FixYa.com
Tags:
Gateway Emachine Bestec ATX-250-12E PS 250w Replacement Power Supply Part Number P/N 100744  Power Supply
Orange flashing lights
posted by notfol on Mar 18, 2008
Is it a common problem? when a cd got broken into pieces in the cd drive model: GCE-8483B accidentally. I removed the cd compactment, and got rid of the pieces. When the power cable is plugged to power supply unit, which model is "Bestec ATX-250-12E the power on light signal, keep blinking or rather flashing. Holding down the start button do not shut the pc down. The hard disk/hard drive do not start at all either I wonder if the power supply unit gone? Since the operative system do not start. Any help to identify this problem will be much appreciated.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Mar 18, 2008
Helpful (85)
Shazbd
Rank:Wiz Wiz
Rating: 82%, 47 votes
May be the power supply gor affected by the damage because the cd rom busted so better than trying to use the same power supply better get another new one because it may damage the other parts of the computer.......
Rating Locked! (?) notfol has rated this solution as Helpful
Can you Help with these System Power Supplies problems?
power plug replacement compaq...
I can get the keyboard off but... Answer This...
not charging
Gateway laptop Battery pack... Answer This...
acer aspire 5570-2609 recharge...
For some reason my computer... Answer This...
power supply problem
Insperion 510 - Battery will... Answer This...
Loose power port
The power port is very loose... Answer This...
Repair Service
Find System Power Sup. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
