Question about KitchenAid KSRA25ILSS Side by Side Refrigerator
Water leaking inside of refrigerator from freezer
Water leaks in from freezer. eventually filling vegetable bins and falling out onto floor. Ice formation near back top shelf and other shelves.
I would like to take refrigerator apart but there does not seem to be access
  • 7 more comments
  • Anonymous Apr 02, 2008
    My Roper refrigerator's freezer drain freezes up and water leaks into the refrigerator below. I have defrosted the ice in the drain line three times in the past 15 months. This task is getting old. I even poured bleach into the drain to help unclog any mildew or other debris that may be clinging to the sides of the drain tube. What is causing this problem to re-occur? The frig is at a lake house is only about half stocked with food. Also it is only opened on weekends. I always turn off the icemaker when we are not there.
  • Missfixit2 Apr 06, 2008
    Each evening I hear growling sounds and then on checking water is almost running down from the middle back of the freezer into the refrig. I mop it up.
    I have a Roper RT21AKXBN00 Recently the frig seemed too cold - yes, items were freezing in frig. So turned the dial from 3 to almost 2. Didn't help the water problem. Both frig and freezer are set back on 3. Can this be fixed with an adjustment or is it bad news?!
  • Michael1001 May 28, 2008
    My old GE freezer is having the same problem. I have changed the setting off from economy, turned the temperature level in the freezer compartment lower, and checked the freezer door for a tight fit.
    Today i found this series of posts, and opened up the fridge to check to defrost drain, but i cant figure whether my freezer compartment has one. The manual claims it never needs defrosting, and I cant find any reference to a defrost drain in the owners manual. Should I expect this old model (TBF 14DAC, bought some time in 1980 by previous owner) to have a defrost drain? If so, any ideas about where in the freezer compartment I should look for it?
  • lg9694 Aug 03, 2008
    Water is accumulating on top shelf and freezes.
    If I lower the temperature I end up with a puddle.
    I don't know where the water comes from.
  • bandhmc Aug 09, 2008
    I am having water condensation in my freezer.  It is coving the top of my freezer.  Any suggestions about what might be wrong with it?
  • ayelovemoney Sep 27, 2008
    I have the same problem I looked up this issue and found others with the samp problem. I think there might be some hose missing the water tray at the bottom of the tray is empy
  • Anonymous Jan 05, 2009
    why is water coming from the freezer to the refrigerator?
  • robert samples May 11, 2010
    whats the brand and model number
  • Anonymous Mar 13, 2014
    food in freezer is frosted over and there's water on inside bottom of refrigerator
The defrost drain is frozen, you need to take the cover off inside the freezer and there will be a drain hole probably coverd with ice, you will need to pop most of the ice out first then I use a turkey baster and a tub of hot water. Squirt the hot water in the hole over and over again untill it drains. Then just wipe everything down. Problem solved.
Posted on Mar 18, 2008
I have a side by side kitchen aide Model # KSRA25FKBL00. The freezer was leaking, we keep finding water on the floor and when you opened the freezer the floor of the freezer was covered with ice. I tried finding a solution online but they all seemed to involve removing parts and I wasn’t conformable doing that. I just had a repair man here.
I spent $125 to have it fixed. It took him less than 5 mins. What he did was chipped the ice away. He took a plastic bottle with a small plastic hose coming out of it, filled with hot water and poured it down the defrost drain at the bottom of the freezer. I don’t think you really would need the tube. There is a defrost drain at the bottom of my freezer that drains into a pan under the fridge. The repair man said it defrosts every 8 hours and drains and sometimes it gets clogged.
I hope someone can save some money with this tip; it was such an easy fix. He tried to block what he was doing, but I stood over his shoulder watching.
Posted on Dec 27, 2008
  • denise a
    denise a May 03, 2014
    I cant THANK YOU enough!!!!! I read your post and everything you described is exactly what was wrong with my freezer. I boiled some hot water for my husband and he poured it straight from the kettle on top of the drain and within a few minutes the ice melted and started draining into the pan below the freezer. Walla!!! You saved me $125. Actually you saved my husband $2500! I was going out to buy a new refer tomorrow. THANK YOU!!!! Denise
Http://www.applianceaid.com/defrost-drain-freezes.php
Get this... I had the same problem, defrosted the drain line several times.
