Question about Acer Aspire 5500 5570-2609 Laptop
Can't enter my computer & control panel
When I try to open "my computer or control panel" I get the following message: this file does not have a program associated with it for performing this action. I'm runing windows vista, could anyone help me please with suggestions of what cause that and how to resolve it?
    Guru:
  • 377 Answers
Hi dear
it's mean your had error in win32.dll, causing by trojan or worm
just remove the virus first
oke
Posted on Mar 26, 2008
La impresora 4345mfp se bloquea y nose como hacer la actualizacion del firdware.
Upgrading the firmware
The MFP has remote firmware update (RFU) capability. Use the information in this section to
upgrade the MFP firmware. The overall process involves the following steps:
1 Determine the current level of firmware that is installed on the MFP.
2 Go to the HP Web site and find out whether a firmware update is available. If an update is
available, download the latest firmware to your computer.
3 Transfer the new firmware from your computer to the MFP.
Determining the current level of firmware
To determine the current level of firmware, view the configuration information on the MFP control panel. To view the configuration information, follow these instructions.
1 Press MENU.
2 Touch INFORMATION.
3 Touch PRINT CONFIGURATION. The configuration page prints.
4 The firmware datecode is listed in the section called Device Information. The firmware
datecode has this format: YYYYMMDD XX.XXX.X. The first string of numbers is the date, where
YYYY represents the year, MM represents the month, and DD represents the date. For example, a firmware datecode of that begins with 20040225 represents February 25, 2004.
Downloading the new firmware from the HP Web site
To find the most recent firmware upgrade for the MFP, go to www.hp.com/go/lj4345mfp_software.
This page provides instructions for downloading the new firmware version.
Transferring the new firmware to the MFP
Use one of the following methods to update the firmware.
Using FTP to upgrade the firmware on a network connection
NOTE The MFP can receive an .RFU file update as long as it is in a "ready" state.
The elapsed time for an update depends on the I/O transfer time, as well as the time that it takes for the MFP to reinitialize. The I/O transfer time depends on a number of things, including the speed of the host computer that is sending the update. If the remote firmware update process is interrupted before the firmware is downloaded (while Receiving Upgrade appears on the control-panel display), the firmware file must be sent again. If power is lost during the flash DIMM update (while the Performing Upgrade message appears on the control-panel display), the update is interrupted and the message Resend Upgrade appears (in English only) on the control-panel display. In this case, you must send the upgrade by using the parallel port. Finally, any jobs that are ahead of the RFU job in the queue are completed before the update is processed.
Follow these instructions to perform the upgrade by using FTP.
To upgrade the firmware on a network connection by using FTP
1 Take note of the IP address on the HP Jetdirect page. The HP Jetdirect page is the second page that prints when you print the configuration page.
NOTE Before upgrading the firmware, make sure that the MFP is not in Sleep mode.
Also make sure that any error messages are cleared from the control-panel display.
2 Open an MS-DOS command prompt on your computer.
3 Type: ftp <TCP/IP ADDRESS>. For example, if the TCP/IP address is 192.168.0.90, type ftp
192.168.0.90.
4 Press Enter on the keyboard.
5 When prompted for the user name, press Enter.
6 When prompted for the password, press Enter.
7 Type bin at the command prompt.
8 Press Enter. The message 200 Types set to I, Using binary mode to transfer files appears in
the command window.
9 Type put <filename> where <filename> is the name of the .RFU file that was downloaded
from the Web, including the path. For example, type put C:\LJ\4345FW.RFU, and then press
Enter.
NOTE If the file name or path includes a space, you must enclose the file name or path
in quotation marks. For example, type put "C:\MY DOCUMENTS\LJ\4345FW.RFU"
The following series of messages appears in the command window:
? 200 PORT command successful
? 150 Opening BINARY mode data connection
? 226 Ready
? 226 Processing Job
? 226 Transfer complete
Then, a message that contains the transfer-speed information appears.
10 The download process begins and the firmware is updated on the MFP. This can take
approximately five minutes. Let the process finish without further interaction with the MFP or
computer.
NOTE The MFP automatically turns off and then on again after processing the upgrade.
11 At the command prompt, type: bye to exit the ftp command.
12 At the command prompt, type: exit to return to the Windows interface.
Using MS-DOS commands to upgrade the firmware
To update the firmware by using a network connection, follow these instructions.
1 From a command prompt or in an MS-DOS window, type the following: copy /B <FILENAME>
\\<COMPUTERNAME>\<SHARENAME>, where <FILENAME> is the name of the .RFU file
(including the path), <COMPUTERNAME> is the name of the computer from which the MFP is
being shared, and <SHARENAME> is the MFP share name. For example: C:\>copy /b C:
\9200fW.RFU \\YOUR_SERVER\YOUR_COMPUTER.
in quotation marks. For example, type: C:\>copy /b "C:\MY DOCUMENTS\3500FW.RFU" \\YOUR_SERVER\YOUR_COMPUTER.
