Question about Epson Aculaser C1100 Printer
Solution to epson c1100 error message
"WORN PHOTO CONDUCTOR" error message
  • 1,447 Answers
Turn printer off and remove photoconductor unit, close covers and turn printer back on without photoconductor, error will appear that you need to install photoconductor, install photoconductor and wait til it calibrates, if same error appears photoconductor is a consumable part you will have to replace it then.
Pls dnt 4get to rate solution. TY
Posted on Apr 06, 2008
Testimonial: "Good answer"
  • 22 Answers
If your photoconductor unit was printing fine, you don't need to spend $300 on a new unit. Go to ebay and get a replacement computer chip for $20 and it will work just fine. Very easy to install!
Posted on Sep 04, 2009
  • Hammo72 Apr 14, 2010
    You can get a reset chip at
    very easy to install (1 minute) and will save you hundreds!
Epson Aculaser Photoconductor Unit problem !!!!
send it back and get a refund and try another supplier
Jan 30, 2012 | Epson Aculaser C1100 Printer
After changing the black cartridge of epson aculaser c1100, a message flashed: Service Req E511
Welcome to FixYa, the world's largest product support community.
The message E 511: Service Required is commonly due to the Photo Conductor Unit's tabs getting stuck. So the first thing we need to do is to remove the PHoto Conductor Unit. Here are the step to remove the Photo Conductor Unit off of your EPSON Aculaser C1100.
1. Turn the printer on, and open cover B.
2. Raise the yellow lever inside cover B.
3. Remove the photoconductor unit.
4. Check the white tabs on the underside of the photoconductor unit. These are spring-loaded plastic tabs that should depress when you press and release it. If the white tabs no longer spring back you need to replace the photoconductor unit.
After removing or ultimately replacing the photoconductor unit, please follow the step by step giude on how to remove the photoconductor unit in reverse order.
Jun 09, 2011 | Epson Aculaser C1100 Printer
The "Service Req E511" error message means that part of the photoconductor unit called the transfer belt is not being detected. Please see the following Epson article which may help.
Jan 29, 2010 | Epson Aculaser C1100 Printer
Install Photo Conductor
Perhaps, it is necessary to establish the necessary software.
Aug 10, 2009 | Epson Aculaser C1100 Printer
Epson c1100
Probably need a new photoconductor - cheaper to buy a new printer....
Jun 23, 2008 | Epson Aculaser C1100 Printer
What is service code 527
The sensor under the photo conductor unit mounted on the metal bar is out of line and does not detect the dev unit in home position. Usually adjusting the sensor toward the dev fixes the issue.
Jan 07, 2008 | Epson Aculaser C1100 Printer
What is service E524
This means the output value of the ADC sensor is below the required value.
Possible parts that caused the error:
  • Photoconductor Unit
  • Toner Cartridge K
  • Toner Cartridge Y
  • Toner Cartridge M
  • Toner Cartridge C
Head for the ADC Sensor assy first. It's the sensor assembly in the rear door below the fuser unit. Check that it is clean and clear of bits of paper etc.
try a replacement Photo Conductor Unit - even an old worn out one will do, just to see if the error clears. If it does you know your PCU needs replaced.
Much more than this and you will need an engineer to look at it as The High and Low voltage systems are not to be toyed with. Similarly the ROS unit if dead will mean the machine is beyond economical repair.
Oct 05, 2007 | Epson Aculaser C1100 Printer
Epson c1100
Yes, they do make this model, I'm using one now. I had the same problem
The solution for me was to clean inside of printer thoroughly, with the C (or whatever) cartridge removed. The sensors get dirty.
Sep 04, 2007 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer Logo
1,317 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
