Question about Electrolux Epic 6500 Vacuum
Continued problem At this point I have hopelessly disassembled the unit and I have no idea how to put it back together I need a diagram or a source to have it done for my. Any ideas?
  • Grapeman Apr 08, 2008
    cord won't rewind
  • BH247 Jun 10, 2008
    I'm curious how you got it diassembled? I have the same model and can't seem to find a screw or clip, nothing, and i don't want to force anything.
Remove the rubber strip from each side. Open to access the bag. Slip a thin srcewdriver between the case and the small strip (that runs the lenght of the case) about 3/8 of an inch in. You should then be able to slip the strip out. Be careful when opening the case; you will need to reassemble it!
Posted on Jul 10, 2008
I need a hose diagram
Hi, it's Ambrai from Crucial Vacuum.
I have inserted a link that will direct you to your ProHeat's User Guide: http://www.bissell.com/assets/0/132/134/228/37c9e5f4-f551-4b35-917f-33c0e7055ea9.pdf
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Ambrai Brown
Crucial Vacuum Customer Care
http://www.crucialvacuum.com
May 13, 2014 | Bissell 9500 ProHeat 2X CleanShot Upright...
Belt Reset Button
please go to the next web page and download your free manual from elextrolux:
http://smallappliances.electroluxusa.com/en-US/Customer-Support/Guides-and-Manuals1/
God bless you
Jul 27, 2012 | Electrolux Vacuums
HOW DO I REASSEMBLE CYCLONE ASSEMBLY DYSON DC11
Dear John,
Thank you for your inquiry. We do not recommend disassembling your cyclone assembly, as a result there is not a diagram available. However, we would like to provide further assistance. Please call us directly at 1-866-693-9766 (US) or 0800 298 0298 (UK). We look forward to speaking with you.
Best wishes,
Jessica
Jul 24, 2012 | Dyson DC11 All Floors Bagless Canister...
Disassebiling the unit body
It is fairly simple to get the unit apart, but putting the unit back together properly does require some mechanical expertise.
The unit is held together by the two side rails or "bumpers". Once these are removed, the unit will split apart in two halves.
  1. Ensure the unit is unplugged.
  2. Open the bag door, and remove the bag.
  3. With the bag door open, peel about one inch or so of the rubber from each of the side rails back
  4. Insert a tiny flat head screwdriver into the T shaped channel the side rail sits in and lightly tap it in about 3/4" or so
  5. Pull the side rail out using a needle nose pliers. Repeat for the other side.
Once you have the side rails removed, your Electrolux 7000 unit is easiest to disassemble and reassemble if laying on its top. Remove the bottom half of the housing first.
Here is a quick video of the disassembly.
I would recommend taking the unit to an Aerus dealer or a local professional repair shop for any major repairs.
Jul 15, 2011 | Electrolux Lux 7000 Bagged Canister Vacuum
The vacuum is hard to manuever; too much suction sound for less suction quality; I've cleaned the unit and replaced the filter. Is it the belt?
Probably it is but vacuum motor and its associate mechanical parts should also be check and clean.
Clean the motor, if suction is still less, then the motor brushes is already wear and need to be replace.
Put back what you disassemble and bring it back together. You must be observant when doing that.
Thanks for asking.
Jul 07, 2011 | Dirt Devil Featherlite Bagless Upright...
Bissell 8920/9500 ProHeat 2X The Floor Cleaner base doesnt spray any liquid. I would take the base apart(and possibly trigger assembly), but the manual does not cover disassembly and assmbly of the tubes...
I just repaired my Bissell 8960 no spray from the base or the flex hose nozzel. Tried to find a diagram or service manual online but no luck. I removed the 2 jets that spray on the brushes and
there was small pieces of silt that would plug them up. only used this unit twice before but it's been
sitting in the basement for a year. anyways ending up takeing the unit all apart. All of the items you
need to get to are in the base not in the handle sections (except of course the spray switch) I put the whole thing on my large work bench to make it easier to work on. If you do take it apart make sure to take alot of pictures or you may not get it back together again. I labeled the hoses with different colored tape and was glad I did.The main problem was the 700 watt heater that is in the very bottom of the base. it was filled with white specs of silt. the heater can be removed and opened up so you can wash it out with a water and a brush. We have city water here thats supposed to be pretty good but know I know why the wife uses distilled water in her iron. Thats what I will be useing from now on in the Bissell..
Apr 05, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
How do I repair my Electrolux Lux 9000 cannister electrical cord retraction? It was pulled out as far as it would go and now it doesn't retract.
First, try standing vacuum on it's back end. Gently pull on cord and release. Try this a few times.
If this doesn't work, you'll need to take it to an authorized Aerus Electrolux store and let the service tech repair it. Although it's relatively easy to disassemble, reassembling correctly is trickier. I've had several machines come into the shop disassembled because the owner couldn't figure out how to put it together again.
Also, when taking the cord rewinder apart, there's a risk of breaking tabs that hold it together.
http://www.aerushome.com/storelocator/
Dec 19, 2010 | Electrolux Lux 5500 Canister Vacuum
Our SteamVac will not release cleaner and water. Everything else appears to be okay. After last use it was rinsed out and left for two weeks at which time it would not work. I would like to obtain a...
click this link directly
http://www.sacreativeservices.com/forum_stuff/steam_vac/
4931375.jpg af5d9a3.jpg The disassembly procedure with photos for this portion of the steam vac is shown in the first image below. This should help you tear down the unit to a point where you can determine the cause of your problem. The wiring diagram is provided in the second image. You may need this diagram to check the wiring if the motor for the brushes is not running. You can view a parts diagram and order parts for the steam vac on the Sears PartsDirect website.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Oct 31, 2009 | Vacuums
TechDrive power assist fell off
See if THIS helps.
Not sure how far you went disassembling the unit so here are a few more useful articles that you may want to see:
How to connect wires
How to get the transmission installed.
Rocky
May 30, 2009 | Kirby G5 Bagged Upright Vacuum
Vacuums Logo
171 people viewed this question
Top Electrolux Vacuums Experts
Marvin
Marvin
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
