Ricoh hq9000 copyprinter drum leaking ink any help would be appreciated
  • Joe4643 Mar 16, 2009
    This Is a constant problem with the Ricoh 9000 Contact Ricoh Direct to get assistance to resolve.
    New Friend:
We have had similar ink leaking problems in the past. We found this company- arico1 . We send our type 90 drums there and they refurbished them. They've been real good to us.
Posted on Apr 21, 2010
SOURCE:
We have a Ricoh Priport HQ9000 which keeps jamming at the paper entry and we are getting a small mark in the middle of the paper
check the rollers well. sometimes they get grime an dust into them and stick or roll rough an hard or not at all. just a touch of spray cleaner works.
Jan 30, 2015 | Ricoh Office Equipment & Supplies
Copyprinter 5375 why does one of my ink drums not work nto accept master
Consult Authorized Service Center or official Helpline of Manufacturer.
Apr 26, 2014 | Gestetner Office Equipment & Supplies
We have a ricoh FW770 that keeps leaving toner on the print, we have to keep cleaning the drum in order to get a good copy
probably you need to change the drum cleaning blade. Its a long silicon rubber stripe that cleans the excessive toner from the drum surface.Also replace the developer units seals to prevent the developer and toner leak.
Hope that helps.
Mar 22, 2011 | Ricoh FW870 Black and White Copier
My copy printer can't show a3 paper . how to fix it?
may i know whats the model of your copyprinter?
use an A3 drum.
check if ur using an A3 drum
Jan 25, 2010 | Gestetner Copier
Sc491 error on ricoh MPC 3500
Sc 491 straight from manual
High voltage power: Drum/ development bias output error
An error signal is detected for 0.2 seconds when charging the drum or
development.
 High voltage leak
 Broken harness
 Defective drum unit or development unit
 Defective high voltage supply unit
1. Check or replace the harness.
2. Replace the drum unit or paper transfer unit.
3. Replace the high voltage supply unit.
Nov 16, 2009 | Ricoh Aficio CL3500N Laser Printer
The getsetner drum was left out over night and now is "dry"
may i know whats you copyprinter model?
do some force in simolation to pump ink on to the drum so that master will stick to the drum
Sep 15, 2009 | Gestetner Copier
Full of black lines on copyprint
it is the problem your copier toner or charger. cherger ir dirty clean it then solve your problem
you install your old cartridge then you quary it
Jul 20, 2009 | Brother DCP 7010 Multifunction Laser...
Savin 9935dpe /ricoh 350 toner waste near full. Where is the
If you can locate the imaging drum unit, the ink is usually stored inside. The imaging drum has a roller with green film over it (this part may not be exposed), which is light sensitive, don't leave it in a bright area for long periods of time, or you may shorten the drum's lifetime.
You'll may have to remove the green roller (is sometimes a dark-blue or black), or some other parts, in order to find a grate. This grate is usually where the ink is dumped, though the design may differ depending on the model. Also, be careful when taking apart your drum, as it is filled with powdered ink, and if you turn it the wrong way, it will spill, and it is very very messy. If you're in an appropriate cleaning area, however, this may be a good way to locate where your ink is stored.
I'm not particularly familiar with Ricoh products, but that is how most laser-printer technology works.
Jun 22, 2009 | Ricoh Office Equipment & Supplies
Black spots and lines on papper
Hello sir; Only thing you need to do is change a drum cartridge.
Jun 03, 2009 | Brother DCP 7010 Multifunction Laser...
Open Questions:
\Q;- XEROX customer support phone {+1'8OO-8O3^1O69} NuMbEr USA .ANITA This XEROX USA phone number[ +18OO-8O3-1069] is ranked #2 out of 2 because 7,728 XEROX USA customers tried our tools and information and gave us feedback after they called. The reason customers call [+I8OO-8O3-1069] is to reach the XEROX USA customer support department for problems like Where to buy, Complaint, customer support, Repairs, Returns. As far as we can tell, XEROX USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. XEROX USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact XEROX USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling XEROX USA Calling XEROX USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our support call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from XEROX USA customer support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with XEROX USA's customer support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare XEROX USA's phone numbers against each other. Contacting XEROX USA in General While [+I8OO-8O3-1O69] is XEROX USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that[+ I8OO-8O3-1O69] is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach XEROX USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact XEROX USA.
Oct 18, 2019 | Xerox Computers & Internet
RICOH customer support phone {\#;-{+1'8OO;8O3^1O69} NuMbEr USA .ANITA This RICOH USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 RICOH USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the RICOH USA customer support department for problems like Where to buy, Complaint, customer support, Repairs, Returns. As far as we can tell, RICOH USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. RICOH USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact RICOH USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling RICOH USA Calling RICOH USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our support call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from RICOH USA customer support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with RICOH USA's customer support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare RICOH USA's phone numbers against each other. Contacting RICOH USA in General While I8OO8O31O69 is RICOH USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach RICOH USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact RICOH USA.
Oct 18, 2019 | Ricoh Computers & Internet
KYOCERA customer support phone {\#;-{+1'8OO;8O3^1O69} NuMbEr USA .ANITA This KYOCERA USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 KYOCERA USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the KYOCERA USA customer support department for problems like Where to buy, Complaint, customer support, Repairs, Returns. As far as we can tell, KYOCERA USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. KYOCERA USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact KYOCERA USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling KYOCERA USA Calling KYOCERA USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our support call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from KYOCERA USA customer support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with KYOCERA USA's customer support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare KYOCERA USA's phone numbers against each other. Contacting KYOCERA USA in General While I8OO8O31O69 is KYOCERA USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach KYOCERA USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact KYOCERA USA.
Oct 18, 2019 | Kyocera Computers & Internet
Computers & Internet Logo
190 people viewed this question
Ekse
Alun Cox