Posted on Jul 30, 2012
My kenmore refrigerator has a sheet of ice under the plastic liner, it was also leaking water into the lower refrigerator. Mine doesn't have a cup, it is just a vent lined with sytrofoam. I determined that freezer drain was plugged up. One man's advice was to disconnect the drain hose behind the refrigerator and use an air compressor to blow through downward into the pan located under the refrigerator. I tried blowing through the other way through the freezer drain. I believe it has worked. The outside of the freezer/refrigerator feels cold now, before it was warm to the touch.
Posted on Mar 04, 2010
How do i removethe back cover on ice mackine on a kitchen aid superba freezer. it keeps leaking water from spout. any ideas
Posted on Jul 25, 2009
The remedy by handybrett was right on. In addition, I would suggest that using a hair dryer to melt the ice in the drain hole works faster then squirting with a turkey baster. I only used the baster to test to make sure the drain was totally unpluged.
Shirley
Posted on Jul 14, 2008
2 Suggested Answers
woodchuck789
  • 4070 Answers
SOURCE: Water leaks in from freezer. eventually filling
Maybe, Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer
Posted on Oct 27, 2009
Ice maker drips water into freezer.Makes ice but doesn't shut off when full.
How to Repair a Refrigerator Ice Maker ' HomeTips
www.hometips.com/repair-fix/freezer-ice-maker.html
Aug 6, 2015 - If the ice maker doesn't make ice but you can see the arm swing intomotion and you hear a ... 4Check the water line that enters the back of the freezer for a blockage. Find the water shut-off valve behind the refrigerator or under the sink, turn it off, ... If your ice maker keeps making ice, even when it is full:.
Refrigerator's Ice Maker Leaking Water ' ThriftyFun
www.thriftyfun.com/tf37813274.tip.html
If your refrigerator ice maker is leaking water, the first step is to locate the source. ... Its not the ice maker - in the floor of the freezer is a small drain that lets the ... I shutthe water supply off but water dispenser still leaks even though no ... My side by side refrigerator leaks water into the ice bin when filling the ice tray with water .
Dec 26, 2015 | Refrigerators
What causes ice build up in bottom of freezer with french doors and then leaks out
sounds to me like a bad door seals causing condensation and leakage
Aug 23, 2014 | Whirlpool Refrigerators
Water pooling under the vegetable bins on the refrigerator floor enough to fill up the cavity and leak out the door onto the kitchen floor. It is Magic Chef CTB1925DR. We have to constantly pull the...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 30, 2011 | Magic Chef CTB1821AR Top Freezer...
I have an 8 year old GE Profile Side by Side TPX24PB Refrig that is leaking water in the freezer, but not the refrigerator. There is a slab of ice on the freezer floor, eventually water runs onto the...
The drain is clogged. Remove the bottom bin out of the freezer. Once done you should see a trough at the back. This trough will be filled with ice, remvoe the ice. Then you have to clear the drain. The best way I know of to do this is to force hot water down the drain with a turkey baser untill water flows freely. Then mix baken soda with water and pour it down the drain. http://www.appliance-repair-it.com/refrigerator-leaking.html
Sep 24, 2010 | GE Profile TPX24PBDCC Side by Side...
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water leaks in from freezer. eventually filling vegetable bins and falling out onto floor. Ice formation near back top shelf and other shelves. Is their a simple fix?
Oct 27, 2009 | KitchenAid KSRA25ILSS Side by Side...
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
IT SEEMS LIKE YOU HAVE A CLOGGED DRAIN . CHECK YOUR CONDECER COILS BEHIND KICK PLATE .. AFTER THAT YOU CAN UNPLUG FRIDGE FOR 24 HRS WITH DOORS OPEN AND SOULD DEFROST ENOUGH TO CLEAR DRAIN . IF NOT . DEPENDING ON MODEL YOU SOULD BE ABLE TO GET THROUGH DRAIN THROUGH MOST FREEZERS .
Feb 03, 2009 | Kenmore Refrigerators
Our Whirlpool top freezer unit is leaking water into the refrigerator. The model number is ET21NKXGW01 and at the top of the inside of the fridge, water is draining out into the fridge. The defrosting...
We were able to fix the freezer water leak. We unscrewed the false freezer floor and the inside back panel. Ice had accumulated on the freezer floor and the defrosting drain was frozen. We removed the ice by using a blow dryer then poured boiling hot water onto the frozen drain hole. The frozen water in the drain pipe hole eventually melted and the water released into the defrosting drip pan at the bottom of the refrigerator. Problem solved. We no longer have water leaking into the refrigerator.
Aug 05, 2008 | Refrigerators
KitchenAid KSRA25ILSS Side by Side Refrigerator Logo
7,914 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
