Question about Sanyo HT27546 TV
Sanyo HT27547 tv - lightening came in on coax line
My 7 month old Sanyo HT27547 tv won't turn on. Lightening came in on the coax from the antenna and the set went off. There wasn't any dramatic sound or smell from the set, it just went off and won't come back on.
Is there a reset inside or a fuse like old televisions had back in the day or am I just out a fairly new tv that I liked?
    Problem Solver:
  • 20 Answers
Ther is probably a fuse and a diode that got hit by the lighting. If you want to try to fix it yourself unplug it check the fuse and change it if it is bad. Then turn it on again. If it blows that fuse then a diode is also out.
Posted on Mar 19, 2008
SOURCE:
What is the likely culprit to troubleshoot on a tv that will not power on and there is no standby light after a lightening strike in the area and fried Directv recievers and tvs?
Hi , it sounds as if the av board is probably fried but it probably did not stop there it may not be worth getting it checked out as that's just another bill to tell you its not worth repairing. Take time to think about it. But get it checked if you wish there is a lot of power in a lightning strike. It could fry one board and pass through the next as they are usually connected.
Mar 10, 2016 | Televison & Video
Why won't my TV turn on after a storm?
Your TV might very easily be destroyed now, from lightening damage. Lightening can come in on the cable, on the power line, all sorts of unexpected ways. I've personally been struck by lightening, plenty hard enough to destroy almost any electronic device... and I was working in a basement at the time.
Jul 30, 2014 | Samsung Televison & Video
My lg tv won't turn on after a lightening storm
Your surge protector did not function properly, contact the manufacturer of the power strip.
Jul 05, 2012 | LG 55 55LW5600 3D LCD TV
RE: Aquos LC40C32U. I replaced the power supply bd a year ago, cost $110. It has failed again (no power light.) ater a series of lightening storms. I am reluctant to spend more money on it. What is...
You can't blame any component in the TV failing after lightening storms. Get lightening arrestors on the antenna cable and use a surge protector on the power cord before you replace the power board again.
Sep 02, 2011 | Sharp AQUOS LC-40C32U 32 in. LCD TV
My LT-37131 was damagd by lightening which came in through the Phone/Coax and destroyed the CISCO set top box attached to the TV via HDMI interface. The TV works only on composite and component connections...
Hi ydoomgm901,
All the inputs mentioned that don't work are located in the main board and the inputs working are connected on a different board, since they might not been not in use at the time of the lightening.
The main board is the one that should be replace to get the defective inputs to work.
If this is something you might want to try fixing yourself, check this link to find the main. That could be a cheaper solution in case you decide to fix your LCD.
Let me know if you require further assistance.
Aug 26, 2010 | Mitsubishi LT37131 37 in. HDTV LCD...
We had a near lightning strike and now my tv (sanyo model ht27744)doesn't want to come on.
Lightening may have caused a surge on your power lines to the house and to the outlet the TV was on.
Do other things work on that outlet? If not you tripped a power breaker.If they do work check this.
Unplug the TV for 2 min or more and plug back in.
Try bypassing your surge protector you had it plugged into. It could have died when the lightening struck.
(no surge protector?) Bet you'll buy one for your next TV.
Look for 3000 joules and up rating for a surge protector and insure it has protection for a cable/antenna input too.
If this doesn't work the TV may be fried or internal fuse blown.
Time to take it to a repair shop or depending on it's age (5 years+) it may be time to buy a new TV and surge protector.
Near Lightening strikes can effect appliances from several inputs that could be affected from outside like Power, Cable, Antennas, Phone Lines that come into your house.
Jul 06, 2009 | Sanyo Televison & Video
Suspected lightening damage
yes ligthning damage your unit because of static electricity that increase the power of your power source
Aug 09, 2008 | JVC AV-27530 27" TV
Re: Sanyo TV Model #: HT27547 Will I have to get a converter box to watch tv stations?? In a few days I will disconnect my satellite service. Thank you!
This link will verify that yours is digital ready.
If not click able go here.
http://reviews.walmart.com/1336/5652233/reviews.htm
to see reviews for your Sanyo flat screen model ht27547
You may have to purchase a new antenna to do that search for one that is specifically for digital reception and good for the distance from station to home. (Range rating)
Apr 25, 2008 | Televison & Video
Sanyo HT27546 TV Logo
194 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
