Question about Zyxel Prestige 660H Router
How to configure in point-to-point
How to configure point-to-point in zyxel p-202h plus v2
subject:
one of my customer have one isdn line in his main office and other one of his branch office one isdn line and i want to connect point-to-point connectivity her two offices pls give me solution about this problem and give me an example also.
    Master:
  • 351 Answers
Dear,
To connect both offices you have to create a VPN between both end's so that you can make a safe data tunnel between these two office. for this you have to static IP's on both ends and a Third party VPN client software.
for more details you can mail me i'll provide you all the details for how to create a safe VPN between two points.
Cheerup
Posted on Mar 18, 2008
6ya staff
SOURCE:
I want to connect Hughes HT1100 modem (satelital) to my Zyxel wireless router (P-660HW T1 v2). I need the configuration for the Zyxel
Type 192.168.1.1 or 192.168.0.1 if the first one doesn't work. You can to Zycel's website to get information on the various settings that will apply to your application.
Dec 13, 2016 | Zyxel Computers & Internet
I need to access CCTV over internet.I am using Zyxel router (model P600R T1 v2) which having a static WAN IP provided by ISP.Can please guide me on the steps.Thanks.
first you need to forward TCP ports in your router pls write down which TCP ports used for video , audio and control in your DVR and configure to forward this tcp ports in your router
it can be do one step using disable the DMZ and it will make less sequrity in your internal network
Apr 11, 2013 | Zyxel Prestige 660HW Wireless Router...
We have been using the zyxel G 4100 v2 for 3 years. Last week we found out that we could no longer use our web based password to monitor our accounts. Did someone hack our system. How can we recover our...
Just reset it! At the back of the router is a small hole with th word "RESET".With a toothpick or some like press gently for 30 seconds and wait for the router to start up again.Log in to http://192.xxx.xxx and start a new configuration.
Jan 01, 2011 | Zyxel G-4100 v2 WirelessHot-Spot Gateway -...
Two access points don't work
1. check the distances of the access points.
If over 300 hundred feet you will loose.
2. check the main router to verify access points are configured in it.
Apr 19, 2010 | Zyxel Prestige 600WH Wireless Router...
Zyxel model G-220 v2 usb wireless adapter won't connect
If you are trying to connect a computer wireless card to a wireless router then follow my instruction on how to configure the wireless router and the wireless card in the computer - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 14, 2009 | Zyxel Computers & Internet
Still cant solve it.
The default address to get to the web interface is 192.168.1.1
The default password is 1234 (No username required)
If that doesn't work, you can restore it to the factory default by pressing the reset button on the back and holding it in for 10 seconds. Be aware that doing this will erase all existing configuration information.
Here's a link to the quick start guide:
ftp://ftp.zyxel.com/P-320W/quick_start_guide/P-320W_1.pdf
Here's a link to the Users Guide:
ftp://ftp.zyxel.com/P-320W/user_guide/P-320W_1.pdf
Jun 27, 2009 | Zyxel Prestige 320W Wireless Firewall...
P320w v2. cant configure
The user manual has the default username and password. if you didn't get a paper manual, check the cd, the manual may be on the cd in a manual folder.
Do you have a zyxel series p600, 660R-D1 dsl modem user manual? I have one and have a range of kbps of 3050 to 240 kblps. I thought I would read and see what to expect, Earthlink and the phone company...
The user manual or user guide of the 660R-D1 is available on the zyxel.com site, if you go into the following path:
Support and downloads --> download library ---> up at the right hand side top you see a drop down menu with list of products, choose 660R Compact series. This brings you to the download page and you can choose out
Model :
P-660R-D1
Version : 3.40
Language : English
OS : N/A
Release Date : 07-14-2006
Citating the part from the manual that I think is important (see down at the bottom of this post the speeds, and the note that it may be influenced by your ISP standard. Ask your ISP what they use.):
1.1
The ZyXEL Device is an ADSL2+ gateway that allows super-fast internet access over analog (POTS) or digital (ISDN) telephone lines (depending on your model).
In the ZyXEL Device product name, "R" denotes an integrated router and "D" denotes a chip set standard.
Your ZyXEL Device product name ends with a number. Models ending in "1", for example P660R-D1, a denote a device that works over the analog telephone system, POTS (plain old telephone service). Models ending in "3" denote a device that works over ISDN (Integrated Services Digital Network). Models ending in "7" denote a device that works over T-ISDN (UR-2)
1.2
The DSL RJ-11 (ADSL over POTS models) or RJ-45 (ADSL over ISDN models) connects to your ADSL-enabled telephone line. The ZyXEL Device is compatible with the ADSL/ADSL2/ADSL2+ standards. Maximum data rates attainable for each standard are shown in the next table:
ADSL:
Up: 832 kbps Down: 8Mbps
ADSL2:
Up: 3,5Mpbs Down: 12Mpbs
ADSL2+:
Up: 3,5Mbps Down: 24Mbps
Note: if your ZyXEL Device does not support Annex M, the max ADSL2/2+ upstream data rate is 1,2Mbps.
ZyXEL Devices which work over ISDN do not support Annex M. The standard your ISP supports determines the maximum upstream and downstream speeds attainable. Actual speeds attained also depend on the distance from your ISP, line quality etc.
Please let me know if the above answered your question:)
Jan 26, 2009 | Computers & Internet
Configuring of ISDN Router
you can telnet by going to Start, run, type "telnet 192.168.1.1" hit enter a black window will open and your in the router. Youl have to call your ISP for the propper settings.
Aug 29, 2007 | Microsoft Office Outlook 2003 for PC
Zyxel Prestige 660H Router Logo
205 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Ekse
Pamela Bates
Pamela Bates
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
