Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
Fan in the back
Of my sony rear projection TV seems to be getting louder each day... this problem started about 4 days ago... i dusted really good in the back of it and the problem in still occuring... thanks in advance for the help
  • shane mclaughlin Mar 18, 2008
    yes i ordered a replacement fan for $10.31... Now I have to find someone to install it... Is it possible for me to do it or should I just not even take the risk ???
  • Sony Master
  • 8,617 Answers
Sounds like the bearings may be getting bad. That can ccause the same operating to become more noticeable. if it starts to make a growling noise you will need to replace it to prevent any internal damage to the chassis. This will also likely result in premature lamp failure. I would order a replacement fan.
Posted on Mar 18, 2008
My 7-yr-old sony wega keeps restarting; blinks 30 times then video comes back on
Two things here to suggest: one is lamp life is 2000 hours or two years average--and many lamps that fail will either dim just a bit, take a bit longer than did to come up to full brightness and the set may detect that and try to blank the screen.
I am saying a lamp even if lamp light does not come on may be the problem or not.
Second, and I have seen this a lot, the fans in the set intake air in the front of the unit and exhaust it out the rear and no matter how clean the house is dust will get pulled inside.
Fans and air-path's can get coated with dust. Especially the blades on the fans, if a fan slows down just a little because of dust on its blades the set will also detect it as it monitors fan speeds etc.
A good dusting out with compressed air (try not to blow the dust into the screen area) will either confirm this or eliminate it as the problem. I almost always do it in the garage or outside as it may look like a dust storm when you do it.
These are my thoughts and I hope they may help you resolve your problem.
SD TECH
Dec 16, 2012 | Televison & Video
Our tv recently displayed projection lamp was about to go out and needed changed, so i purchased a new lamp assembly and replaced it. tv worked good as new for a few days, then in the middle of watching tv...
Most often, I find when servicing these televisions, the lamp has failed but it was due to poor fan circulation. This television has at least 3 if not 4 fans. If you take off the back and find these fans are filled with impacted dust, the fan may be causing the failure. Also check to be certain your door safety switch is making good contact. These tips should ber of assistance but check your fans. A clean inside of a tv is a happy tv!
Jul 11, 2011 | Sony Grand WEGA KDF55E2000 55" Projection...
I have a sony 52 inch rear projection tv in front panel a red light flashes 5 times and the screen goes black but i still have sound i put a fan behind the tv and now it seems fine no red light no black...
Check the internal fan on the TV. when you turn the set off the fan should still run. Get a couple cans of "dust off". The rear of the set is easy to pop off. Pull the power to the set and let it set for a couple hours, then clean out the back of the set with dust off. the fan comes out easy with 4 screws. clean it off and put it back together. should be ok. If you still have an issue, post a comment and I can help you further.
Jun 14, 2011 | Televison & Video
Had Blinking RED blinking lights. FIXED
CHECK LAMP COVER, CLOSE IT AGAIN THE RIGHT WAY
Feb 21, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
I have a sony 52sony flat screen, and my tv comes on for a little while and then goes out, this goes on all day comes on for about 5min and off for about 1min or longer.
This is a way for the tv to prevent internal failure because it is getting too hot. Make sure your cooling fans are working properly. A can of compressed air works good to clean out the dust if its just dirty.
Jun 04, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Blue cloud
Problem fixed by reading other post with same problem. Unfortunately Sony is not going to fix this problem.
Apr 18, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Humming noise from tv
Yes a humming noise on that model is usually related to the color wheel It will get progressively louder
Jan 17, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Turns on and off green LED flashes until TV turns back on.
this is a symptom of a bad lamp. for some reason it won't spit out a lamp error. shaking up the lamp will sometimes fix temporarily but you will find replacing to be the answer. if your tv has a fan error, you will get 4 red blinks.
Dec 09, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony Grand WEGA KDF-60XS955 60 in. Rear Projection popped and turned off
the reason your lamp blew so quickly is the the lamp fan has become cloged with dust. this is a known problem by sony and I have done 15 or so of the up grades needed. first look at the lamp door is it discolored and warped. if so have a tech order the up grade kit which includes a new door, siraco fan, thermal fuse, and lamp. the return fan may also be needed. also some service menu changes need to be made with the fan voltages of fan 1 and fan2.
Feb 22, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
89 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
