Mobile broadband issues
Hi, I have a mobile broadband device, which works fine, but when I start the application up, it wont let me open any other programs until I pull it out of the usb port, then the all start to pop up (programs)
I used registry mechanic and it fixed the problem, but it has come back again, it gets really annoying, what should I do.
Reinstalling the software doesn't help either, tried that.
Can you help?
SOURCE:
SOURCE: Pocket LOOX T830 conection problems
In Settings-->Connections-->USB TO PC, uncheck the "Enable advanced network functionality" helped the PDA Phone work with my laptop.
Posted on Jun 23, 2007
SOURCE: How can I get my Vista laptop to open LG Mobile Sync Ver 1.0?
lg k500e is not compatible with vista as most things at the moment unfortunatly
Posted on Apr 13, 2008
  • 4 Answers
SOURCE: Cannot connect using LG internet cube software
I had the same problem but now i have found the solution for it. Its not the software its the phone. Go to your Phone Settings hit Connectivity and then Usb Connection select Data Service and now connect your phone to the pc and select connect in Mobilesync and it should work. After you are done using MOBILE SYNC you can simple go in settings once again and choose mass storage for any downloads!!!
Posted on May 12, 2008
SOURCE: Computer cannot detect camera at all!
This works for Windows98
1. Uninstall the Canon camera software.
2. Search for "Canon" in the registry. Delete ALL references associated with Canon camera in the registry. Just uninstalling the software will not work. Do not delete any other references to Canon products (printers, etc).
3. Re-install the Canon camera software.
I've had to do this several times. Works every time.
Posted on May 17, 2008
SOURCE: Can not connect using LG Mobile Sync
I have an LG 970 with precisely this stupid problem. In many, many ways, this phone is a complete nuisance. This particular stupidity is a phone setup issue, it cannot be a Mass storage Device and a Data Service at the same time.
Solution:
Phone, Menu, 9 Settings, 4 Connectivity, 3 USB connection, ...
- select "Mass storage" if you want to access images, sounds etc using Windows Explorer, just like any other USB stick
- select "Data service" if you want to use the LG Mobile Sync application
FH, Denmark
Posted on Oct 13, 2008
I purchased a 50 dollar top up over the phone for my broadband account but still can't get on the internet. It tells me I'm connected but I'm not. What can I do to fix this issue
Hi Cherryl, at first when top up was done, you should always restart the mobile device in order for the account information to refresh and IP as well. Then try to reconnect and see if you are able to browse successfully.
May 18, 2014 | Novatel MiFi 2200 Mobile WiFi Hotspot...
Phone crash after sd patition it wont start
If your phone wont start after an "SD Partition" this means that your device is corrupted i would advise you to bring your mobile device to the Mobile Shop where they can fix the issue.
Feb 25, 2013 | Samsung Cell Phones
How to configure pocketwifi
Quick Start Guide Introduction
Your Pocket WiFi™ Router sends out a WiFi signal so that you can connect to the Internet without the need for wires. Your Pocket WiFi™ links multiple WiFi enabled devices at any one time, for example your laptop, Apple® iPod touch, Apple® iPad or Nintendo DSi.
How many people or devices can share my connection at any one time?
Up to five devices can be connected. With increased users and high data downloading (i.e. streaming music) the speed may be slower.
Does Pocket WiFiTM work on Mac, Linux or Windows 7 computers?
Yes, Pocket WiFiTM with most WiFi enabled devices. The dashboard is browser based so works with any operating system.
Terms and Conditions
Check for PocketWiFi compatibility with the devices you intend to use it with before you buy. Device can operate with a maximum of 5 compatible WiFi enabled devices at ay one time. Unlocking fee applies. Broadband Availability: Broadband speeds are available in Vodafone's 3G Mobile Broadband Zone. Slower speeds can be expected outside Vodafone's 3G Mobile Broadband Zone. High bandwidth applications, such as video and music streaming, and full track downloads, only available in Vodafone's 3G Mobile Broadband Zone. Actual speed achieved varies depending on factors such as device capabilities, location and network usage. See www.vodafone.com.au/coverage for details. Vodafone Pty Limited ABN 76 062 954 554.
