Panasonic PT-50LCX63 it's not the bulb this time.
I have a Panasonic PT-50LCX63. The lamp light it flashing reporting the bulb is bad. I have tried two different new bulbs and walked through the steps to reset the timer. Still the TV reports the bulb is bad.
    Genius:
  • 1,175 Answers
I've worked on similar units. If the bulb is good then the ballast that powers the lamp has failed. The ballast is available but around 300-400 US
Posted on Mar 18, 2008
I have a panasonic projection TV, PT-60C13 that will not turn on. Upon pressing the power on button, the button flashes green many times, then flashes red five time then one orange flash. This red/orange...
The most common cause of Panasonic Rear Projection LCD TVs not starting is bulb failure. The PT-60LC13 users manual gives some help in translating the LEDs on the front of the TV.
If the TV worked normally for a period of time (months or years) and won't start, the most likely cause is bulb failure. There is no way to measure the bulb, sometimes the bulb is visibly damaged when it fails. Remove the Lamp Assembly and look at the bulb.
If there was an On-Screen Lamp Replace warning and TV won't start, bulb has failed.
The first step with all Panasonic Rear Projection TV "No Picture" problems is bulb replacement. If that does not remedy the problem, get a technician, there are no user serviceable parts. Guessing if the ballast, power supply, controller board or optical engine is faulty is not practical.
The Panasonic Lamp Gallery shows all Panasonic models and Lamp Numbers. There is also a link to Panasonic DIY bulb and lamp replacement.
easyab
May 05, 2011 | Panasonic PT-60LC13 60" Rear Projection...
Picture on tv went dead. How do I know if it's lamp or ballast or both?
open it on the bulb hatch remove it it will be broken to look at it usually like a normal light bulb would be ballast requires a meter to confirm it needs replaced
Dec 21, 2010 | Panasonic PT-50LCX63 50" Rear Projection...
I have a panasonic PT-50LCX63 and when you turn it on it just flashs green on the on button never turns on
You need to get the bulb replaced. On the left hand side is where you can remove it. Buy a better bulb with the full cage or you will be spending time trying to soder it back in the cage. Bulbs are generally around 100.
Sep 25, 2010 | Panasonic PT-50LCX63 50" Rear Projection...
My Panasonic PT-61LCZ70 keeps shuting off
Most likely problem is bulb failure. Replacing the bulb is first step in any LCD rear Projection troubleshooting.
PT-61LCZ70 has a special "Super Dooper" long life lamp that costs a ton to replace. US users have 5 year warranty on the lamp assembly. Canada users can whistle for help from Panasonic Canada. There is no replacement bulb available, only expensive lamp assembly.
TV has to be completely taken apart to change the lamp. Panasonic service information is 12+ pages for lamp change instruction.
Check Panasonic Lamp Gallery for an image of this lamp assembly.
easyab
Apr 22, 2010 | Panasonic PT-61LCZ70 Television
How to reset lamp meter
I have a PT-50LCX63 unit. After 5 years and 4 bulbs, a "reset lamp" warning showed up every time I turned on the tv. I have to say that after a few weeks, the message ceased on its own. I don't know if all models eventually reset or turn off, but I could not find any other information on the direct way of resetting. I find the warning a waste of time since the bulbs are good for 10 -14 months. Sadly I missed the class action suit that dealt with the premature lamp failures. I am looking for a new tv at this point. Bulbs have cost me $1200.00 since I bought it. The warning is supposed to allow you the option of replacing the lamp before it fails, Ha! what a joke...Thanks for reading.
Dec 29, 2008 | Panasonic PT-50LCX63 50" Rear Projection...
How to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
PT-50LC13/PT-60LC13/PT-50LCX63/
PT-60LCX63/PT-43LCX64/
PT-50LCX64/PT-60LCX64
SPLIT for Models:
PT-43LC14/PT-50LC14/PT-60LC14
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
Aug 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic model# PT-50LC13
It very well could be the ballast. I unfortunately have this tv and keep extra bulbs because they go out about once a year. Last time when I replaced the bulb the tv blinked and the red lamp light flashed like it does when the bulb is bad. Ballast repair kit fixed it up. This is certainly a design issue but you'll get no help from Panasonic. If tv comes on the goes out after a while, clean the fan filter.
Feb 17, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Troubleshooting
We had the same problem and found out that we had to replace the Lamp Bulb. The problem is they try to sell you a whole new compartment house with the bulb, but all you need to buy is the bulb (with wires) itself. It will save you a ton.
Jan 06, 2008 | Panasonic PT-50LCX63 50" Rear Projection...
Televison & Video Logo
348 people viewed this question
Top Televison & Video Experts
Electro Med Services...
