Candy AQ1000 Compact Stopped
I have a Candy AQ1000 Compact washer, yesterday the circuit it was attached to in the house tripped out as it started it's cycle and since then it hasn't been working. When I try to start it I can hear the water entering the drum but then nothing else happens. I have then opened the washer and found that the water hasn't drained out and is sitting in the bottom of the drum. I have opened the screw/valve thing at the front bottom right of the machine to let this water out so that it wasn't sitting there but the machine just doesn't seem to want to get into the cycle. Is there anything you could suggest that might be the problem that I can fix?
Thanks,
Mike
  • mikpem Mar 20, 2008
    The machine was manufactured in 2005.
    When you put it on a regular cycle it lets in the water and then stops, that's it, nothing else.
    When you put it on just a spin cycle it turns the drum for about 10 seconds slowly and then stops and drains the water out if there is any in there from the previous attempt.
    So I know that everything is working, pumps, motors etc but it just doesn't seem to want to work for more than 10 seconds at a time before cutting out.
    Cheers
    Mike
  • Anonymous May 11, 2010
    Please give a little more info regarding what the washer will, is, or is not doing when putting it on a cycle. please also give an approx age of machine!
    regards Faggly
    Scholar:
  • 74 Answers
Hiya mikpem... try replacing the brushes in the motor.. the age of the appliance suggests they are about ready along with the symptoms you describe!
Regards Faggly
Posted on Mar 20, 2008
SOURCE:
Start button doesn't work on King Size Washer
Are there any lights on at the washer? If not check the washer circuit breaker in your house main circuit breaker/service panel. If it is tripped reset it and try start button again. If it trips again you need a service call. If there are lights on try turning the washer main knob to off and unplug the washer from the wall outlet...wait 10 seconds then plug in and try start button again.
Mar 16, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
Model is Candy Alise 1200 SE fault is, trips house earth leakage breaker as soon as washer power switched on!
Short circuit on machine Disconnect the heating element located at the back of machine pull off the two wires then try switching on for fault, hope it clears......
Jun 13, 2011 | Candy Washing Machines
Candy trips out house mains power when turned on
Has short circuit some part try disconnecting wires to the Heating element as this is common ,Could also be several other this , process of Elimination to locate this problem .happy new year from Glasgow.
Jan 02, 2011 | Candy CNW136 Front Load Washer/Dryer
Please can you help our washer was working fine. Now when we switch the plug on at the wall iy trips the mains. i have removed the top cover and notced a small cylinder bolted on the back with the mains...
Not familiar with this machine, but what I can say is sounds like your talking about the capacitor that the brown wire is attach, you need to find out why there is water. Capacitors can/are storing charge so there may be danger of electric shock, I short circuit them for safe handling.
Oct 01, 2017 | Candy CBL160 Front Load Washer
Power overload swith in the house has started tripping when the dishwasher is started
Is this happening only now! If it was working OK earlier and tripping now only it may be due to some electrical fault inside the machine.
Switch off all the high power appliances and try the dish washer. If it works you have to check the breaker overall power rating!
If it trips during dish washer ON, the fault could be in the heater circuit of your machine. Heater Insulation would have become weak etc.
May 17, 2010 | Dishwashers
Candy GO1482 washing machine blows house fuse
u have an earth fault on mc caused by damp or water across the neutral check for water on electrical components
Nov 18, 2009 | Washing Machines
My Kenmore Elite front loader has no power.
the power is on but the start button does not start the machine
Jun 29, 2009 | Kenmore Elite 45986 Front Load Washer
Candy Eclipse washing machine blows the circuit breaker
It's possible that the current rating of the MCB is too low to run your washing machine PLUS all the devices plugged into the other sockets on the same circuit. If possible, try plugging in the washing machine on a circuit with fewer or no other appliances plugged in. MCB's are much faster tripping than circuit breakers and are rated to trip at the current rating on them. Circuit breakers, may carry a current slightly over the rated current which may be why it never happened before. The permanent solutions (if the overloaded circuit is the problem) would be to install a circuit solely for the washer and dryer or install a MCB with a higher current rating. The latter solution is not practical, however, since an overload on lower power devices may never reach the current rating of the MCB creating a hazardous shock potential.
May 11, 2009 | Washing Machines
Door lock , wont light up , therefor wont start washing.
Click on "Candy" (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
You can also go to "troubleshooting" above, you are sure to find some solutions. And dont forget to rate me on this great site.
Jan 07, 2008 | Candy CNW136 Front Load Washer/Dryer
Washing Machines Logo
77 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
