OKI C3300 Color Laser Printer
We are have had nothing but trouble with this printer which is only some 9months old. It was OK to begin with but now it does not print from any of our desk top computers.We have tried everything from turning off and then on (worked for a few times then nothing) changing the toners etc without success.
  • 43 Answers
Please check these things:
  • if the machine is connected via a network cable check the machines ip address can be pinged from your pc.
  • if the machine if connected to a pc via usb please disconnect it and connect it to another pc.
  • try to reinstall the driver using the cd supplied.
  • ring your local oki service agent, the machine should have at least a 12 month warranty.
Posted on Jun 01, 2008
Can I reset the belt
How to reset your OKI C3300 C3400 C3600 laser printers ...
? 2:40
https://www.youtube.com/watch?v=czyqKMpy2-E
Oct 6, 2014 - Uploaded by Toner Man
How to reset your OKI C3300 C3400 C3600 laser printers drum unit ... drum message you can install the chip on your drum unit and continue printing. ... Replacing the Transfer Belt on an OkiC3000 Series Printer - Duration: ...
Nov 26, 2015 | OKI C3400n Laser Printer
Oki c3300 amber light blinking
how to reapir samsung c3300 lcd light
Jan 26, 2011 | OKI C3400n Laser Printer
Can't seem to get anything to print everything hooked up OKI c3300
Check to see if the toner is finish and also check to see if the papers are correctly place into the printer.If the paper is not push into the printer properly the printer will not be able to grab the paper and you can also clean the print head on the printer. .
Aug 14, 2010 | Oki Electric Industry C3300n Laser Printer
My oki c3400 printer makes a really loud clicking noise when you first turn printer on and it cycles through, and it also does it when it cycles through printing. Any ideas what the problem could be?
My OKI C3300 was the same and an engineer found the Cyan drum was bouncing on its gears being very stiff to turn. We changed the drum but it was still the same. Changing the cartridge cured the problem, that was jamming the drum.
Mar 10, 2010 | OKI C3400n Laser Printer
It doest't work. I need oki c3300 drivers for window 7
You will need to download the Vista drivers but run the setup with compatability mode for Vista. (right-click -> properties -> compatability)
http://www.c3300.co.uk/index.asp?printername=C3300&menumode=0&content=c3300downloads
Feb 14, 2010 | OKI C3400n Laser Printer
I have an OKI C3400 color laser printer. Can the
The counters reset when you install the new drums. Did you purchase Oki drums or were they after market drums..that could be the problem.
Feb 11, 2010 | OKI C3400n Laser Printer
My oki c3300 laser printer has suddenly started printing pink on blank pages?
Pictures printde on OKI c3300 sudenly coming out very pink. No alterations made to printer or computer settings.
Any isddeas please
Jan 12, 2010 | OKI C5100n Laser Printer
Oki C3300 toner replace, where do I stick the new chip
On the top left hand side of the cartridge, usually where the letter representing the colour of the toner (in your case M for Magenta) appears, there is a small removable section, about 15mm by 20 mm in size. Prise this open with your finger nail or small screwdriver. Remove the old chip and insert the new one in here.
Jul 30, 2009 | OKI C5200n Laser Printer
Oki 3300
When installing the C3300 printer, or when replacing the toner cartridge, be sure to fully insert the toner cartridge into the image drum, and make sure the blue lever is pushed ALL THE WAY toward the back of the printer (fully locked position). If it is not fully closed (locked), a "toner sensor" or "toner empty" message may result.
Mar 28, 2008 | OKI C5200n Laser Printer
Default settings on laser printer
OK here we go You go to the print page find the oki print driver click on properties then under the genral tab click on pinting preferences then under the job options tab all the setting are there.If you want the settings to stay that way you must click on default and then apply. Good Lucky Steveo
Sep 11, 2007 | Office Equipment & Supplies
531 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
