Question about Canon PIXMA MP530 All-In-One InkJet Printer
Printing when I print or batch scan I get thin black line 2 1/2 inches in on the right side of paper, does not happen in scanning bed...vgriff
  • Vernon Griffin Mar 18, 2008
    cannon mp530. if I scan from the bed and print I get no line, batch scan from the top or copy from the top I get a line. vgriff
    Brigadier General:
  • 6,966 Answers
Hi vgriff,
If I may add to the posts of pincer, Ekse and smilemaker.....
There are two (2) possible sides where the line will appear, on the printing side and on the back of the printed page.
If the line is on the printed side, then it is likely one of the rollers is smudged with ink. You can determine the most likely by aligning the printed paper (with line) to which roller the line coincides with. The solution of course would be to clean manually (though a bit messy).
However, this also indicates that the roller got the ink from somewhere and the most likely place would be the from the bottom plate which in turn got it from drippings from the print head. Having said that then chances are, you would also have smears, lines ink smudges on the other side of the paper.
If you would be kind enough to look over the the Maintenance Sections (in the PIXMA MP530 Properties), there would be an option to perform a "Bottom Plate Cleaning" option. This should be done a couple of times and insert paper when and where directed by the on screen instructions. Thereafter it may also be necessary to manually clean the bottom plate.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 18, 2008
  • 790 Answers
Hello!!
Switch off the printer and disconect the USB cable for 30 seconds. deep clean on the black head to get it work properly.
  • Canon Master
  • 13,433 Answers
Possibly ink cartridge problem, try cleaning the cartridges.
    Master:
  • 377 Answers
No black line while you scan, but it only appears while you are printing?
  • pincer
    pincer Mar 18, 2008
    Can i get the model of your printer.
  • pincer
    pincer Mar 18, 2008
    Printers work by creating latent images on a rotating, light-sensitive drum and then attracting toner to exposed points on that drum. If any point on the drum’s light-sensitive surface is damaged, you may notice that toner is always attracted to that point, thereby transferring to the final page and appearing as a repeating mark. Because the drum is a cylinder, such marks will appear at equal distances down the page, corresponding to each rotation of the drum (maybe every two inches, for example).
    An EP (electrophotographic) “engine” that can be replaced in just a few easy steps. Check your printer’s documentation and replace the appropriate assembly (or have someone do it for you), and the repeating marks should go away.
    Best regards,
    pincer
My Brother MFC-7420 Printer always prints black lines and splotches down the left side of my paper. This happens whether I'm scanning or printing from my PC. When I looked at my drum, it appears a
If you are seeing vertical streaks/black lines your primary corona wire is dirty and or the fax scanner may be dirty.
1)To clean the corona wire you take the drum unit and toner cartridge and place it on disposable paper to avoid spilling.
2) Clean the primary corona wire inside the drum unit by sliding the blue tab from right to left several times.
3) Return the blue tab and snap it into the home position.
4) Reinstall the drum unit and toner cartridge.
5) Close the front cover.
Caution: if you do not return the blue tab to the home position it may repeat the black lines.
Nov 29, 2012 | Brother MFC 7420 All-In-One Laser Printer
I always have a black line down the middle of the page when i scan. help
If there's a black line when scanning but not when printing, you need to clean the scan bed. Either the glass has something on it or check the paper path if you're using the ADF. A single ink spot either place will print a line down the whole length of your scan.
May 12, 2011 | HP Officejet 6500 Wireless All-in-One...
My Ricoh Aficio CL2000N is printing several faint lines
Couple possibilities:
Fuser hot belt has wear lines transfering to the page
Black pcu needs to be replaced
Transfer unit is not being cleaned properly and needs to be replaced.
Remove each of these assy and inspect them for wear or lines that corespond to the lines on your prints.
Mar 25, 2010 | Ricoh Aficio CL2000N Laser Printer
Black line is present when copying document; not
This sounds as if you have some ink/contamination on the small scaning glass that sits to either the left or right of the main glass on the copier.(Depending on the model/make)As your original is scanned over this thin piece of glass the scanning device will see any spots and this will result in a black line down the page.Please clean the glass with a soft rag.
Oct 12, 2009 | Office Equipment & Supplies
2" black horizontal line appears on paper when I fax, print,
Check the wondow where the paper passes to be scanned. You will probably find some debris or white out stuck on the glass. That is usually the cause of vertical lines on sent faxes.
Sep 17, 2009 | Office Equipment & Supplies
Samsung CLX-3160FN All in One Printer
open the scanning unit. in scanning unit clean the mirrors.
Sep 16, 2008 | Samsung CLX 3160fn All-In-One Printer
Thin black lines (mp 530)
Here's the link for how to clean the unit... I was going to post the instructions here, but there are pictures that might be helpful to you.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13371
Before doing anything more drastic, I would try this.. let us know how it turns out.. if it doesn't work, we'll go from there.
Maggie B
Feb 23, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Dell 1600n and vertucal line while scanning
Any difference between using the document feeder and just the flat bed?
Nov 05, 2007 | Dell 1600n All-In-One Laser Printer
Black line down right side of paper
On the ADF check the twink mark on glass scanning mirror
Oct 15, 2007 | HP LaserJet 3055 All-In-One Printer
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
205 people viewed this question
old marine
old marine
