Question about Siemens optiset E Corded Phone
How to MUTE?
How to switch on mute function in Siemens optiset?
regards,
Vijay
How to put the phone on mute
Your phone must have MUTE buttton.
Dec 15, 2015 | Siemens optiset E Corded Phone
How to mute microphone on Siemens 5020
Locate the mute button on the button pad or headpiece or open the "Options" menu and locate mute from there.
  • Press the mute button or select it from the "Options" menu and click on it.
  • Press the mute button again to deselect mute. You will have to open the "Options" menu to deselect mute on micphone headset that mute in this way.
  • Apr 11, 2012 | Lands Phones
    Euroset 2005 phone does not have high low volume switch
    ya you are write the volume switch is not given in Euroset 2005. volume can be adjusted by this code while u pick up the receiver "Set/mute # 4 #"
    M.Qasim
    Jul 18, 2011 | Siemens Euroset 2005 Corded Phone
    I can hear but people can't hear me
    Try to unmute the headset. This may be your problem. The mute function is enabled through the volume buttons. Simply tap both volume buttons at the same time until you hear a mute tone. The mute tone when unmuting the call will be a descending tone. When you tap both volume buttons, if you hear a descending tone you have just disabled the mute function and your problem is solved. If the mute tone is ascending tones you have just enable the mute function and this was not the issue. If this is the case consult your user manual or contact Motorola for trouble shooting.
    Aug 27, 2010 | Motorola Mobility H710 Bluetooth Headset
    My I use my H 710 I can hear my customers but they can not hear me. How do I remove mute? Thanks
    Aug 23, 2010 | Motorola Mobility H710 Bluetooth Headset
    I can hear the other person but they can't hear me
    Your headset may be muted. Try to unmute the call. The mute function is enabled through the volume buttons. Simply tap both volume buttons at the same time until you hear a mute tone. The mute tone when unmuting the call will be a descending tone. When you tap both volume buttons, if you hear a descending tone you have just disabled the mute function and your problem is solved. If the mute tone is ascending tones you have just enable the mute function and this was not the issue. If this is the case consult your user manual or contact Motorola for trouble shooting.
    Aug 18, 2010 | Motorola Mobility H710 Bluetooth Headset
    Mute button wont turn off
    HERE is your manual in PDF format.
    This unit doesnt have a volume mute function.
    What are the problems you are experiencing.
    If it says Mute or ATT on the display - it is the cellular mute function turning off the volume for an incoming call.
    Page 34 details turning on and off the cellular mute function.
    You also may try a hard reset by removing the face, and pressing the reset button.
    Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question
    May 06, 2009 | Audio Players & Recorders
    My laptop is Fujitsu Siemens AMILO Pro Celeron. somehow the sound is not coming... i dont know why??? i tried my best to get to know the problem... but nothing seems to be helpful
    There are four ways to turn sound down or mute it on a laptop.
    In the Windows Desktop there is normally an icon of a speaker near the digital clock on the bottom far right. You can rest or click your mouse over this icon and a volume slider pops up onscreen. In this pop up the slider can be turned down or the mute box checked.
    A laoptop also has special function keys activated by the Fn key near the left side of the spacebar. This Fn key has letter colors that are different than the rest of the keys. Pressing and holding this Fn key and also using another key activates the Special Functions. Usually pressing Fn +PgUp or PgDn and or End will raise lower or mute the sound in that order. the Pg Up keys, etc. have other lettering on them to indicate the special function. Often this is just and icon.
    With these hints you may be able to get your sound back on. If not, tell me how and under what circumstance you lost the sound. It could be a deeper setting in your laptop.
    Regards,
    Worldvet
    Nov 30, 2008 | Computers & Internet
    Siemens optiset E Corded Phone Logo
    698 people viewed this question
    Top Siemens Lands Phones Experts
    Ekse
    Marvin
    Marvin
    Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
