Thin Grey vertical line
Toshiba model 42LX196 LCD has very light grey fuzzy line from top tobottom in center of screen. Does NOT look like a bad panel as the lineis not as thin and pronounced as a bad panel would be.
Panel is bad you will have to live with it!
Posted on Jul 19, 2008
SOURCE:
Grey vertical line at the bottom of tv screen. 50" Hisense smart tv
The TCON board or the LCD panel is faulty.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 26, 2016 | Hisense Televison & Video
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
My Panasonic smart tv had a thin blue line running down the middle of the screen earlier today. When a tv show was playing the right side of the blue line was fuzzy. Tonight I came home and now when I turn...
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both LCD & Plasma TV screen are given with illustrations. You can get an idea about the fault to an extent.
Mar 28, 2015 | Panasonic Televison & Video
My tv will only display color screens when on
tried with re seat the LVDS cable at the t-com board, it was attached covered with metal shield which transfer signal to the panel display.
Sep 02, 2012 | Toshiba 15LV505 LCD TV
Only top one tenth of screen works. the rest of it is grey.
Screen fault I'm afraid - seen this a fair bit, LCD screen expensive so hopefully you are covered by warranty. If you could find one the lvds pcb which is situated top center on the screen (the one with the drive lead plugged into) can be replaced if you are careful.
Feb 03, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
42 inch toshiba\r\n tv screen
Dark picture. I adjusted brightness, but it keeps getting dark. It has vertical lines that can be seen in grey areas on the screen.
Dec 08, 2010 | Toshiba Regza 42RV535U 42 in. LCD HDTV
Dark vertical lines on tv screen
looks like lcd panel is off.the cost is abit less of anew tv!
Jul 07, 2008 | Televison & Video
Grey vertical line appears on screen
I had the same problem with my Lnt4071f. I called tech support and they said it was a faulty panel and the entire set had to be replaced. If you have your warrantly still use it, if not you may just be able to replace the panel, but its expensive.
Dec 27, 2007 | Disteck P4204TWHD Television
Blank screen except for a vertical grey line through the middle
The horizontal sweep signal to the yoke is bad. Since other problems exist, the problem may be in the IHVT HI voltage transformer area. Check for bad solder around the IHVT pins and yoke plug. I hope this helps. Lee http://www.CrazyComputers.com
Jun 22, 2007 | ViewSonic N2750w 27 in. HD-Ready LCD...
Televison & Video Logo
96 people viewed this question
Top Televison & Video Experts
Ekse
