Question about Mag Innovision LT776s 17" LCD Monitor
Blank screen When I boot up, the monitor (just about 2 years old) turns white. I can see a few hazy colored lines in the white. I either have to keep turning the monitor on and off and hitting it on the side or top, or I have to reboot the entire computer. Finally the desktop will come up. The same thing happens if I let it go into sleep mode, so I basically cannot use sleep mode any more. Some days it takes a half dozen trys to get the monitor to work. The cables are not loose, the rest of the computer runs fine. Do I need a new monitor?
  • ALNCEC Mar 19, 2008
    Thank you for the suggestion. The next time I have the problem, I will try the flashlight solution. Then, If I need new lamps, I will have to call Best Buy or some place, and figure out whether they have the lamps, what they cost, and how to open the screen and install them, if they are the problem. There are no visible screws on this screen for opening it.
  • Anonymous Oct 18, 2008
    I also noticed such a problem with my flatscreen monitor, and it only appeared today (after about 2-3 years of usage). On boot, the screen went mostly white, as if someone had pressed down firmly on it with a white paint roller. After the boot process changed modes, the monitor's image was fixed.
    Throughout the workday, nothing was wrong. But the problem recurred again late in the day, when the screen saver was active. The whiteness remained. I turned off the monitor, and when I turned it back on, no white screen. Any ideas as to why it's acting this way?
    Novelist:
  • 138 Answers
Hi this is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen went white, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace.
Thank you,
Posted on Mar 18, 2008
My acer Aspire 3500 wont turn on. It was fine a few hours ago but now wont boot. I keep getting the acer picture featurning the f2 set up and then the screen turns blank with a white flashing - in the left...
if you activity lights on, try connecting to an external monitor or modern flat screen tv. if the screen is flashing then it is probably a screen issue. eg the invertor r screen has failed.
Jul 23, 2011 | Computers & Internet
Blank white screen in my Acer Travelmate 5730 Laptop
Hello Karthik,
This must surely be a problem with your monitor, because you say that you see the white screen while boot up. If this is a graphic driver issue, you may have the problem after booting up in windows. Since its been only a month old laptop, the product must be in warranty for sure. Take away any CDs in the drive, any USB drives and see if this white screen appears. Let us know.
Thank you!
Sabharish
Jun 26, 2009 | Acer LXA3706003 Notebook
Gateway MA7 laptop
If display issue: connect an external monitor to see if any change.
Could be spyware - boot in Safe Mode (F8) - download, install and run SpyBot (spybot.com).
Good luck.
Jun 12, 2009 | Computers & Internet
Dell Inspiron 9400 display goes blank after a few minutes
If the issue occurs in the safe mode, then I'm suspecting a failure of the LCD backlight. (It warms up and quits) Also see if video stays on using an external monitor. If it does, then the LCD is most likely failing.
If video goes out on an external monitor as well, then the Video card is failing due to overheating. Make sure all vents are free of dust (Clean with canned compressed air) and the all fans are functional (Run the fan test in diagnostics) If fans check up, then video card is failure point. If fans fail diags, replace affected fan 1st
May 21, 2009 | Dell Inspiron 9400 Notebook
Reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
Dec 21, 2008 | LG Studioworks 700S 17" CRT Monitor
View sonic flat screen monitor trouble
I have a Viewsonic Flat Screen - recently I turn it on and all I see is like tye dye colors across the monitor with a slight ghost images of windows trying to boot-up. What can I do to fix this. The monitor is about 1 1/2 year old.
Sep 08, 2008 | Computers & Internet
Flickering
it an indication that some of the supporting capacitors are becoming bad see a local technician
Apr 12, 2008 | Gateway FPD1765 17" Flat Panel LCD Monitor
MONITOR SCREEN KEEPS BLANKING OUT WITH A ORANGE COLOR OR BLUE COLOR
It is one coulour missing and it can b mostly due to CRT socket loose or some dry solder in CRT {RGB) path..
Chck out...
This is a technical freak from INDIA!
Apr 07, 2008 | Compaq fs740 17" CRT Monitor
Lacie 19" Electron Blue - Black screen with a brilliant white line across
I have 2 of these monitors and have this problem. I was so frustrated turning the monitor off and on until the white line disappeared that one day, I punched the screen. And it worked! So now whenever this happens (about once every other day) I use my palm and smack the lower left corner of the monitor until the white line disappears. I like the color on these screens so I don't want to replace them until I have to. I will NOT buy another Lacie though.
Sep 13, 2006 | LaCie Electron 19" CRT Monitor
LG Studioworks 700E
seems flyback problem ,leave it to the repairman...
Aug 19, 2006 | LG Studioworks 700S 17" CRT Monitor
Mag Innovision LT776s 17" LCD Monitor Logo
135 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
