Question about Motorola Talkabout SX700 2-Way Radio
SX700 2-way radio garbled
I have a Motorola SX700 2-way radio with garbled input on one of the units. When someone "calls in it cuts in and out and the communication is basically unintelligible. Typically I know it is receiving messages and can hear the other person talking but I can't make out what they are saying. The problem is the same from several metres to over a kilometre in distance. Any ideas?
Ok sounds like there is a lose connection in the airal or the speaker so it would probably need to be repaired
your best option is to take it to a electronics repair centre near you that specialise in motorola equipment
Posted on Mar 19, 2008
SOURCE:
When my wife and I travel in different cars we like to use the CB. She uses the handheld, I have a CB in my truck. When transmitting I know she is talking but it is all garbled. She hears me fine.
who is transmitting if it is someone else and you are hearing garbled it could be because they are using single side band on their A.M. CB radio .which your radio cannot detect.
https://en.wikipedia.org/wiki/Single-sideband_modulation
Oct 19, 2015 | Midland 75-785 Handheld CB Radio
Sansui 2000x Phone 1 and 2 inputs produce garbled sounds.
I imagine everything is also VERY LOUD.
Only a Phono (old school turntable) should be plugged into the Phono inputs. It contains a preamp for the tiny signal provided by a Phono cartridge, plus is alters the frequency response drastically to compensate for the RIAA curve applied when they cut the record from tape.
Mar 26, 2010 | Audio Players & Recorders
Motorola CLS 1450c radios microphone problem.
The problem you are experiencing is not a mic problem, or the problem would also be associated with the two-way radio portion of the radio. Your radio is either in need of repair or you have a bad, low or defective battery. It takes more energy to transmit or use the unit as a phone than to simply receive.
If your radio is under warranty (less than 1 yr old) you can return it to the place of purchase for warranty replacement or service. After warranty repair is also available through Motorola's factory depot. Ask your local dealer.
Feb 16, 2010 | Motorola CLS 1450CH (4 Channels) 2-Way...
What is the dc input voltage for a 7.5V NTN1171A charger for a MTX838?
The book list the wall adapter to charger NTN1171 as being part number 2580162R01. The description says 13.8VDC 1.5A AC ADAPTER. When googling the part number, it appears someone is selling one on eBay for around $29.99. Retail from Motorola appears to be $125.
Sep 30, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
Garbled transmissions
it's in the software programed in the chip to descramble the signal
Jun 07, 2008 | Radio Shack Pro-96 Scanner
Motorola GM300 Base Station
Pls check your power supply it can cause a garbled audio once the power supply is not regulated or constant voltage so your transmission also is defective,check also the connector it should be tighten,if not do change your microphone for temporary......
May 19, 2008 | Motorola MU21CV (1 Channel) 2-Way Radio
Garbled Sound
may b ur headset has fallen on ground once... may it is the problem with ur cellphone... or may be problem with ur network connection which may b in particular place... check wit these things,,, try others headset and check in ur handset....
Feb 05, 2008 | Motorola Mobility H700 Wireless Headset
Only on/off chimes come through radio
The input source is controlled by contacts in the actual input on the side of the radio. It sounds like the contact for an aux connection is stuck closed. The contacts need to be separated, and probably the only way to do this is to disassemble the radio. If it is under warranty (less than a year old), I would suggest calling SIRIUS warranty for a replacement. If not, and you don't feel comfortable taking the unit apart, find someone who is because the unit is most likely salvageable!
Jan 03, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Garbled Bluetooth
Most likely you're covering the phone's bluetooth radio. Try putting your phone in a shirt pocket closer to your headset. Try it right side up, then upside down. Sometime the bluetooth radio (or antenna) is at the bottom of the phone.
Dec 15, 2007 | Motorola Mobility Bluetooth Hands Free...
Motorola Talkabout  SX700 2-Way Radio Logo
130 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Ekse
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