2 Press Enter on the keyboard. The control panel shows a message that indicates the progress of the firmware upgrade. At the end of the upgrade process, the control panel shows the Ready
message . The message 1 file(s) copied appears on the computer screen.
Jul 15, 2011 | HP LaserJet 4345mfp Printer
Tip
How to reset DRM (Digital Rights Management) for Windows Media Player 12 in...
These instructions are for Windows 7.
*WARNING*
If you have downloaded songs from protected music services (i.e. Napster, Rhapsody, etc), these instructions will delete the DRM for those files and possibly make them unplayable. Please be sure to back up your DRM by copying the files in step 10 to a safe location prior to deleting them. After following this procedure, You may have to restore music that you downloaded from online services to your computer. Please consult your music services for more information.
Please perform these stepscarefully and note the warning below.
1. Open the 'Control Panel'.
2. Open 'Folder Options' and select the 'View' tab.
3. Select 'Show hidden files and folders'.
4. Uncheck 'Hide protected operating system files'.
5. In the warning message you receive, click 'Yes'.
6. Click 'OK'.
7. Close the Control Panel
8. Click the Start button. In the 'Start Search' box, paste the following:
C:ProgramDataMicrosoftWindowsDRM
9. Press 'Enter'.
10. Make a backup copy of the following 4 files to a separate location such as your desktop or a flash drive.blackbox.bin
drmstore.hds
v3ks.bla
v3ks.sec
11. Delete ONLY the following 4 files from C:ProgramDataMicrosoftWindowsDRM:
blackbox.bin
drmstore.hds
v3ks.bla
v3ks.sec
That will wipe out and reset your existing DRM.
on Mar 18, 2010 | Computers & Internet
Tip
How to detect Viruses easily
I am going to tell you about a trick to detect viruses in your computer. It is simple and fast. Just follow the steps below:
1- Go to start-run-command
2- Write cd.. (notice the tow dots) and press enter write cd.. (again) and press enter
3- Write (cd windows) and press enter
4- Write (cd system32) and press enter
5- Write (setup) and enter
If you get that message
(Please switch to the control panel to install components and systems composition)
Then that means your pc is clean.
The idea here is the (setup) file which is located within (system32) is shut down when your pc infected and open when your pc is not infected because most viruses shut down all system.exe extensions.
I've tried it and it worked!
on Dec 20, 2009 | Computers & Internet
I have XP Home,and for some reason,my volume control icon is missing from my taskbar.When I opened "Sounds and Audio Device Properties",and checked the "place volume icon in the...
Method 1: Add the Volume iconTo add the Volume icon to the notification area of your computer, follow these steps:
  1. Click Start, and then click Run.
  2. Copy and paste or type the following command in the Open box, and then click OK: mmsys.cpl
  3. Click to select the Place volume icon in the taskbar check box.
  4. Click OK.
If the Volume icon is displayed in the notification area of your computer, you are finished. If you cannot add the Volume icon or if you receive an error message when you try to add it, the Sndvol32.exe file might be damaged or missing. Go to method 2. uparrow.gifBack to the top Method 2: Save a new copy of the Sndvol32.exe file on your hard diskIf the Sndvol32.exe file is damaged or missing, you must extract a new copy of the Sndvol32.exe file from the Windows XP CD and save it on your computer's hard disk. PrerequisitesThis method requires you to have your Windows XP installation CD.
Note If you do not have access to the Windows XP CD that contains the installation files, ask the network administrator for help if the computer is at your workplace, or contact Support. To contact Microsoft Support, visit the following Microsoft Web site: http://support.microsoft.com/contactus/ (http://support.microsoft.com/contactus/) To extract a copy of the Sndvol32.exe file from the Windows XP CD and save it on your computer's hard disk, follow these steps:
  1. Insert the Windows XP CD into your computer's CD drive or DVD drive. Press and hold the SHIFT key as you insert the CD to prevent it from starting automatically.
  2. Click Start, and then click Run.
  3. Copy and paste or type the following command in the Open box, and then click OK: cmdThe command prompt opens.
  4. Type the drive letter of the CD drive or DVD drive, type a colon, and then press ENTER. For example, if your computer's CD drive is drive E, type the following, and then press ENTER: e:
  5. Copy and paste or type the following, and then press ENTER: cd i386
  6. Copy and paste or type the following, and then press ENTER: expand sndvol32.ex_ system_root\system32\sndvol32.exeNote system_root is the path and folder name where the Windows system files are located on your computer. This is usually C:\Windows. If the folder that contains the Windows system files on your computer is C:\Windows, type the following, and then press ENTER: expand sndvol32.ex_ c:\windows\system32\sndvol32.exeNote There is a space between "ex_" and "c:\windows" in this command.
