Question about GE JES636WK 700 Watts Microwave Oven
Microwave jes636 Microwave made a popping sound and now will not heat...
  • GE Master
  • 9,098 Answers
The popping sound was probably the high voltage rectifier diode failing.
If it's bad, the symptoms you usually experience id that it runs but won't heat. It may hum a little louder, or even a little less.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa:
You can usually find helpful exploded view diagrams and order parts by entering your full model number here:
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
A typical diode is shown below.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 31, 2008
Is there A FUSE? My microwave gave a pop and stopped working?
If your microwave gave a pop sound, that was the magnetron going "heats food" to have it repaired will probably exceed the price of a new microwave oven. There is a main fuse in the unit near the high voltage parts.
Mar 25, 2011 | Microwave Ovens
Own Whirlpool microwave model MH7100XY, everything works on it, however it does not heat anything, heard a small pop and after that it does not warm or cook anything?????
The pop sound is an indicator the magnetron is gone that heats the food. It is cheaper to replace the microwave oven than have it repaired.
Mar 19, 2011 | Whirlpool MH7140XF Microwave Oven
Doesnt heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
May 13, 2010 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
GE spacesaver microwave JVM1631WB002- making popping noise
The material is popping as a result of being heated.
Jan 19, 2018 | GE Microwave Ovens
Made a popping sound. Runs but doesn't heat
Remove the outer cover and look for a blown fuse. Change the high voltage diode (pull the power plug first) and the 'stirrer' (a fan-like device located inside the sheet metal waveguide near the port where the microwave energy enters the cooking cavity). It's plastic bearing will arc-over causing a short circuit on the microwave energy.
Nov 03, 2009 | GE JES1456 Microwave Oven
Microwave popped and now does not heat
Okay, first we need to separate the situations. You were boiling water on the stove and had the range hood fan running to **** up the steam. Then you put something in the microwave to heat and you heard a pop and then zip-o.
The water on the stove has nothing to do with the situation, the fan you turn on is not part of the microwave, so it has nothing to do with the microwave.
The pop you heard and then the humming suggests the magnetron failed. You said you found a blow fuse and replaced it and still nothing, right? The magnetron is the most likely culprit...I would think it is safe to say that the magnetron shorted and drew enough current to blow the fuse.
Replace the magnetron and if that doesn't work, let me know here. Good Luck!
Sep 14, 2009 | Sharp R-1480 Microwave Oven
Hotpoint Microwave - won't stop spinning/buttons seem to do nothi
if i understand, u say it is intermittent right? control pad get wet? it is definitely not mag, diode, cap.
Aug 19, 2009 | GE Microwave Ovens
Loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
Jun 03, 2009 | GE Profile Spacemaker Over-the-Range...
Microwave made loud popping sound and now does not heat.
Try this
Probably a high voltage diode popped because contaminated grease eventually built up and made a path for a high voltsge arc to occur.. To confirm,take the outer cover off the microwave and discharge the high voltage capacitor by shorting its terminals. Then pull the plug off the magnetron side and place it near the magnetron socket. Now turn the microwave on and push the connector on the magnetron with a chopstick or a long insulated screwdriver. If no arc when you do this this confirms a bad diode.
please rate my suggestion..
Apr 13, 2009 | Kenmore 62702 Microwave Oven
GE JES636WK 700 Watts Microwave Oven Logo
119 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
