Question about Apple iPhone Smartphone
Installer shuts down when I try to open
Installer on my iphone shuts down when I try to open it. It hangs for a few minutes and then just closes.
  • Anonymous Jul 10, 2008
    same here :-( please if anyone knows how to fix this, share with us
I hav the same prob
Posted on Jun 03, 2008
I have the same problem, installer just quits back to the summerboard, i've tried turning itouch off restarting it and sometimes it works or just trying a couple times in a row, but now after several tries it won't open. Not that installer is doing much for me these days. Most applications that i try to install, usually games, will start to install but instead of sliding back to the package window, installer quits to the summerboard and i see that i have the application on my file manager but they are no where to be found on my itouch. if anyone has any suggestions of how to fix these problems please email me at sean_leno@hotmail.com
Posted on May 03, 2008
Compressor shuts off after a few minutes and only fan stays on. now only fan comes on and even that shuts off. I tried power surging. My plumber, installer (2 year old unit) is stumped.
From the sound of it your refrigerant charge sounds like its off. (shutting down on either high pressure; dirty condenser or low pressure; refrigerant leak.)
Jul 27, 2011 | Mitsubishi MSY-A24NA Air Conditioner
Got a virus through text in my iphone
Could you please tell me which firmware version you are running?
Feb 14, 2008 | Apple iPhone Smartphone
Hi my Iphone 3gs won't slide to open and can't slide it to shut it off either..I can still see i'm getting twitter texts but can't slide to open and do anything with phone since last night..can you help?
Press and hold Power and home button for few seconds, it will turn off the device, keep the device off for few minutes then press the power button only to make the phone on again, and it should work again properly, This may happens when you try to install apps specially themes which hangs the springboard
If you require more assistance, feel free to reply to this post
Regards-BA
Jan 28, 2011 | Apple iPhone 3GS Black (16 GB)
My iphone is hanged and i can't switch off the phone , i tryed all the solution . what should i do?
Hold both the Power button and the Home button for a few minutes. You may need to repeat this a few times. My iPod Touch Hangs all the time
Jan 25, 2011 | Apple iPhone Smartphone
My i phone is locked
Before we get started, you'll want to disable the iTunes helper application that may get in the way of the installation. Make sure iTunes is not running, then open OS X's Activity Monitor in the Utilities folder of the Applications folder. Search for or scroll down to iTunes Helper, select it, and then click on the Quit Process button in the top left of the screen. You'll also need your iPhone, your data cable, and a Wi-Fi connection to the Internet.
Apple doesn't support the installation of third-party applications on the iPhone, but enterprising developers have created a program called AppTapp that will let you install including chat clients, games, and other pieces of software - including those that are needed to unlock your iPhone
Download and install AppTapp. Once you run the program, the first thing it will do is ask what version of the firmware you're running. If you've just updated your iPhone, you probably have Firmware 1.0.2-select that and click on Continue.
Assuming all goes well, you should get a screen that begins with the words: "Congratulations! You have successfully installed AppTapp Installer onto your iPhone." You should then find a new application on the iPhone's home screen called Installer.
The next instructions will require downloading some applications from the Internet to your iPhone-so make sure your iPhone is connected to a WiFi network. Launch the Installer program, and you'll see a long list of various applications that you can install. Scroll down, then select and install-in order-Community Sources, BSD Subsystem and OpenSSH.
NOW PERFORM THE GSM UNLOCK
First, download and install Unlock.app, lockdownd, and Cyberduck.
Then go to the iPhone's General settings and set Auto-Lock to Never. Next, you'll need to get your iPhone's IP address on your local network. To do this, go to Settings: Wi-Fi and click on the blue arrow next to the network that you're connected too. Write down the IP address, as you'll need it for later.
Now, open Cyberduck and click on the Open Connection button in the top left of the window. In the connection window, type the IP address that you just noted. Make sure that SFTP (SSH Secure File Transfer) is selected, and that you are using Port 22. For the username, type root, with the password of dottie.
Once connected, navigate from /private/var/root to the main directory by choosing the / item. Next, navigate to /usr/libexec and drag the file named lockdownd (the one you downloaded earlier) into it. It will ask if you want to overwrite the existing file-click on Continue to do so.
Now, in Cyberduck, drag the Unlock file from the Mac's desktop into the /Applications folder at the top of the main window. Once that's done, turn off your iPhone and remove the SIM card, then turn your iPhone back on and choose the application on your iPhone called Unlock
Afterwards,there should be a white screen that says "All files found. Ready to go. Press Start." Once you press start, it will take about 20 minutes for all the files to install.
The progress messages will appear at the top of the screen as it progress-once you see "Completed" then you're finished. Insert a new SIM card of your choosing into your iPhone. Congratulations, you've just unlocked your iPhone!
Jun 22, 2010 | Apple iPhone 3G Black Smartphone
My apple iphone was working fine bt now its on a hang up mode and cannot be even switched off.. how do i resart my phone..??
Try holding the power switch at the top of your iPhone, and while holding this down, hold down the "Home" button on the iPhone (round button on the bottom of the iPhone). Be patient, it may take a few seconds to shut down.
Oct 08, 2009 | Apple iPhone Smartphone
I CAN'T CALL OR HANG UP FROM MY IPHONE BUT OTHER KEY PAD WORKS.WHAT DO I DO?
am assuming you JB your phone recently?
If yes, then the dialer freezing issue is caused by few apps from Installer. I faced the same issue and I ended up restoring and re-JB without selecting Installer. If you would like to keep Installer, the Apps that you need to remove are:
- Kate
- Mobile Enhancer
- RIP DEV Preferences
Just go to Installer and remove those and restart your iPhone, the freezing and crashing should stop.
As of upgrading to 2.2.1 for JB purposes, it's 100% jailbreak-able and it works well. But I am not 100% sure regarding yell0wsnow. (I don't unlock, I only JB - sorry)
Hafeez -Pakistan
Mar 11, 2009 | Apple iPhone 3G Black Smartphone
2.2 Jailbroken iPhone 3G dailer crashes! Help!
If after the jailbreak you can't make dial calls because the phone dialer freezes and goes back to the main menu, try this:
1- Uninstall Kate from Installer: this is what everyone recommends, seems to work for a lot of people but didn't work for me.
2- Then go to Installer again and uninstall these apps:
A) Mobile enhancer
B) RIP DEV preferences
3- Reboot your iPhone.
That's what I did and got my dial pad back again.
Dec 27, 2008 | Apple iPhone 3G
Jail broken iPhone can't make calls
i had something similar where my iphone just freezes and goes back to home 3 seconds after i go to the phone part of the iphone. I just went to settings>RiP Dev (something I downloaded after jailbreaking)>RiP Dev Products > Kate and there Look for a checked application called facelift. I unchecked it and my calling worked again. It was cause Facelift is not compadable with Winter Board (another app dled from installer) If this doesnt solve the problem then... sorry :x
May 04, 2008 | Apple iPhone Smartphone
Iphone got hang while installing iblacklist software from installer
Had the same problem. Used ibrick to reboot. You loose nothing of the info and software you already installed on your iphone.
Apr 25, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
115 people viewed this question
Top Apple Cell Phones Experts
David
Marvin
Marvin
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