  7. Type exit to exit the command prompt, and then press ENTER.
  8. Verify that you can start Volume Control and that the Volume icon is displayed in the notification area (if you selected this option in method 1).
If the Volume icon is displayed in the notification area, you are finished. If the Volume icon is not displayed in the notification area, go to the "Next steps" section.
Resource
http://support.microsoft.com/kb/319095
Jan 26, 2011 | Computers & Internet
When I tried to download javas new update it sent me a message saying windows installer is not opeating properly. I'm running Vista home basic. Can you help
Try to ensure that Windows Installer service is running, or force start it. 1.. Open Run, and type in services.msc then press Enter. Alternatively, go
to Control Panel -> Administrator Tools -> Services.
2.. Locate Windows Installer in the all install services listing.
3.. Verify that the Status is Started. If the Status column is blank,
right click on Windows Installer and select Start.
4.. If you get error trying to force start the Windows Installer service,
try to change the Startup Type to Automatic (default is Manual), and then
restart the computer.
I would suggest you to run SFC scan which would scan for corrupt system files on the computer and replace them.
Steps to perform SFC scan:
1. Click the Start button
2. From the Start Menu, Click All programs followed by Accessories
3. In the Accessories menu, Right Click on the Command Prompt option
4. From the drop down menu that appears, Click on the 'Run as administrator' option
5. If you have the User Account Control (UAC) enabled you will be asked for authorization prior to the command prompt opening. You may simply need to press the Continue button if you are the administrator or insert the administrator password etc.
6. In the Command Prompt window, type: sfc /scannow and then press Enter
7. A message will appear stating that 'the system scan will begin'
8. Be patient because the scan may take some time
9. If any files require replacing SFC will replace them. You may be asked to insert your Vista DVD for this process to continue
10. If everything is okay you should, after the scan, see the following message "Windows resource protection did not find any integrity violations"
11. After the scan has completed, Close the command prompt window restart the computer and check.
Nov 09, 2009 | Microsoft Windows Vista Home Basic Edition
Volume icon in taskbar
You experience one of the following symptoms on a Windows XP-based computer:
* The Volume icon is not displayed in the notification area at the far right of the taskbar.
* When you try to add the volume control icon to the notification area, you receive the following error message: "Windows cannot display the volume control on the taskbar because the Volume Control program has not been installed. To install it use Add/Remove Programs in Control Panel. "
Therefore, you cannot start the Volume Control program and cannot adjust the volume and sound level settings of your computer.
There are two possible causes of this problem:
* The Volume icon has not been added to the notification area of your computer. (The Volume icon is not displayed automatically when you first install Windows XP.)
* The Sndvol32.exe file is damaged or missing.
Solution:
mmsys.cpl
4. Click OK.
Prerequisites
To extract a copy of the Sndvol32.exe file from the Windows XP CD and save it on your computer’s hard disk, follow these steps:
cmd
4. Type the drive letter of the CD drive or DVD drive, type a colon, and then press ENTER. For example, if your computer’s CD drive is drive E, type the following, and then press ENTER:
e:
cd i386
Note: system_root is the path and folder name where the Windows system files are located on your computer. This is usually C:\Windows. If the folder that contains the Windows system files on your computer is C:\Windows, type the following, and then press ENTER:
Hopefully the Volume icon is now displayed in the notification area.
Jul 18, 2009 | Computers & Internet
Write Protected USB
hi Not only your pendirve your computer system is also affected by virus . please check your pendrive with any other computer .before you connected open your pendrive format your pendrive with any other computer. if it will not work you have go for any new pendirve. bye
Jun 16, 2009 | Disney High School Musical Mix Stick 2.0...
Can't open .pdf file email attachments from Windows Mail (Vista)
Send yourself another known working PDF attachment and see if the same thing happens. If it does, post back. If not, then it most likely means there's either a naming issue with the problem PDF, or it is just corrupt enough to give you troubles when opening from email.
Mar 19, 2009 | Microsoft Computers & Internet
Cannot open my computer, laptop model PCGK45.
thats simple ur windows xp is corrupted there is only one thing u can do that is put in the xp dvd and reinstall xp
Dec 17, 2008 | Sony VAIO K45 Notebook
sounds like you are a good candidate for a re installation of your operating system
Mar 18, 2008 | HP Pavilion dv6000z Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
69 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
