Question about Sebo Air Belt K2 Bagged Canister Vacuum
Electrical problem I have an electrical problem with the above cleaner. My wife recently extended the power cable by yanking it out of the reeling mechanism too violently. The cleaner stopped there and then. I suspect that the cable has become disconnected inside the cleaner and I would be grateful for information as to how I can mend this problem. Nigel
    President:
  • 1,673 Answers
May have broken the cord, in which case you will probably have to repace the reel cord asm. But you will have to take it apart to find out. Take off the bumper that gores around the cannister, there are 3 or 4 clips that hold the two halfs together.
Posted on Mar 18, 2008
SOURCE:
The cleaner simply won't turn on - tried emptying bag and changing fuse but no response when switched on
Not easy to find without a multimeter .
thermostat circuit protection , carbon brush , broken or faultering slidecontact of the electric field or broken cable reel.
Aug 01, 2016 | Vacuums
Why did the brush roller stop spinning?
With the cleaner unplugged, turn the unit over and look inside the opening where the brush is located. Do you see the clogging of the brush with lots of hair? If so, you will need to disassemble it to remove the hair. In any case, you will probably need to take off the cover to see if there is an obstruction jamming the brush. Also, check to make sure that motor for the brush is getting power. If there is an electrical cable on the outside connecting the brush housing to the rest of the vacuum cleaner, check if it is disconnected. When you have the cleaner on, do the lights glow? Do you hear the motor running? Try the above and report back.
Jul 21, 2015 | Kenmore 31913 Progressive Direct Drive...
Our miele red star(s314i) vacuum was running great and quit suddenly. It had not been running for a very long time and just quit. Newish bag, no clogs in hose and doesn't seem overly hot. the over heated...
Ok, so if the cord test didn't fix the problem, then it sounds like either the plug has gone bad, or the switch. The plug is a very common problem to go bad, and can be caused by just simply yanking the plug out of the wall, or putting too much tension on the cord while you're vacuuming. Here's a link showing how to replace a plug on your Miele. You may purchase a plug at a Home Depot for very cheap. If this doesn't fix your problem, then it is either going to be the entire cord reel assembly that's gone bad, or the switch. The plug is the easiest, cheapest next best option, so hopefully this is your problem. Here's a link on how to change the plug out;
http://electrical.about.com/od/diyprojectsmadeeasy/ss/replacecordplug.htm
Please just use the comment field again if this doesn't fix it, and I'll walk you through step by step the more detailed process of replacing the cord reel.
Jan 17, 2011 | Miele Red Star Bagged Canister Vacuum
I have a Miele silver moon that kept shutting off while using it. I replaced the hose with the new 125-s model but problem came back. It does appear to be a problem with the hose. Any suggestions?
My S558 Red Velvet had the same problem. I disassembled the handle and cleaned the rings and electrical contacts. The problem has not come back.
Sep 28, 2010 | Miele s558 Silver Moon Vacuum
Vacuum is making a burning smell from the motor/fan.
Actually the screws to access the motor on Kenmore canisters are located underneath of the foot pedal that retracts the cord reel, and there's usually also two screws that underneath of the tool lid arms.
You may access the screws underneath of the cord reel by prying the foot pedal off of the vacuum. Simply put a flat head screw driver in between where the foot pedal and the vacuum cleaner meet on the top of the machine, and pry upwards with the screw driver. Once you remove the pedal you'll see the screws and have direct access to the vacuums motor.
If you are trying to access the power nozzle motor, here's a detailed step by step instruction tutorial that will walk you right through it.
http://www.fixya.com/support/t4499227-need_replace_belt_in_kenmore_vacuum
When a vacuum cleaner smells like something is burning, it can only really be one of two things. Either the rubber belt inside of the power nozzle is burning, or the motor is burning. If it's the belt that's burning, it will be a burning rubber type of smell, but if it's the electrical motor, it will be more of an electrical smell.
If you have any further quesitons, please feel free to reply using the clarification request tool here on Fixya. I'm always more then happy to answer any follow up questions.
If this was helpful, please rate my repair by clicking the thumbs up icons in the top right hand corner of this repair.
Thank you,
Chris J.
GoVacuum.com
Apr 11, 2010 | Kenmore 25614 / 25615 Progressive Bagged...
My electrolux O3 carpet power head keeps shorting
If your unit is like ours, there is a electrical short in the wand to Hose connection.. dont use it.. ours unit shorted out and sparks were everywhere.. burned thru the wand to the inside of it and the outside. Good thing my lovely wife wasn't touching that part. electrocution risk was Extreme. PESTER ELECTROLUX, they drag their heels when it comes to admitting and making it right.
Oct 18, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Power to power carpet head
it sounds like the spring on the cord reel let go. difficult to reinstall. it may have been broken already and that is why it came off. it is rather meticulous trying to work on a cord reel. many can't be disassembled without breaking
Aug 09, 2008 | Miele S548 Bagged Canister Vacuum
My miele medivac will not turn on when plugged in
It could be either the switch, the motor, or the cord reel. Try plugging it in and slowly feeding the cord in and out while clicking the power switch on and off. If the motor kicks on while doing this, you have an intermittent short in the cord reel.