Sep 20, 2011 | Computers & Internet
I was surfing on net by connectting my samsung c3510 to my pc,and at the same time i want to open gmail java application on same device (samsung c3510).at the movement of opening java application my...
hi just remove the cable connecting to your computer and dismandel the mobile just remove your mobile battery and again replace it as it was and then switch it on the mobile will work as normal
Feb 26, 2011 | Cell Phones
I need usb driver in linux for my mobile samsung sgh x820
hi...
many mobile phone companies dont provide drivers for linux.
But there is a software i would personaly recommend to you. Actually its not a software, its a shell script.
Name of software is "Sakis3g". It can connect to mobile phones and other mobile devices which can be detected by linux kernel. You can use IR, Bluetooth, even USB cable to connect to your device.
You can use this software for the following
connect to mobile devices by IR, bluetooth, USB Cable
  1. Send and receive files between computer and device
  2. Access Internet from Device by Dial Up Networking
  3. Browse files on Mobile device
  4. Mount the mobile device on a user specified mount point or communication port.
    usually it mounts connected mobile device to /dev/rfcomm0. Through this port, you can communicate with the device .
Connect to USB Modem (Like Reliance DataConnect, TATA Photon, IDEA Netsetter etc.)
  1. ability to connect to any locked/unlocked USB internet Modems (Zero Devices)
  2. fully automated connection setup. No manual input is needed except to specify connection name.
You can find more details and download Sakis3g from this address
http://www.linuxconfig.org/mobile-broadband-connection-and-sakis3g
hope this will help you to solve your issue.
Dec 12, 2010 | Samsung SGH-X820 Phone
I am unable to install .jad and .jar files on my htc touch viva phone is it possible to install these files on a windows mobile phone if not what type of applications would work pls guide
hi no sorry it is not possible, they are mobile phone format file extensions only i gather you are trying to install games or apps on you phone? sorry but thats the only thing they will run on....hope this helps
Jul 26, 2010 | Computers & Internet
Windows 7 on aspire one AOA150, built in modem doesn't work
After installing Windows 7 and any other new applications, please ensure that you have loaded ALL the required W7 drivers for your specific Aspire One especially the CHIPSET supports driver (if not, plug-in devices and other inbuilt devices like sound, modem, usb or video will not work properly). Hope it helps. Let me know how you go!
Dec 31, 2009 | Acer Aspire One AOA110-1113 Netbook
I am trting to install a mobile broadband device on my dell laptop - I get error 1152 erroe extracting to Temp location. The device will load fine on all other PC'S
go to start then click on run. type in %temp% then click enter when the screen opens look for your device or whatever software or drivers you or it tryied to install and double click on it and it should finnish installing or open up for you.
Please rate my answer its much apreceted
Feb 12, 2009 | Computers & Internet
Blackjack II blank start screen
Hi dogbyte,
For some reason, certain Windows Mobile (Standard) devices don't like "list" format for the Start Menu.
Give this a try:
1) Remove the battery for 1-2 minutes. (This allows any cached memory to clear)
2) Power the device back up.
3) Before openning ANY other apps, navigate to Start > Settings > Display > Start Menu Style
4) Change this value from "List" to "Grid"
5) Click Done twice, then click the Home key.
6) Give the Start menu another try. (Does this resolve the issue?)
Another forum suggested that Windows Mobile seems to be a little picky about which application appears first on the Start Menu. If you have any custom applications installed, it's possible WinMo's start menu just isn't playing nicely.
Hope this helps!
Apr 10, 2008 | Samsung BlackJack II Smartphone
Open Questions:
WEBROOT TechnICal SupPoRt pHone ~II+[[18OO8-O31O69}} NumbEr u.sa//vs Usa WEBROOT USA phone number is ranked #2 out of 2 because 7,728 WEBROOT USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the WEBROOT USA Technical Support department for problems like Where to buy, Complaint, Technical support, Repairs, Returns. As far as we can tell, WEBROOT USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. WEBROOT USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact WEBROOT USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling WEBROOT USA Calling WEBROOT USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from WEBROOT USA Technical Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with WEBROOT USA's Technical Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare WEBROOT USA's phone numbers against each other. Contacting WEBROOT USA in General While I8OO8O31O69 is WEBROOT USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach WEBROOT USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact WEBROOT USA.
Oct 17, 2019 | Webroot Computers & Internet
Computers & Internet Logo
42 people viewed this question
Ekse
Alun Cox
