Question about Magic Chef MCB780W Microwave Oven
Mcb780w microwave oven wont stop working
  • bamaknox Jan 24, 2009
    I have a Sharp Carousel that has worked great for over 8 years, but one day it wouldn't stop running the light and fan after it finished cooking. With the door closed, the fan, light and turntable run, but not the magnetron. While it's doing this you can set the timer and other controls and hit start and the magnetron starts and cooks normally, but when the cooking is done, the fan, light and turntable run on continuously. We keep the door open now and only close it to use it. Is this a small problem someone can fix, or will it require replacement of the control board, something that might cost more than a new unit?
  • Magic Chef Master
  • 9,174 Answers
So it's running even with the door open? If not, please reply back with more details. If so, here's my initial answer:
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 31, 2008
SOURCE:
Where can i buy a plate for me my mcb780w microwave.
Repairclinic.com carries a replacement glass tray for your microwave for about $23. Just type in your model number and you will find the tray listed as item 1206615. I hope this helps you.
Dec 15, 2009 | Magic Chef MCB780W Microwave Oven
Microwave won't Work
sounds like a fuse for starters, remove outer cover there will be a white cartridge appx 1"longX1/8"dia this is a ceramic fuse avail at most hardware stores in 15 or 20 amp configurations, if this blows again after repl suspect a faulty H.V. Diode/H.V. Capacitor, or the magnetron tube unless while inside unit you see something obviously wrong 2 fuses are under $5.00
Sep 27, 2009 | Magic Chef MCB780W Microwave Oven
Our Microwave, Jet343g shows display but wont work, also our oven
I am in desparate need of either a GE Jet343G oven with a manufacture date before May of 1989 - or a manual or some documentation that shows this oven was made before than.
Sep 06, 2009 | GE Microwave Ovens
Magic chef mcb780w
MCB780W - May 27, 2017
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open.
You likely have a shorting membrane keypad. MCA's parts site is not showing keypads or controller parts as being available for this model, but they may be.
You can contact them here.
FixYa doesn't notify me when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
[email protected]
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 22, 2017 | Microwave Ovens
Mcb780w won't work
Chances are its the fuse on the circuit board. You will have to remove the outer shell of the unit to access it.
clarkco
Feb 27, 2009 | Magic Chef MCB780W Microwave Oven
Magic chef touch pad doesnt work
I don't have Magic chef, however, I would try hitting cancel, unplugging the microwave and waiting a few minutes, then plugging it back in to reset it. Alternatively, you could go to your manual under troubleshoooting. I wish that I could help you more with this. Good luck to you. Please let me know if you figure this one out.
Jul 31, 2008 | Emerson MW8626W Microwave Oven
Defective microwave
I would definitely contact the manufacturer since most of them have a one year parts & labor warranty and they'll fix it free.
If you have your owner's manual, you can find their number. If not, please reply back with your brand and model number (or brand at least) so we can help you.
Sounds like a bad door switch or relay, and also possibly a bad magnetron or high voltage diode.
May 29, 2008 | Magic Chef MCB780W Microwave Oven
Glass Tray table size?
Visit Magic Chef online and click the Cusomter Service link at the top: http://www.magicchef.com
Apr 03, 2007 | Magic Chef MCB780W Microwave Oven
Magic Chef MCB780W Microwave Oven Logo
207 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
gggg
Gerry Harvey
Gerry Harvey
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
