Lamp what if u just put a new bulb in it and it still wont light
  • WVLibrarian Mar 24, 2008
    I have two Viewsonic PJ501 projectors with the same problem. When the power is turned on, the "lamp" light is red and the lamp will not come on. I have replaced the lamp in both projectors, but still have the same outcome. When I check the lamps, they do not appear to be "burned out."
  • DUB7 Sep 06, 2008
    I have a Panasonic PT-LB10E projector that has had the bulb replaced but now shows a flashing red "lamp" light & will not come on.
    The fan is running but nothing from the bulb.
I have just installed a new lamp in my lcd hitachi projector an it will not light up an work,can you help me to solve this problem.
Posted on Jan 02, 2009
  • Anonymous Jan 02, 2009
    i just installed a new lamp in my lcd hitachi projector an it will not light up an work,can you help me to solve this problem.
  • 563 Answers
Hi there
This could be a faulty Ballastboard ( Lamp's Power Supply )
I get this sort of problem all the time and it normally solves the problem by replacing the ballast if the lamp still won't strike after replacement.
Posted on Mar 26, 2008
SOURCE:
Wont light or turn on
1,whether the lamp is ok? -put this lamp to another projector to check it
2,whether the lamp ballast is ok ?
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: [email protected]
http://www.lampdeng.com
Feb 26, 2014 | NEC Vt 695 Home Theater Projector 220 Lamp...
I put a new bulb in my jvc tv and it still blinks red why
take it out and put it back in it may have been put in wrong or something
Apr 05, 2013 | JVC HD-52G886 52" Rear Projection HDTV
Put new bulb in it wont strike, put old bulb back in (worked before0 and it wont strike WTF
Make sure the lamp connector in the projector has not been pushed in as I have seen this happen on a couple of LP540 and LP640 projectors.
If the connector is pushed in the connector on the lamp will not make contact and strike the lamp.
Jan 27, 2013 | InFocus LP640 Multimedia Projector
JUST PUT NEW BULB IN A TOSHIBA TDP-S20 ON 2/18/11 . BOUGHT PROJECTOR IN 2004 USED UNTIL THE BULB HRS RAN OUT . BULB NEVER BROKE / BURST. ON START UP WITH THE NEW BULB IN MACHINE BOTH FAN AND LAMP LIGHTS...
Your new bulb is not lighting.
Check the connections are correct.
Have you also tried putting back old bulb to see if it works.
Please dont forget to vote this answer was helpful
Many thanks
Feb 18, 2011 | Toshiba TDP-S20U Multimedia Projector
I had a bulb burn replaced both bulbs worked for a couple of days but now it wont power up only lamp1 light blinking. I have tried taking bulbs out and putting them back in still nothing, also the lamp...
the lamp units should be properly aligned with the 2 very tiny switches
between them. If not lamp led will blink.
If lamp led is continuously on, lamp timer has to be reset, according instructions that come with new units.
Original lamp modules are AH-45001 and AH-45002, two different
units needen for 1 projector, reset procedure is different for each lamp !!
Dec 21, 2010 | Eiki EIP-4500 DLP Projector Multimedia...
Light does not work
1. remove power then look to see that the bulb socket bottom pin touches the bottom of the lamp; if it does not use a pen tip to bend it back up.
2. check or, replace the door lamp switch
Apr 07, 2010 | Frigidaire FRS26R4A Side by Side...
Lamp went out, ordered new bulb and put in but TV did not come back on but the bulb light keeps flashing light orange. Sent new bulb back just in case it was faulty & ordered another 1. I just received...
Make sure lamp cover is put back in its position properly after bulb replacement.
If I have info about model and brand of your TV then I might offer better help to fix it.
Jan 15, 2010 | Televison & Video
Front main light wont work when new blub fitted v reg fiesta
First ensure that power is getting to the bulb connection behind the headlight. You can use a 12v test light to do this or use a known good bulb. If no power to the bulb connector, check the fuse panel on the lower left of the dash and look for the fuse for the headlight lamps and replace if necessary.
Sep 02, 2009 | 1993 Ford Festiva
Epson ELP-3300 powers up bulb light is green but stays on stand by
Hi djSilver
Try resetting the lamp timer.
This normally solves this problem.
Apr 22, 2008 | Office Equipment & Supplies
Samsung HLM507W Blink Lights
beings the connectors were different on the new bulb the spark gap maybe different also if it is the lamp wont work in that unit
Apr 12, 2008 | Televison & Video
625 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
