I'm trying to installing my software ( resume maker edition career) the system is let me know this software is not compatible for window vista. can you help me let me know what kind of program I need to download.
    New Friend:
    Problem Solver:
  • 5 Answers
Hello
Microsoft had change backward compatability when it come to produce vista for end user, so most of the softwares developed for the earlier softwares did not run on windows vista, although i don't know which type of vista you are using, but vista home basic support some of the obselete softwares. Why not try to use vista home basic and see wheather you will succeed. Or I will say you download the softwares from the developers site which is compatible for vista OS.
Enjoy.
Yarima
Posted on Mar 18, 2008
SOURCE:
Having problems uninstalling career edition resume maker
1. Open Control Panel.
2. Open Programs and Features. the program should be listed along with other programs
3. you can uninstall the program from here.
Jun 11, 2014 | Individual ResumeMaker Career Edition for...
When I try to install Movie Edit Pro 14 Plus, I get a message telling to use a good version of Windows and no more. My version of Windows is Windows7-64 bits. What is the solution to this Bill Gates...
this version was released with only 200/xp/vista support. you may just have to run both the installer and the software in compatibility mode. you can do this by right clicking the setup and on the top tab select compatibility mode then select windows xp sp3. there later version of this software (movie maker 17) does support the windows 7 platform
GL
Jammer
May 06, 2011 | Magix Movie Edit Pro 14 for PC
I have Microsoft Picture It 7.0, Is this software compatable with Windows Vista. Installed it but can't get it to work. Thanks
No, this software is not compatible with Windows Vista and will never work correctly. Microsoft will never release an updated driver to make it compatible. I went through this very thing myself when I bought Windows Vista 3 years ago. I spent many hours trying to make it work and even contacted Microsoft on this issue. I finally gave up and purchased Microsoft Digital Image Suite Anniversary Edition which works perfectly. I suggest you do the same as you are fighting a loosing battle.
Apr 27, 2011 | Microsoft Windows Vista Home Premium with...
I have software for 32 bit computer and would like to install program on new 64 bit computer. When trying to install American Greetings Card program, it states compatibility problem. What can I do to...
If a program cannot be run under Windows 7 64 bit because of compatibility issues you have to right click on the executable file that will start the application and click Properties. Select Compatibility tab and check the Windows version you know the program worked with before. You can find more about this Compatibility issue on Microsoft website.
Dec 19, 2010 | Microsoft Windows Vista Ultimate Edition
How can I run Baudville ID Maker 2000 v 2/0 with Windows Vista
ID Maker 2000 does not support Windows Vista. You can try to install using compatibility mode, but even if successful in installing there will likely be features which don't operate correctly. I would suggest getting the upgrade here: http://www.idville.com/category/id+card+systems/id+card+software.do
Oct 24, 2010 | Baudville Computer Prod ID Maker Express...
I can't install Sonar 4
As I see Sonar 4 has compatibility issues with Windows Vista. Is suggest tu update to a better version
Also you can try compatibility mode doing right click - properties , set compatibility to windows xp
Aug 02, 2009 | Microsoft Windows Vista Ultimate Edition
Windows vista accept all type of softwares to be install
nop
vista is having its own compatibility issues
all old softwares doesnt work on it
Dec 18, 2008 | Microsoft Windows Vista Ultimate Edition
Realtek HDA driver
The driver you are installing needs more requirements. try to install driver from mother board CD. If not try to download realtek HD driver compatible to your processor.
Aug 28, 2008 | Microsoft Windows XP Home Edition
I am trying to install Resume Workshop on my new computer and it has Vista operating system
Most programs written for Windows XP also work in this version of Windows, but some older programs might run poorly or not at all. If a program written for an earlier version of Windows doesn't run correctly, use the Program Compatibility Wizard to change the compatibility settings for the program. To change settings for a program manually, use the individual program's Compatibility tab.
If changing the settings does not fix the problem, go to the program manufacturer's website to see if there is an update for the program.
How to Run the Program Compatibility Wizard 1. Open the Program Compatibility Wizard by clicking the Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, clicking Control Panel, clicking Programs, and then clicking Use an older program with this version of Windows.
2. Follow the instructions in the wizard.
If you cannot install a program, insert the installation disc for the program and, using the wizard, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The wizard is not designed to work on programs that have an .msi file name extension.
To change compatibility settings manually for a program, right-click the icon for the program, click Properties, and then click the Compatibility tab.
Jul 03, 2008 | Computers & Internet
Runtime '429' error
It sounds like your product is not compatible to Vista....you may need to email the creators of this product and ask them for the update if they have made one YET.
Oct 02, 2007 | Individual ResumeMaker Career Edition for...
Open Questions:
D link router CUSTOMER service pHoNe:~{-l84433O2330}-}nUmBeR USA USAiary D link router CUSTOMER service Number +l84433O2330}}USALogin Repair service center to resolve all D link router tEcH SupPoRt pHoNe nUmBeR products. D link router ROUTER is an American multinational company which was founded by Michael D link router ROUTER using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, D link router ROUTER support number, and selling of computer-related services and products. D link router ROUTER Tech Support Phone Number Recently, D link router ROUTER has been named the number D link router ROUTER technical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, D link router ROUTER customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a D link router ROUTER Service Tag or a D link router ROUTER Get D link router ROUTER Technical Support Phone Number and Customer Services. D link router ROUTER is a US-based multinational tech organization having its headquarters located in Round Rock, Texas. This tech organization supports, repairs, sells, and develops technology products. Basically, the company offers computer related products and services.
Oct 21, 2019 | The Computers & Internet
D link router tEcH SupPoRt pHoNe nUmBeR:~{-l84433O2330}^-} USAsary D link router tech Support Number +1{84433O2330}}USALogin Repair service center to resolve all D link router customer service phone Number products. D link router ROUTER is an American multinational company which was founded by Michael D link router ROUTER using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, D link router ROUTER support number, and selling of computer-related services and products. D link router ROUTER Tech Support Phone Number Recently, D link router ROUTER has been named the number D link router ROUTER technical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, D link router ROUTER customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a D link router ROUTER Service Tag or a D link router ROUTER Get D link router ROUTER Technical Support Phone Number and Customer Services. D link router ROUTER is a US-based multinational tech organization having its headquarters located in Round Rock, Texas. This tech organization supports, repairs, sells, and develops technology products. Basically, the company offers computer related products and services.
Computers & Internet Logo
83 people viewed this question
Ekse
Marvin
Marvin
