Question about LG DVD 6183 DVD Player
Disk not detected
Shows loading for about 2 mins then displays no disc.had this repaired before 3 times with the same problem...but the same problem repeats.
  • _Q3_ Aug 07, 2008
    when i insert the disk after a minute or less it says disk error i tried it many times but it shows the same problem, please i need to solve this problem thanks in advance my email add. ll_badboy2_ll@yahoo.com
Hi, had the same problem myself, turns out (after some investigation) that the motor that spins the dvd wasn't getting power. I carefully pulled out the smaller ribbon cable that goes to the small circuit board beneath the drive caddy, then pushed it back in. Put it back together, turned it on and off it went! Yay!
Posted on May 31, 2008
    Sergeant:
    Champion:
  • 304 Answers
Hello there,
This problem can initially send users into a panic attack, because they naturally tend to assume that the drive must be the source of the problem. But in the vast majority of cases, it's the media that's not working properly. Remove the questionable disc from the drive and pop in another disc, preferably a factory-stamped disc such as an audio CD. If the drive reads the audio CD, you know the drive is working properly and the disc is the problem. The disc may be scratched, or perhaps you accidentally grabbed a blank CD-R instead of the recorded CD-R you meant to use. It happens to everybody.
If you know you're using a readable disc, clearly the drive is the source of the problem. It's possible that the drive's laser has become dirty to the point that it can't read the disc. Open the drive's caddy and spray into the drive with compressed air. The blast of air should blow away any dust buildup over the laser. Pop a disc into the drive and try to read it again.
If your drive still can't read any disc, even after you clean it, the drive may have a serious problem indeed. The drive's motor may not be working properly, or the laser in the read head assembly may be malfunctioning. In either case, it's probably best to simply replace the drive. Drives are so cheap now that replacing a broken drive is a more viable option than fixing it.
Yours truly,
Jack d.
>>>>>>eof
Posted on Mar 18, 2008
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Window shows NO DISK when there is a disk in the unti
If the CD manually loads correctly, the pickup(laser has gone bad) and no longer has enough power left to read the disc the TOC, (table of contents), showing no disc on the display. If you're interested in a repair, please contact me through my website, audioserviceclinic.com. Thank you.
Nov 16, 2013 | Pioneer Audio Players & Recorders
Problem with the Samsung Washing Machines The machine keeps coming up with the message HEI 10x
Here is a list of errors for your machine.
I hope they help you.
SAMSUNG WASHING MACHINES, ERROR FUNCTIONS
When an error occurs, the alarm noise will sound and the error code displayed in the program window. Listed below is a series of error codes you may or may not see for your model of Samsng Washing Machine. The errors are shown as blinking in O.5 second intervals until the error status has cleared. In this case, all the driving devices are turned off until the error is cleared.
1. WATER SUPPLY ERROR - Display shows 4E.
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
2. WATER DRAIN ERROR - Display shows 5E.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
3. OVER-FLOW ERROR - Display shows oE.
Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub is drained for 2 minutes if a frequency of more than 25 KHz is detected.
4. UNBALANCE ERROR - Display shows UE.
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
5. WATER HEATER ERROR - Display shows HE, HE1.
HE, HE1 is displayed if the water temperature rises by 7 C or more in 1 Min or by 2 C or less 20 Min after heating process has started. The error can be cleared by turning POWER switch OFF.
6. WATER PRESSURE SWITCH ERROR - Display shows 1 E.
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
7. ABNORMAL WATER TEMPERATURE ERROR- Display shows cE.
e.g. If the water temperature is 50 C or more, during a Delicate or Wool cycle.
At the time of initial water supply, if the water temperature is not appropriate, the display will show cE. This error can be cleared by POWER SWITCH OFF.
8. WATER LEAKAGE ERROR - Display shows 11 E.
Water Leakage error occurs when the water drains naturally, (by leakage) after the washing program starts.
9. THERMISTOR ERROR - Display shows tE
Nov 21, 2010 | Washing Machines
My Sony vaio came already loaded form Sony, after
go here for a how to:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C1009579&sliceId=1&docTypeID=DT_KNOWLEDGEARTICLES_1_1&dialogID=128698405&stateId=1 0 128704615
Or try this-
  1. Place a blank media disc into the appropriate optical drive.
  2. Click the Start button and in the Search programs and files field, type system repair disc , and then press the Enter key. LoadImage('png60589.png','Block BorderSolid','','','Search programs and files') png60589.png
  3. In the Create a system repair disc window, click the Create disc button. LoadImage('png61020.png','Block BorderSolid','','','Create a system repair disc') png61020.png
    NOTE: In the Drive field, the appropriate optical drive should have been displayed automatically. If your computer has more than one optical drive capable of burning to blank media, you can click the down arrow and then click to select a different drive.
  4. When the Using the system repair disc window appears, remove the disc from the optical drive, follow the on-screen instructions to label the disc appropriately, and then click the Close button.
  5. In the Create a system repair disc window, click the OK button.
Jun 13, 2010 | Sony VAIO PCV-RX500 PC Desktop
Cant play campaign
Halo 3 is buggy disk , I have 2 brand new copys of halo 3 for testing repaired drives
and found that of all the 360 I repair, benq drives will read 99% of the time the hitachi
seem too slow on the seek time to get a
lock/read resulting in a dirty disk error.
Halo 3 does not play on all 360
its just a picky disk .There seem to
be two xboxs thoes that will load halo 3
and thoes that will not.
Sorry this may not be very helpful
Rob
Sep 18, 2009 | Microsoft Halo 3 for Xbox 360
Cant get on.keeps saying operating system not found.ihave windows xp.can you tell me what to do and why its doing that?Thanks
Do you have the original start up disc? If so use it. If not there is generally a button to use at start up that will get you to a screen where you can restore your computer to a previous date. The button is usually F10 or F11 or one of the f keys. Also make sure that you don't have a disk in one of the drives. Take everything out and try starting it up. Good luck.
Jul 30, 2009 | Compaq Presario 700 470024-192 Notebook
Disk Recover message and trays are locked
I have had the same problem. To reset the machine when this happens: 1.Switch off with front panel switch (display dims, but still shows same message). 2. Switch off at mains socket, leave off for about 15 seconds. 3. Switch on at mains socket then front panel - machine should then start up as normal.
I have experienced the "disc recover" condition several times now, when a radio recording has run to the end of a disc, and for some reason the recording process has not terminated properly, resulting in the loss of the recording. I found by trial and error that if you switch the mains off at the socket without first switching off at the front panel, then the disc can become corrupted and useless.
I suspect it is partly dependent on the make of disc as my current batch of TDK RWs do it almost every time, whereas with my last batch (can't remember if they were Maxell or Memorex) seemed much better.
I think the only way to prevent the problem is to manually stop the recording before the end of the disc is reached, I suspect possibly before the 74 minute 'red-book' CD limit is reached, even on an 80 min. disc, though I haven't yet tested that theory properly.
Hope this helps,
HifiJohn
Aug 31, 2008 | Philips CDR796 2-Disc CD Recorder
" unknown disc, check disc" message
3 out of 10 will record 30-40 min and say DISK FULL..
2+ out of 10 I'll record 2- 1 hour shows then I'll
get a " disc unknown " error...
www.govideo.com site NOR customerservice@govideio.com works..
did they go out of business ?
who bought them ? where's the support ?
joe_wht@msn.com
Dec 14, 2006 | GoVideo VR3840 DVD Recorder/VCR
LG DVD 6183 DVD Player Logo
156 people viewed this question
Computer Repairing
Computer Repairing
