Question about Dryers
Tumble dryer Creda Smplicity T320VW
I cannot remove outer casing of dryer to replace belt. Have removed all visble screws
  • Anonymous Dec 14, 2008
    How do you change the belt for a creda t320vw tumble dryer?
  • turacyd Apr 17, 2009
    removed all screws and cant pull cover off to get at belt how do I remove cover
I am an authorized servicer for Creda and I can explain how to remove the front panel to change the belt. Email me at [email protected] if you still need help.
Posted on May 19, 2008
SOURCE:
How to put belt on hotpoint dryer
Dryer Belt Replacement - YouTube
? 6:23
https://www.youtube.com/watch?v=dFB4vnmADh0
Jun 20, 2011 - Uploaded by Repairs101
How to do-it-yourself instructional on changing the drive belt on an electric ... She wanted to know about replacing the drive beltin her clothes dryer. ..... How to replace tumble dryer beltHotpoint, Indesit, Ariston, Creda, Proline ...
How to replace tumble dryer belt Hotpoint, Indesit, Ariston ...
? 9:36
https://www.youtube.com/watch?v=kNJGHyEPiJA
Jan 30, 2014 - Uploaded by how-2-repair.com
How to replace tumble dryer belt Hotpoint, Indesit, Ariston, Creda, .... to get right and the grooves correspond to the drive, so really obvious..
Dryer Drive Belt (part #WE12M29) - How To Replace ...
? 5:14
https://www.youtube.com/watch?v=ZXSJlWcZPiY
Oct 25, 2013 - Uploaded by AppliancePartsPros
Buy the new Dryer Drive Belt WE12M29 ... to replace the Dryer Drive Belt WE12M29 on GE, Hotpoint, RCA, Sears, and Kenmore dryers.
Jan 01, 2016 | Hotpoint Dryers
How do get into this dryer? Is there a secret to opening it?
1st remove outer door 17 by removing screws from 2 hinges so that you can remove front panel 24. Then remove drum support 6 (bottom pix) so that you can remove belt 18c9ql4ekhbnniaaaaaelftksuqmcc
6rdyt7bom98aaaaasuvork5cyii=
Jun 24, 2014 | Maytag Neptune MDE5500AY Electric Dryer
How to replace belt on Creda T620 CW Tumble Dryer
Remove the back panel quite a few screws, once of the belt can be seen, mind your fingers (use hook on metal coat hanger or the like) and roll the drum slowly with the hook under the belt directing it off the drum, refit is much the same as removal although special care should be taken not to nip the belt, fit to small pulley first on motor then turn drum slowly gradually rolling onto the drum mind the fingers and obviously make sure machine is off.
Nov 28, 2013 | Washing Machines
How to fit belt on Creda Reversair 37643 Tumble dryer
New belt is very tight, so you have to use more strength. Put it on motor and all other on "drum". Spin it easily and slowly but with strength until its done.
Be carefully, use gloves.
Apr 13, 2013 | Indesit Hotpoint Creda Tumble Dryer Belt...
How do i get the case off to change the belt on my creda t320vw dryer have undone all visible screws.
You also need to remove the top console panel, and timer knob to reveal hidden screw, and the rear panel if you have not already done so.
Then the whole cabinet pulls upwards.
Hope this helps.
Please rate my solution.
Thankyou.
Jan 25, 2010 | Dryers
I have a Creda 37374 Tumble Dryer and the belt has snapped. ive managed to get to the insides of the machine but how do i replace the belt as it looks as if it came off two pulleys next to the motor and...
remove the timer knob and you`ll see a small screw. remove that and the from control panel should slide upwards. once thats off you will see two metal rods/arms which fit onto the rear and the front of machine. remove the 2 screws holding the 2 rods/arms. the front of the machine can now be moved forward enough to get the belt over the drum. when the belt is over the drum, place belt onto the motor drive shaft (ribbed part of belt to ribbed pulley) then put belt between the sprung rollers and onto both rollers. make sure drum is then re aligned onto the bearing sliders on the front panel of machine. fasten back up. job done.
Jan 20, 2010 | Dryers
My creda reverseair tumberledryer won';t work. my
Hi
If you can hear the motor running and have also checked the belt tension and they are O.K., then the only thing I can think of is the Motor pulley, where the belt sits on.
Check that out and make sure it is not loose on the motor shaft, so that the motor turns but the pulley slips.
Regards
Ash
Nov 09, 2009 | Creda IWD12 Front Load Washer / Dryer
How to fit a belt to a creda tumble dryer
open case
loop belt around bits
close case
more particularly
Unplug dryer
pull dryer away from wall
remove 1 screw each side at back of top plate
slide top plate backwards and lift off
undo 1 screw each side of front kickplate
tlit front panel up
unplug door switch
set front panel aside
careful of control panel its V.fragile
(I lay the dryer on its back)
pull out old belt and bits of belt
loop new belt round drum at wear marks
pull tensioner to end of travel against spring
loop belt round motor pulley & both tensioner wheels(most creda) 1 wheel (old)
relax tensioner
rotate drum by hand to make sure belt wont jump off
reassemble in reverse order
creda uses hotpoint parts
Oct 30, 2008 | Dryers
How to change a drive belt on a candy CDC266 tumble dryer
don't know what make you have but if you go to sears .com click on parts put in your model number(inside dryer door)you will find a break down of everything you need to know,let me know how you do-mike
Oct 12, 2008 | Candy CDC266 Dryer
Creda
remove the rear panel screws, remove side panels, pull drum backwards, slide belt down front of drum and under, refit rear panel screws refitting drum at the same time, place belt around motor spindle and reasemble, job done.
Dec 24, 2007 | Washing Machines
Dryers Logo
704 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
