RW/DVD Drive
I own a Presario F730US. I have had it apart many times and it is a difficult case to open. There are several ribbon cables that are easily damaged if you are not very careful. You have to pop up the speaker cover panel as there are case screws under it as well. Once inside you will see the screws that retain the optical drive. Once you remove them it will slide right out and the new one will slide right in. I can not overstate how careful you have to be. If you are not 100% sure of yourself I would recomend that you take it to a repair shop and let a qualified tech assist you. The screws you need to get to are under the keyboard. The whole laptop does not need to be disassembled to swap the drive. Once you pop the speaker bazel and the keyboard you are home free. If you need more help feel free to ask.
George
Aug 03, 2008 | Compaq Presario 700 470024-192 Notebook
Acer Aspire 3100-1405 Notebook Logo
24 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
