Question about Nikon Coolpix 5700 Digital Camera
Overexposed picture when shot in Auto mode, in bright light picture comes as absolutely overexposed. In less light conditions, picture is good without flash but comes as overexposed again.
  • 1 more comment
  • Tom-at-dasp Aug 20, 2008
    All pictures, except those in very low light conditions, are extremely over exposed. I set all options to factory settings, with no improvement.
  • alangreenone Aug 22, 2008
    I have a similar problem that has recently appeared. it seems to occur when using the camera at any zoom position other than full wide angle. I am contacting Nikon to ask for support!
  • gregdon Sep 03, 2008
    Same over-exposure in bright light, but ok with flash indoor / low light.
    I am assuming a shutter open fault, and hopefully Nikon UK will clarify.
    Novelist:
  • 100 Answers
My guess is the the EV setting is on the + side and not neutral (0). Either that or Image Adjustment setting is wrong. Check EV by pressing the +/- button (right side near On/Off switch). Hold EV selector and make sure 0.0 is in the display. Let me know if that is not the problem and I'll assist you further.
I hope this helps!
Regards,
CharlieJ
[Please rate this solution, if it helps you.]
Posted on Nov 17, 2008
SOURCE:
Over-exposed & Lines Picture problems! Please help!
Kate,
It's six years old - at $90, that represents a mere $15 per annum. Just replace it.
Jun 11, 2017 | Sony Cyber-Shot DSC-H70 Digital Camera
Overexposure
Is the camera in full auto mode or is it in a semi auto mode with manual overide for the exposure?
Jul 07, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
My Canon IXUS 120IS has developed some problem. All the shots are overexposed. I have tried all different setting but still the shots are coming overexposed. IS it a problem with the settings or hardware...
Check the ISO setting...is it too high for the lighting conditions? Check the "exposure compensation"....it should be at "0". If you want darker pictures, you can set it to a lower number.
Jan 14, 2011 | Cameras
Finepix E550 -suddenly very grainy photos and over exposed?
Have you checked what ISO you have selected here?
Graininess and over exposure can be caused by selecting the wrong ISO ( which in film days was ASA ( film speed) The average ISO should be 100 some early models allowed ISO 64 or similar. Having it set at 400 -800 ISO can also have the pics come out grainy. But not nescessarily overexposed unless you point directly at the light source as these ratings are for low light/movement situations. The video mode usually sets itself up differently to picture mode. The fact that you say your video is OK says there is nothing wrong with the lens or sensor, just the settings you have initially chosen to have autoed.
Please rate our help to keep thye service online++++Thanks for using FIXYA
Sep 19, 2009 | Fuji FinePix E550 Digital Camera
Background is overexposed
So, the problem doesn't seem to be the flash if the actual subject in the foreground is exposed properly. My guess is that the background is being lit by another light source. Typically, your camera uses a flash for dark areas or what it gauges as a dark area. This doesn't adjust the background for additional light sources. For example, if you're standing outside and there's a tree covering someone that you're taking a picture of your flash will adjust to "properly" light that individual. However, because the flash was used for the main subject, the background is actually now overexposed. The overexposed background will show up as a brightly lit area because the camera had to adjust for the foreground. This will actually reverse itself when it's dark out - meaning if the background and foreground are dark, the flash will expose the foreground, but the background will be black. Hopefully, that helps you understand lighting and exposure. Now, to fix this problem when shooting, you would need to consider several options - 1. SLR camera with aperture and f-stop settings as well as compensation controls. This will allow you to control every element of the exposure, but you still need to be aware of the lighting behind the "subject" to properly expose your shots. 2. backlighting compensation - common settings on both SLR and point and shoot cameras that makes auto lighting conversions for backlighting and other common lighting issues. Test whatever options are on your camera to see what works best for your specific problem. 3. Photoshop retouching - you may take one shot with your subject exposed properly and a second shot with the background then merge the images together. 4. using a tripod to shoot without using the flash - this may give you the closest exposure to exactly what you see when looking at your subject.