If you remove the bag chamber lid, (on the s300 series merely opening it until it makes an awful cracking sound, and then lifting it off;) you will be able to access the screws to remove the rear housing. Under the exhaust filter are two screws that will allow you to remove the control unit, and then there are about five screws on the top that will need to be removed if you need to go further.
The control unit contains the switch, which you can test continuity through by using a VOM. If the switch checks out ok, you can test continuity through the other electrical components on the underside of the control unit. If you find a component that does not have continuity, replace it. If they all appear functional, continue with the disassembly:
On the s300 series it is easiest to flip the machine upside-down after removing the top screws, and then lifting the base away from the top housing. This will give you access to the motor and the cord reel.
What can occasionally happen with these cord reels is that they can wear out, allowing too much lateral slop of the actual reel assembly. You can shim this by using something on the axle in the center to push the reel assembly back against the contacts. I use a small rubber "doughnut," but pretty much anything non-conductive will do the trick.
If this doesn't restore electrical continuity, you'll probably need a new cord reel. I highly recommend against trying to do any further repairs on the cord reel itself, as it's a nightmare to deal with... especially if the main spring comes apart.
Any other problems will have to be referred to a repair station, since it could then be either the motor or the motor control board.
Do NOT attempt to test the motor by directly connecting it to wall voltage, as the actual power applied to the motor when it is functioning is stepped down by the circuits attached to it, and attempting to "hotwire" it will fry the motor.
Hope this helps,
-R
Jul 30, 2008 | Miele Vacuums
Won't Turn On
Mine was a simple fix. Hope yours is too.
You need to take the unit apart to get to the cord reel. If you don't know how to take your unit apart, here are some instructions on how to take apart most of the Miele canister units.
http://www.sannerud.com/house/miele.html
Once it is apart, you will need to take out the cord reel. There is a small rubber hose which needs to be removed on the outermost part of the reel. Then there is one small silver screw that you must remove as well. One these two items have been removed, carefully lift the entire cord reel assembly upwards. When you are doing this, ensure that you are also lifting the black and white wiring along with the reel - just make sure that you're not yanking it and possibly breaking the connectors off. As you lift the entire reel assembly out, you can also remove the white wiring harness which connects to the main switches on the vacuum.
Now, here is the trickiest part - not really that tricky if you are good with your hands.
First, make sure that the cord is retracted fully. Then, start pulling the white plastic cord reel away from the black plastic assembly about 1 inch or so. Between the black assembly and the white reel, you'll notice a copper-like metal spring which is attached to the white reel. Make sure that as you are removing the white reel further, that you are maintaining visibility with the copper-like spring. DO NOT LET THE SPRING OUT OF ITS OWN WHITE REEL (the spring has its own reel which is difficult to wind up again, so be very careful!).
Make sure that the spring is fully retracted at this time. If it is not, wind the reel so that the spring is not wound up anymore around the white reel. Carefully slip the spring out of the white reel and leave the spring as-is ensuring that it does not unwind itself out of its own reel.
Now that you have the white reel off the black assembly, inspect the inside of the inner part of the white reel. You'll see two copper rings with 'wings' on them. These wings transfer power to the vacuum. There may be some grease (black) which you should wipe off with a paper towel. Also wipe the metal rings on the black assembly which touch these 'wings'. (the wings touch the metal rings to send constant power to the motor. The wings are there so that as you wind and unwind the power cord from the vacuum, there is always constant contact with the metal rings on the black assembly.
Now, carefully pull the wings up and out. If you can picture it in your head, what you're doing is ensuring that there is a good contact between the copper wings and the metal rings on the black assembly. Do this for all 4 wings on both the inner and outer copper rings within the white reel. Make sure that the 4 pads are clean and grease/dirt free.
Once you've done this, it's time to put the white reel back on the black assembly. Do everything you did earlier, but in reverse.
Carefully take the copper spring and align it to the white reel - you'll see a specific slot where the spring slides and grabs onto on the white reel. You'll probably have to place the white reel slightly onto the black assembly rod in order to achieve this - again, you must be good with your hands to do this without breaking anything.
Once the copper spring is attached to the white reel, press the rest of the white reel onto the black assembly. HINT: turn the white reel slightly so that you're applying some tension on the spring - this will make sure that the spring doesn't fall out of the white reel.
Reassemble the cord reel assembly (black and white parts) back into the vacuum. Make sure that the black and white power cables are out of the way. Once seated, wrap the black and white cables around the assembly and reseat the white wiring harness. Reapply the black rubber tube to the cord reel assembly and replace the silver screw to hold the entire harness down.
Close the vacuum casing, replace the control panel (power and cord buttons). Close the unit, plug it in, and power it on!
If it worked for you, congrats! If it didn't, sorry, you've got a much bigger problem with your unit.
Dec 23, 2007 | Miele S514 Solaris Turbo Plus Vacuum
Sebo Air Belt K2 Bagged Canister Vacuum Logo
159 people viewed this question
Top Sebo Vacuums Experts
Nick Olsen
Chris Nomland
Chris Nomland
Tom Chichester
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
