Power supply when i give power to tv fuse is gone .how can i solve this problem
  • Anonymous Aug 12, 2008
    I WILL REPLACE THE REGULATOR OF THE POWER SUPPLY BUT ITS NOT WORKING
    Problem Solver:
Hi i have a f32689 rca tv ctc-197cr1a chasis an it is the power supply which is most commonly the problem with these set's anyways i need the service manual for the power supply in this if you have it i be most greatful
Posted on Apr 26, 2008
  • Joseph Amond Dec 06, 2017
    k no longer have a dinosor for tv i finally upgraded to newer set
    Genius:
  • 1,665 Answers
Hi have a nice day!
Check if new fuse is of same type that is needed ie 2A , 2,5A as manual says. dont put different.
If you put correct fuse and blows then there is a short circuit at power supply area or after it and your TV must take to a qualified repair shop.
If you are familiar with electronic repairs write me down make and model to look for a service manual available.
Posted on Mar 18, 2008
SOURCE:
Logik l22 fed12 stuck in wont come out of standby
sounds like a Power Supply Board gone bad, or an internal fuse could be the problem, (which is an easy easy fix. ) just make sure the unit is UNPLUGGED from the wall socket. If it is a power supply they too are easy to replace also.. be sure and be careful some of those cap. can still store energy and give u quite a jolt. NOTE ,,, take pictures of the inside of the TV,. take close up of the power supply and make sure u get the model # off the power supply board itself. and get an exact match when u order. I usually try Shop JImmy.com first. DO NOT remove the power supply till u have the new one in your hands. that way u won't for get how it hooked up..
Jan 07, 2015 | Televison & Video
I try to turn the tv on but there is no power.
check the incoming power with a tester and if ok then check the plug fuse and if burnt replace and if ok proceed to open the tv cover and check the cable continuityand check the fuse in the power supply region if blown, check other components inthe power supply area and replace the faulty ones if any then open the fuse in the power supply and connect a 100w test lamp to see if there is a short circuit. if the bulb lights up and gets dim gradually you ca now remove the lamp and put backthe fuse and test again
however, your tv problem could be solved by simply replacing a burnt fuse but its always advisable to verify the cause of the blown fuse
Sep 21, 2011 | Sanyo Televison & Video
Fuses keep blowing in tv
The tv have a short in many parts internally in tv power supply board itself could be anythings on the tv power supply board to causes the fuse to blow over and over again.U will never solved it if u don't have all the measuring elecronics equipments and skills and know how to find out.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Aug 11, 2011 | iLO LCT32HA36 Television
Hitachi 42PD7200 Plasma TV gone dead
this problem is from smps power supply of your tv circuit, may be power capacitor may be short , power transister may be short pls check some spair of power supply
Apr 06, 2010 | Hitachi 42HDT79 42 in. Plasma Television
Tv has sound ,no picture,power light comes on
Tihs would be the power supply unit gone bad.
1. Check power supply fuse if the fuse is blow so are the caps do not try to replace the fuse you will smoke this thing.
2. upon inspection you can remove the power supply unit and buy a new one. There about $150 bucks aftermarket for this unit. So I would be looking for other RCA's with this same series and pull some psu's to save money.
I hope this helps you find a solution for your TV these are nice to have and worth the repair.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 21, 2009 | RCA R56WH76 Projection Television
The green light on the two speakers and subwoofer will not power on. The power button is on however ther is no power.
There could be a fuse gone in the plug or in the power supply itself. Try a universal power supply to see does that solve the problem.
May 17, 2009 | Altec Lansing BX1020 Computer Speakers
Can't get power on tv
Is the LED light on? If not then the Power supply may be bad. Try to unplug the TV and then plug back in. There is a fuse near the AC input. Check the fuse If the fuse is OK then the Power supply has gone bad.
Apr 01, 2009 | V, Inc. Vizio P50HD Plasma Television
V172RTNRA 17 in. LCD is strobing.
I solved my problem when I tried using a different Power supply. The Batesias V171RTNRA uses a 12V 4.2Amp positive center post power supply. I discovered that I had a 12V 3.0Amp power supply that had belonged to a hard drive and decided to give it a try.
It worked like a charm. Something had gone bad with the original Power Supply causing strobing in the picture. With the replacement Power Supply it no longer strobes and works perfectly.
I am not sure if it's the lower Amps that solved the problem or not.
Jun 29, 2008 | Batesias V171RTNRA 17 in. LCD Television
Plasma TV
I would check the internal fuses, should be 4, also check the output of the power supply, could be your y block is gone or your power supply.
Regards
What About Bob
Feb 24, 2008 | Televison & Video
Televison & Video Logo
103 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