Dec 19, 2008 | Polaroid i733LP Digital Camera
Overexposed
try it in auto mode if it is the same condition do u feel change in color like white turning pink or purple or sort of over exposed pics as u said then i worry that ur CCD HR is going to faulty in coming days later on pics will get pink and purple and then ccd stops working completely , i hope this is not the case do let me know if i can help u
Jan 07, 2008 | Fuji FinePix S1 Pro Digital Camera
Day time photography
Could be a camera problem but it's possible that your hand or part of a straying finger may be covering the sensor on the front that tells the camera what the exposure is in full auto mode. You'll need to do some test shots making sure there's noting in the way. It could be that the sensor is failing, maybe put the camera into fully manual and take a shot a about 125th of a second at f16 on a bright, sunny day to see if the camera responds with a good image. A good source of information is the manufacturers web site, there may be a firmware download that could fix the problem. Good luck with it.
Sep 04, 2007 | Pentax Optio S50 Digital Camera
Blue tint when shooting aperture priority
Hello, First of all let's explain what aperture priority does in terms of electronics and mechanical/optical changes in the way the camera takes photos. Unlike most point and shot digital cameras, your one has variable aperture range. Aperture is related to your camera lens. Their main function will be to collect light and direct it to the camera's sensor. The aperture of a lens is the diameter of the lens opening and is usually controlled by an iris.The larger the diameter of the aperture, the more light reaches the image sensor. Aperture is expressed as "F-stop", for example F2.8 or f/2.8. The smaller the F-stop number (or f/value) the larger the lens opening (aperture). This means that when you're using aperture priority or large aperture values (a smaller f/value) your image sensor (ccd or cmos) will tend to receive more light or slightly overexpose itself. Most simple digital cameras, the point and shot ones, have a fixed aperture, the lens are fixed and that's set to a so believed "optimum" range in order to produce best pictures when using automatic settings. SLR or semi SLR digital camera's woun't achieve best performances when using them on automatic settings, they aren't designed in the same way as the simple camera's. These camera's will tend to either overexpose, or have lighting/colour problems or achieve blurry images when using automatic settings. Any SLR or semi SLR camera user will be required to understand the way photography (electronic photography) works in order to achieve the best performances with it's camera. For your example, I guess the shots have a blue tint on them when you're using natural sun light in your photos, or in room pictures are illuminated by natural sun light. This is the first sign of overexpure, and the best way to reduce it and it's efects is to manually set the aperture range. Note that higher values will reduce the light that passes to the sensor, so you will want to experiment a little with those in order to achieve the best performance. When you take photos in light environments, bright sunny days or in rooms that contain many white surfaces or walls (these reflect the light pretty much and can overexpose the camera even if it doesn't look that bright when you look at them with your own eyes) you may want to use larger aperture value in order to have little light come to the sensor. Look for the highest values in aperture (in your menu) for example F8 or F16. If the pictures come out to dark or miss some details, you may want to use larger apertures (smaller numbers). Try these tests in order to check if your camera's problem can be solved this way. If not please reply back and we will look on the hardware - firmware side of the problem. Regarding aperture a quick recap :) A large aperture allows more light to reach the sensor. It's good when taking portret pictures and also achieves that nice blurry background surrounding your main subject in the picture. It's defined by smaller numbers (for example F1.8 or F1.2 or smaller). A small aperture allows little light to reach the sensor. It's good to take pictures in bright sun light. It's defined by larger numers (for example F16 or F22 or larger). Hope this helps, Bogdan.
Jul 01, 2007 | Nikon D40x Digital Camera
My picture is too light (overexposed).
If you're using the forced flash setting, it may be too bright. Try setting the flash to Auto. If you're facing a bright light source, you may need to shoot your picture from a different angle. Use Image Expert to adjust the picture's brightness, as described on page 9-4. Set user mode to Manual and adjust the camera's exposure setting.
Sep 13, 2005 | Epson PhotoPC 800 Digital Camera
Finepix 2400 Dark landscape shots
I was just out yesterday taking pictures in very hazy conditions, and some of my shots were facing south at about noon. I was actually expecting the sky to be overexposed, so I took two pictures of everything, one on auto, and one on manual with the exposure set to -0.6. Well, it turned out that even the ones on Auto were dark, so the ones on the manual settings were even worse! As it turns out, I had the same problem you had, and should have boosted the exposure. Reading the manual, it does say that you should use positive compensation for very bright scenes or pictures of mostly sky. Try it next time and see how that works. I'm new to this too, but I'll get the hang of it sooner or later... ;)
Sep 04, 2005 | Fuji FinePix 2400 Zoom Digital Camera
Nikon Coolpix 5700 Digital Camera Logo
1,559 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
