Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Belt replacement on hotpoint wma63 washer
Trying to refit belt on spiner
    Problem Solver:
  • 10 Answers
Start by taking a bag tie and bag tie the belt to the drum pulley, hook the other end of the belt to the motor pulley, turn the drum from the top and the belt will be pulled on, once on, cut bag tie off and away you go. other wise hotpoint do supply a special tool that is along piece of hollow tube with a stopper on one end, that hooks onto the motor pulley.
The bag tie method does work, but be careful you don't your arms when you work from the top.
Posted on Mar 19, 2008
Hotpoint wma63 fabric conditioner not draining from the drawer during wash cycles. I've tried a 'service wash' @ 95deg to clean the machine. I've also checked the detergent/conditioner...
Hotpoint wma63 fabric conditioner not draining from the drawer during wash cycles This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jul 02, 2011 | Hotpoint Washing Machines
Hi my hotpoint wma63 fills with water for a wash, then empties
motor tacho not being sensored...motor or pcb fault...chopper board faulty bottom front right in machine.
Jul 31, 2010 | Hotpoint Washing Machines
Where are the filters on a Hotpoint Ultima WMA63?
The filter is located at the rear of washer.
Remove lower rear panel of washer.
Remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage and or obstruction here as well.
Please leave feedback for my solution.
Thankyou.
Jan 12, 2010 | Washing Machines
Refit belt
There is provision made for tensioning the belt.
It is self tensioning.
Remove top cover and rear panel.
With the washer tilted away from you,(get someone to hold it for you)Fit the belt round the motor pulley first, then slowly feed it round the drum pulley, turning the pulley at the same time, watch your fingers as it will be very tight, and just keep going until the belt is on, if it slides off, just start again.
Good luck.
Dec 13, 2009 | Hotpoint WMA35 Front Load Washer
Cant find filter to clean. not at the front bottom as usual. wma63 hotpoint. thanks
Remove lower panel at rear of washer, locate and remove large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Please rate my solution.
Thanks.
Oct 29, 2009 | Washing Machines
Drive belt came off spindle on Hotpoint First Edition Washing Machine.Have tried to replace but back of machine does not remove, just a small access hole. How can I refit a new belt please??? John Bennett...
Remove rear panel, remove top cover,.tilt washer forwards, get someone to hold it for you, and fit belt round motor pulley first, then start feeding it round drum pulley, easing drum round at same time, it will be tight, so watch you fingers,
Thanks.
Sep 13, 2009 | Hotpoint First Edition FEW12 Front Load...
Checking for items in 'sump' of Hotpoint WMA63
hi you need to pull the washer out. tip it up and at the bottom ov the drum there is a black pipe from your drum to the pump its big on the drum and sall end is your pump end take it off at the drum end and look in there if not try takeing your pump off not that hard to due hope you find it stuart
Jun 24, 2009 | Washing Machines
REFITTING THE BELT ON HOTPOINT WMA 40
Place it on the motor pulley and then guide it around the drum pulley. It will have come off for a reason which if you do not correct will cause it to come off again. Lay it flat on a table - if it does not lay flat - replace it. Check the pulley on the drum does not move from side to side. (problem with pulley or drum bearings)
Sep 03, 2008 | Hotpoint WMA40 Front Load Washer
Trying to fit new belt
loop round the motor first then up around the pulley, this will be tight so pull halfway round and hold it to the pulley while turning it, rather like refitting a bicycle chain. make sure it runs cetrally on the pulley by adjusting it on the motor shafts grooves.
Aug 27, 2008 | Hotpoint Aquarius WF220 Front Load Washer
Fitting new brushes on a hotpoint washing machine
Remove lower rear panel.remove drive belt, undo screws that secure motor. unplug motor lead, noting which way it is fitted.,lever motor back and remove, replace brushes and refit motor and belt.
Mar 30, 2008 | Hotpoint First Edition FEW10P Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
1,583 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
