Question about HTC Touch P3450 Smartphone
My Touch Cube Doesn't Work
If I slide my finger upward, nothing happens.
How can make my touch cube work?
  • Anonymous Oct 05, 2008
    my cube doesnt work?
Use a registry editor (ex. PHM Registry Editor) and change the following key:
HKLM\Software\OEM\TFLOSettings
EnableCube = 1 (DWORD)
EnableScrool = 1 (DWORD)
Posted on May 29, 2008
I went to use my ipod touch this morning and the touch screen just wont work. The home and hold button work but it doesn't help because it won't let me slide to unlock. I tried holding down the home and...
hELLO THERE:
Many people think that it's a pressure problem, and the fact that the iPod is not picking up the pressure you apply when you touch the screen to perform a task. However, the screen on the iPod Touch is not pressure-activated but rather, heat-activated. This means that when you touch the iPod screen, the sensors inside the Touch pick up on the heat from your finger and follow it to wherever it goes. If it can't pick up the heat, it won't be able to do much for you. Luckily, because it's the heat sensor, the problem can sometimes be very easily corrected.
Oftentimes, this problem occurs when people are outside on a very warm day and are trying to use their iPod Touch. Because the surrounding air is just as warm, or hotter, than the temperature from the tip of the finger, the sensors can't differentiate and so, they don't respond when you touch the screen. So, just move to a cooler place and you should be able to operate your iPod Touch again. Some also suggest turning your iPod off and on and waiting a few minutes before trying again to see if it will work.
Unfortunately, if those solutions don't work for you, you might be out of luck and might just have a defective screen. If this happens, the only solution sadly is to return your iPod Touch to Apple and hopefully, you're still under warranty to get a new one.
Nov 13, 2010 | Apple iPhone Smartphone
Tip
Htc touchflow cube technology
Picture rotating is available in Touch Vogue not in GSM but you can install the s/w HTC Album (as available with me HTC-Album-1-0-822-716.cab) then you can do it as you have seen in YouTube clip for Touch.http://www.youtube.com/watch?v=TkJR5JVDGcs
you can find the file Htc album 1-0-822-716.cab through google search
insatlling this u can slide pictures using ur finger tips rotate nd zoom
on Mar 11, 2009 | HTC Touch P3452 Smartphone
Game cube disc no spin cleaned disc nothing
your lens is ruined it will not work anymore have you look inside it says DO NOT TOUCH LENS!!!! you touch it thats your problem. im sorry please rate!
Apr 10, 2010 | Nintendo GameCube Console
HTC touch flo cube
Just try colly from exact bottom center and push your finger very normally....even it took me about 3-4 days to get it right
Feb 08, 2009 | HTC Touch P3452 Smartphone
No touchflo
Do you mean that you cannot use the cube which IS displayed on the screen or there is no cube on the screen?
If the cube is not on the screen then just slide Firmly from the centre of the screen base so that the cube pops up.
If the cube is displyedbut not working...just hard reset..hope you have a data backup.
Feb 04, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
HTC Touch P 3452
hey u ppl... i bought htc p3452 just 4 days ago n its an amazing phone... as far as the cube in concerned, its an old feature which comes in htc p3450 which has been withdrawn by the company in india( to d best of my knowledge). p3452 has an improved touch feature having a touch flow bar instead of the conventional cube... and its far better than the cube... so i guess dat resolves d fuss abt the cube...
Dec 31, 2008 | HTC Touch P3452 Smartphone
Game cube not reading disk
I have a game cube that does the same thing. I open it while it's turned off and put my finger on the eye and slide it back and forth a few time. It works after a few tries. I think the gears that move the eye are wore out.
Sep 20, 2008 | Video Game Consoles & Games
Cube doesnt work
Slide your finger up from the very bottom (or even lower) of the screen
Aug 08, 2008 | HTC Touch P3450 Smartphone
Frigidaire In Door Ice Dispenser
betz589,
I had the same problem and just finished fixing it myself. 1st, slide out your ice bin about 3-4" and look underneath it. There will be a long brass rod running along the underside of the ice and goes into a little square hole below the ice maker. This rod runs the flap on the dispensor and keeps it closed for crushed ice and opens the flap for cubed ice. The is a plastic bar inside the little square hole that needs to be moved. Slide your finger onto the plastic bar inside the square hole and move it either up or down. Slide the ice bin back in and try cubed ice. If it doesn't work, move the plastic bar the other direction. This will fix your problem...........Good Luck! Dennis
Aug 01, 2008 | Refrigerators
Touch cube
Install the "Cube Config Tool" and you can change the apps for all of the buttons on the cube.
Jan 10, 2008 | HTC Touch P3450 Smartphone
HTC Touch P3450 Smartphone Logo
64 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
