Question about Frigidaire GLTF1240A Front Load Washer
Drum/Tumbler hammers loud
Replaced both shocks as one eye was broken on one.Drum is still hammering away loud!Do I have an internal problem with the tumbler?I have been told it could possibly be the driven pulley isn,t square on the shaft?
  • wayne911 Apr 13, 2008
    when in final spin mode the washer flaps loudly only in finial spin opened up the back and no sign of any thing loose no thrust movment on either pulley cant see the rollers i think it is enclosed
We are talking washers not dryers. The inner spin tub probably has broken spyder it bolts to the tub but is not available as a seperate part.
Posted on Jul 03, 2008
    Scholar:
  • 49 Answers
The drum is driven by a belt attached to the motor. In order for the drum to turn freely, it is SUPPORTED by a rollers. One of these rolers may be broken (cracked or split) so the drum is not equally supportedon all sides.
If you open the machine up - you'll see it. Depending on the particular brand sometimes there a set 0of rollers in the front AND back, sometimes just the front - with the back supported by a central pivot.
I hope this helps
Posted on Mar 18, 2008
I have a ingersal rand 2141 3/4" impact the hammer frame had broken. It was replaced and
THE IR 2141 HAS A 2 HAMMERS, ON 1 SIDE IT IS FLAT AND ON THE OTHER IS HAS A BEVEL. THE 2 BEVELS HAVE TO FACE AWAY FROM EACH OTHER AND 180 DEGREES OPPOSED (1 UP AND 1 DOWN) IF NOT ORIENTED CORRECTLY IT WILL CAUSE THE MECHANISM TO LOCK. FOLLOW THIS LINK AND LOOK AT ITEM 15.
http://irtechpubs.com/ir_pdfs/Tools/Impact%20Tools/Air%20Impactools/04584009_ed1.PDF
May 01, 2013 | Air Tools & Compressors
Need to replace back left rear wheel studs...3 out of 4 are broken. How difficult is this? Should I just purchase another drum? Is the drum difficult to get off and install for a want to be mechanic?
drum is not hard to get off and install
no dont buy another drum
once you remove drum,you can just knock the broken studs out with a hammer and punch
to install new studs,just tap them into place with a hammer. the studs go in from the inside of drum.happy mechanicing
Dec 23, 2010 | 2000 Ford Focus
Into the spin dry cycle a loud hammering noise appears. Immediately goes away when powered off and drum speed drops. Can you please advise. Regards Geoff
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Oct 05, 2010 | Hoover H130E Front Load Washer
The bolt broke off with the lug nut. how to take out the old bolt.
If it is like a VW Jetta lug bolt, soak it with PB Blaster.
Take a sharp center punch and a heavy ball pien hammer and drive the broken threaded portion the bolt in the direction it goes to remove the bolt. Hold the center punch at appor 60 degree angle to the plane of the drum or disk and hammer away.
If it is a splined threaded bolt soak it with PB Blaster and drive it out from the back side of the drum or disc. Use a pin punch or rod or old bolt slightly smaller then the splined broken off portion and hammer away.
Above proccdure saves my bacon countless times!
Good luck
Terry
Sep 19, 2010 | 1985 Toyota Tercel
My Whirlpool front load washer is out of balance when spinning. It makes a loud noise. How do I get the tub back in balance? GHW9200LQ is the model.
Whirlpool front load washers have shock absorbers that helps them in moving the washer around the place. Due to regular usage of the washer it may tend to break.This will result in drum hammering sound . To clear this problem pull the bottom front off and check the shocks. Typically the rings where the pins go through are where they will break. You have to grab them and should have a complete check by moving them to see that whether they are broken.
Thank you !!
May 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Orange light on drum. drum making a loud hammering sound when printer is put on or attempting to print.
Sounds like a broken drum drive gear. Try another known good drum assembly first. Parts can be googled and found. But, difficult for end user to replace. You have to remove all covers and fuser asm. Then gear housing from the left side to change the drum drive gear.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Dec 30, 2009 | Brother HL 1440 Laser Printer
How do i remove the brake drum on my 1996 dodge caravan
You remove the tire/wheel assembly and pull it off. Make sure you have removed the factory installed wheel lock tabs on your studs if they are still there.Discard them because they're not needed.
Jun 15, 2009 | 1994 Suzuki Swift
Something stuck in drum, spinning cycle loud hammering/clacking sound
hi there,
sounds like you may have something caught between the tumbler and the cabinet. since the drum has holes in it, can you have a look if you can see anything that's come of clothing, like a bra wire. it's usually something bigger.
Sep 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire GLTF1240A Front Load Washer Logo
151 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
