59.40 error 4350 machine
  • 1,326 Answers
What make is a 4350? It may help a bit.
Posted on Mar 19, 2008
SOURCE:
ERROR 225 CANON MF4320-4350 WHAT IS PROBLEM
Hi
You can find this error, E225, here:
Error Codes Canon MF4320
where it clearly shows the cause as "CIS lamp has a fault."
and suggests remedies. Also by changing the drop down menus along the top of the page you can view other errors for your machine and for other models and makes. You can also use the link to get a Service Manual for your machine.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 30, 2014 | Radio Communications
HP 4350 with a 41.3 error- Paper size is set correctly and size switch actuator is OK. I tried another tray and also tray 1 (manual feed tray). That tray jams- no lift to feed roller. Any ideas?
I have seen many diferent 41.3 errors. Start by making sure tray is set to standard instead of custom and reset machine to factory settings. Next change out the roller assembly behind the tray 1. It has the selonoid on it. I have seen that cause it before. I would just replace the entire tray 1 to solve the no lift. good luck
Apr 08, 2013 | HP LaserJet 4350 Printer
51.10 error
Thank you for contacting FixYa. I have been working on some archieved inquiries that may have gone unanswered. Your issue is a beam detect error with your laser scanner.
HP LASER PRINTERS 4200, 4300, 4250, 4350 ERROR 51.XX
1. Printer has a beam detect error
2. Replace the cable ***'y from scanner to D.C. controller
3. Replace the scanner ***'y
4. Replace the D.C. controller.
Aug 25, 2011 | HP LaserJet 4350 Printer
My printer hp laserjet 4350 shows error 49,what could be the cause
Most times a "49" error indicares the need for a firmware upgrade.
If the machine is networked, disconnect the network cable and power the printer off, wait 2 minutes and power it back up. It should reset the error.
BEFORE reattaching the network cable delete the job in the printer queue that caused the error ( Most likely a PDF file).
Go here:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=412171&prodTypeId=18972&prodSeriesId=412160&swLang=8&taskId=135&swEnvOID=228#290
and download and install the latest firmware
A workaround is to print the PDF as an image
May 20, 2011 | HP LaserJet 4350 Printer
LaserJet 4350 Printer: HP 4350 printer, 49.2F9D service error...
1st thing to do is upgrade the firmware. Go to hp.com and look for the software and drivers. Drill down to the firmware and read the instructions.
May 16, 2010 | HP LaserJet 4350 Printer
HP Laser jet 4350 dtn printer gets 59.40 error. I
Print Cartridge Motor Error.
Try removing then re-installing the cartridge. If that does not work then you will need to try a different toner cartridge as the toner cartridge is "locked up". These are the most common solutions. If none of these work then you have a cartridge drive problem and will need to contact a service center.
Jan 05, 2010 | HP LaserJet 4350dtn Printer
HP 4350 downgraded to a HP 4250
Is this affecting performance? Try new firmware. www.hp.com/go/lj4350_software.
Mar 20, 2008 | HP LaserJet 4350 Printer
HP 4350 printer
you might need to upgrade the firmware
Dec 28, 2007 | HP LaserJet 4350 Printer
Open Questions:
187 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
