Question about Minolta CF2001 Copier
CF2001 w/Fiery X3A and scanner resolution
OK... just bought a used CF2001 prints great. BUT, I can't seem to set the resolution for the scanner. It's set at 150 dpi and I can't figure out where to change it. The scanner menu says enter the resolution on the 10 key pad, but no changes occur. Does anyone know what the issue is here?
Is there a program that came with this printer that allows one to setup the printer from a PC versus the LCD interface on the printer?
What is the service life, in copies, of this printer? Mine has about 115,000 clicks on the counter. It makes beautiful prints.
Thank you for your help.
Kelvin
  • kcaudell Mar 27, 2008
    I figured it out that you have to hit clear before entering a new resolution.
  • Minolta Master
  • 6,696 Answers
How is the scan resolution changed when using the Scan to HDD feature?
Solution
Press the scan button and then press the clear key on the copier control panel. Enter the desired resolution from 1-600 DPI.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Aug 01, 2009
Scanner settings Bizhub Pro C500
The communication can only be complete when the IP Address is fully established. This is in the manual and information on doing a set up is detailed by Minolta. Only you or a technical person with privileges who you invite into your computer can resolve that issue.
Feb 20, 2014 | Konica Minolta Bizhub Pro C500
Where can I find a Fiery unit for my CF2001 minolta copier?
I have a used one - contact me @ advantagecopies@yahoo.com and will discuss
Jan 12, 2010 | Minolta CF2001 Copier
Canon ir C3200 Print Resolution
Print out a Fiery config page ....there may be something in the fiery settings on the actual Fiery box, you'd have to reboot and run setup when it prompts you.
Jul 12, 2009 | Canon Office Equipment & Supplies
Cf2001 will not allow use of copier
I assume you unplug the machine, does it have a internal fiery? have you open and close the front door, Also check user settings.
Jun 22, 2009 | Minolta CF2001 Copier
Xerox DCCS50 to DC12, change Cobra with X12 fiery
at the end of setting up network settings it should ask if you want to save settings, click yes then its enabled. i have never had a fiery that doesnt hold its settings so its probably something you arent pressing.
there is an issue with one of the mac OS's that it just doesnt like the old fiery rips and you will never be able to print, but i'm not that clued up on the mac side and cant remember, sorry.
from your add printer section it should automatically see the x12 and give you the options of a hold,print and direct queue. I f you havent got a pc then the only queues that is useful to you is direct. Print holds the job on the hard drive and will eventually fill the server
Jun 19, 2009 | Xerox DocuColor 12 Printer
CAN'T PRINT FROM FIERY X12E
That happeng to me before, i just low the resolution that fix the problem or flat the image before you send that help too
Mar 18, 2009 | Xerox DocuColor 12 Color Copier
Docucolor 12 no print
if its a print from system to machine do the following
1: check the cables from fiery to machine
2: press clear server in the fiery menu
its not ok
next time mention fiery model
Jan 16, 2009 | Xerox DocuColor 12 Color Copier
First 30 pages of a print run after 24hrs idle are blank
don't upgrade the xp, it runs a limited version to ensure that the command workstation works ok. A reload is probably in order to start again. Any updates can generally be found on the xerox website, and installed via command workstation
Aug 09, 2008 | Xerox DocuColor 12 Color Copier
Scanner
that's a resolution settings issue on the scanner software. Open up the scan manager, and set the resolution at fine or less, not superfine(which works for color photos, etc.)
Feb 05, 2008 | Lexmark X1150 All-In-One InkJet Printer
Printing to an LC031
The mini centronix port is used to update your fiery. You need to set up an IP address, Subnet address, and gateway on the fiery. Then go to WWW.lanier.com, and download the LC031 print driver, or E7000 fiery I believe. You may want to check the fiery model. Then is a matter of installing the driver, and pointing it to the IP address.
Dec 27, 2007 | Office Equipment & Supplies
128 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Marvin
Marvin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
