Question about MSI K8T Neo-V Motherboard
Sata version :1 drivers
Ineed to get a suitable driver for my kst neo -( ms7032) version :1 and all the drivers i have tried so far are not functioning. i need your help
    President:
  • 2,351 Answers
This is the site you are looking for. Just click the link.
http://www.msicomputer.com/product/p_spec.asp?model=K8T_Neo-V&class=mb
Driver download: http://global.msi.com.tw/index.php?func=searchresult&keywords=K8T+Neo-V&table=download
Let MSI scan your PC & suggest updates;
http://global.msi.com.tw/index.php?func=downloadindex
Good Luck & kind Regards.
& please vote.
Posted on Mar 18, 2008
  • MSI Master
  • 3,606 Answers
Download here at msi.
http://www.msi.com/product/mb/K8T-Neo-V.html#/?div=Driver&os=All
Select your windows and unzip the files before you install.
Posted on Nov 15, 2012
I have a MSI K8T NEO.V mother board and I just bought two wd wd1001fals TB hard drives, one internal and one exturnal and the motherboard doesn't acknowlege them at all. Can't the motherboard handle that size?
Thanks
[email protected]
Posted on Nov 23, 2008
Why HDD WD5000AAKS/16Mb did not work with my K8T800+8237R chipset? Thanks.
Posted on Mar 23, 2008
SOURCE:
Driver SATA
The only draivers available are at the location:-
http://www.msi.com/product/mb/848P-Neo-V.html#/?div=Driver&os=All
SATA drivers are part of the BIOS so if the computer isn't seeing it you have a problem with either your drive or your motherboard.
Feb 17, 2012 | MSI 848P Neo-V (MS-6788-040) Pentium 4...
I need drivers pack for microstar motherboard model ms-6788 brand american megatrends inc. version v1.2
Download here at MSI:
http://www.msi.com/product/mb/848P-Neo-S.html#/?div=Driver&os=All
First select your windows system.
Select the driver and download.
Unzip the file before you install.
Here is some other models with the same number:
http://www.msi.com/product/mb/865PE-Neo2-V.html#/?div=Driver&os=All
If i have selectet the wrong mainboard type in the ms XXXX
number here:
http://www.msi.com/service/download/
Good luck
Feb 16, 2011 | MSI 848P Neo-V (MS-6788-040) Pentium 4...
Can my mobo msi k8m neo-v supports sata dvd rw? if yes then how to install dvd rw and sata driver?
If it as a Sata connector on this motherboard (looks as though ther should be one), it will support a SATA DDVRW. You should not need Sata drivers, but to be on the safe side, you can download them from here:
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=159
check your oS first
Jan 04, 2011 | MSI K8M NEO-V Motherboard
Send me the audio driver for MS-7032 K8M Neo-V
open goole home page download Driver magician instal after update serch all drives click audio drive opition driver version support relase date
google page open serch driver name version freedownload after instal problem slove its true ............try
Add a comment
Oct 24, 2010 | MSI K8T Neo-V (7032020) Motherboard
Drivers for msi 848P Neo-V Pentium 4 800FSB Prescott Ready Socket 478 Motherboard w/SATA OEM
hi
go to following link you will have your MSI M/B Drivers
http://driverscollection.com/?H=848P%20Neo-V&By=MSI%20(Microstar)
Aug 30, 2010 | MSI 848P Neo-V (MS-6788-040) Pentium 4...
Drive the motherboard
This is your Mainboard driver
MSI K8T Neo V (MS-7032)
Direct Download :
VIA 10/100 LAN Drivers
XP :
Vista :
VIA PIDE/SATA RAID Drivers & Utility
XP :
Vista :
Realtek ALC Series AC97 Audio Driver
XP :
VIA Chipset 4in1 Drivers
XP :
Vista :
VIA VT8237(R) SATA RAID Driver (For floppy driver)
XP32bit :
AMD Cool and Quiet Driver
• AMD Athlon™ 64/Sempron™/Turion™ 64/Opteron™ systems with ACPI 2.0 processor performance control objects
• WinXP WHQL pass
XP :
May 08, 2009 | Intel Motherboard
Msi pt880 neo v.2
I can't find a version on the MSI site. As far as I can see there were PT880 Neo-SR, LSR and FISR versions. All of these versions are in one manual if you click here to download the exe file. Install the download to extract the pdf. Then you can use that or print it off as you please.
Nov 19, 2008 | MSI PT880 Neo FSR Motherboard
SATA Drive on MSI K8T Neo MS-6702 Ver 1.0
I believe when first installing windows it asks you to press F2 if you want to load sata drivers
Have them handy and follow instructions
Sep 19, 2008 | MSI K8T Neo-FSR Motherboard
SATA configuration for MSI P965 Neo --- JMicron hell!
Once you have loaded your main board drivers,configuration should be pretty much automatic.Personnally,I have my dvd drive on the standard IDE ribbon cable header,and 2 SATA HDD.One on each SATA header.After loading The mainboard Drivers,Windows did the rest.I haven't found any need to mess around with any BIOS settings at all.
I currently am using a Biostar P4M900 board,but I have dealt with MSI before,and they are pretty much the same deal.
Feb 07, 2008 | MSI P965 Neo-F Motherboard
MSI K8T Neo-V Motherboard Logo
648 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Ekse
Thomas F. Schneider
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
