the use of liquid detergents is recommended over powders in washing machines as they do leave a mud build up over time in the bottom of the wash bowl
no they do have to be dissolved before use
spin speeds are set in the machine program and cannot be altered
spin time is set in the machine program and cannot be altered
use the recommended detergents for the machine because if you use top loader detergent in a front loader it will froth up excessively and cause problems for a front loader machine
the suitability of use for the detergent ( powder or liquid) is clearly marked on the labelling on the bottle or packet
any brand that states specifically for front loader machines. From experience I would prefer to use liquid detergents specific for front loaders as there are less harmful products that rot and corrode parts in the machine.
I want you to run an empty load, pour 3-4 cups of white vinager into the soap dispencer, this will flush out detergent buildup, it sounds like the unit has a buildup of soap and is oversudsing, the vinager wash will stop it from happening, if this stops the problem cut the amount of soap you are using in 1/2. If it does not let me know, good luck
I don't know how you are administering the soap powder to the machine..but for one, its recommended that you use detergent thats made exclusively for the front loader washer, usually says "he" on the front of the LIQUID detergent, they recommend that you use liquid detergent on top of that, BUT if you have to use regular powder detergent it must be put inside the tub and NOT the pull out detergent drawer. The reason why they want you to use liquid is because the powder detergent is not concentrated and when you use it, it lathers up alot and its harder for the front loader machine to clean out the clothes and I was told that they (sales agents) have heard of soap suds and bubble floods coming from the machine due to either using the powder detergent or using too much. Hope that this helps!!
Pull the drawer out you will find detergent has built up in side the dispenser probably from from way too much detergent, modern front loaders work best with a small amount of detergent and liquid detergent normally will wash better.
Hi. Yes, it sounds like the internal workings are blocked. Try pouring Hot - NOT BOILING! water into the drawer whilst the drawer is open, you may need to do this a few times! Persevere, it will eventually clear it if this is the problem. Then put the machine through a hot wash cycle, as hot a program as it has. Using the cooler wash programs is a good idea, but it does lead to a build up of Body Fats (Ugh!) and old detergent. A good really hot wash occasionally will flush and prevent this build up in the machine's internal workings and prevent a very expensive call-out charge. Once every three months or so will do the trick!. In future you may want to try using a liquid detergent, it will help to avoid the problem.....Good luck........Let me know if it works?......Cornwellnet (UK)
Yes! any kind of liquid soap is ok for your front loader. HE soaps are just a little better in the front loaders so yes you can still use your liquid soap.
I was searching the net looking for the same answer - have just bought an LG front loader but wasn't certain I should be using liquid detergent - my manual refers to powder without telling you specifically to use it only. Look at the answers to the question after yours on the Fixya website "LG washer has awful mildew odour" or something similar. Solution 3 by Tresilla convinced me I should use powder! Also, the salesman who sold me the machine recommended powder because, quote, " gentler on clothes and more efficient ..." - he didn't mention the possibility of a later mildew odour which is apparently generic to front loaders!
i just placed my order @ home depot for the LG TROMM front loader washer. i purchessed the 5 yr warrenty and i belive after reading some of the comments in here that this was a good move. I used a maytag neptune @ work and it was a peice of JUNK! it has the mildue smell everyone is talking about. i was told of a remidy for this smelly issue. pour a good amount of casscade dishwasher POWDER not liquid into the washer drum and then pour bleach into the wash slot on the fron loader and then put the washer on the longest setting and let the machine run the cycle. i hope this works for you. i will try it once a month om my front laoder when its delivered. GOOD LUCK!!!!
