Question about Nokia 3230
Memory card locked
I just restored factory settings and now I cannot have access to my memory card. Previously it never asked me for a code to have access to the memory card and I don't remember putting any code for access to the memory card
Disply no light 3230
Posted on Apr 18, 2008
    President:
  • 1,017 Answers
The default security code for Nokia is 12345.
You can recover the password. Although if you reset your phone you probably won't be able to recover the old security code. Anyway this is how it's done.
The best way is to download a file manager to your phone. I use Best Fileman for my N70, from http://www.smartphoneware.com/ It's for series 60and 40. The trial version should be enough, it's only £5.60 anyway.
In the file manager (when installed on your phone) you'll find under- C:\System\mmcstore -the file you're looking for, you have to rename the file- mmcstore.txt -then send it to another mobile (best way) or your PC via bluetooth or USB, open it on the other phone and your password will be revealed.
Rename that file- mmcstore.txt -to just- mmcstore -there might be another file named- mmcstore.txt -to view your password rename one or the other- mmcstore1.txt -one is for your phone PIN number the other your MMC card.
Clear enough?
Posted on Mar 25, 2008
6ya staff
SOURCE:
What is a problem when My Phone does not displaying the keypads when im trying to type sms or mms
Software of your phone is corrupted. easiest way out is to factory restore your phone....BUT THIS WILL EREASE ALLL USER DATA INCLUDING PHONE BOOK ENTRIES STORED IN THE PHONE MEMORY....However sim and memory card data will not be effected.........to do this...go to settings and select restore factory settings/full factory restore...ur phone will ask for security code....for code refer user manual..or enter code that u have previously changed.......if this fails then switch off phone,....remove battery....reinsert battery....press volume up,and Power button for about 15 seconds.........till boot mode appears and u get some text written on screen....using volume up key scroll thru the text and select erase all user data/restore....now press power button for about 2-3 seconds......process begins........restart phone.......this should solve the problem...........but if still problem persists then u will have to visit a service person who will flash ur set using special tool loke...volcano box.
May 20, 2014 | HTC Hero Smartphone
Micromax master resetting code all
1.NormalReset - Dial *#7780#
If you dial this code in Nokia handset, it will restore system setting without missing phone memory data (videos, photos, songs).
2. .Deep Reset - Dial *#7370#
When this code isdialed in Nokia handset, it will wholly clean internal phone memory. Entire phone settings and profiles will be deleted, but there is no effect on memory card data.
Remarks -
For Nokia Symbian 60 V1 supported mobile handset (7650, 3650, 3600, 3620, 3660, N-Gage)
you can dial *#7780#*#7370#
Latest S60 mobile handsets, you can dial Deep Reset through another way.
*.Switch off mobile handset first.
*.Press calling key (green), 3 and * keys or (Green calling button + 3 + *)at same time and grip them down.
*.You find a message about format mobile and then release these keys.
*. Password of Reset factory setting code will be either 1234 or 12345.
Nokia X3-02 mobile Restorefactory -
*.Go to Nokia menu lists, browse these options one by one-
*.Menu --settings-- Menu--- Restore Factory Setting
*.Insert phone code 12345and wait few moments to complete restore process.
Nokia 5230, 5800, 5233 and similar mobile handset Restore factory settings, how ?
*.Browse phone menu lists,
*.Then, go to
Menu - Settings - Phone -- Phone mgmt Factory settings
*.Insert security code -12345
*.Without data lost of internal memory, Nokia handset returns in original modes.
Hard reset of Latest Nokiahandset through another code -
*.Switch off mobile handset.
*.press and holdGreen (calling) +Red (End call button) + Camerakeys at the same time along with switch on power of mobile handset.
*.Then mobile asks to insert phone security lock code , so insert12345.
Samsung Restore factory code
*.*2767*3855#
*.*7465625*638*00000000*00000000#
*.#7465625*638*00000000#
or
*.Remove SIM card from mobile handset
*.Once off and on handset
*.Type *2767*2878# to perform internal memory reset
*.Insert SIM card again in mobile.
Samsung Androidsupport handset restore factory code -
Type*#*#7780#*#* - To Factory Restore.
Micromax Restore factory code for all version with Android -
You can use any following below code one by one to perform restore factory of Micromax mobile:
*.1122
*.0000
*.1234
=*symphony> 1122
=*nokia >5071 or 0000
=*micromax> 1234
=*tecno > 1234 or 0000
=*samsung> 1234
=*apale i phone >5869
BACK2HOME
Information from:
http://peperonity.com/sites/a--a.secret.mobile.codes/47096442
Terry
Apr 16, 2014 | Samsung Computers & Internet
I have forgoten my security code for my nokia e71. And i want to restore to fatory settings. the imei no. is 352925021952314
Hello
You can try to do a hard reset to restore it back to factory settings. All your contacts, messages, calls, applications, themes > everything will be gone. So BEWARE. Backup your important stuff first. Your memory card will be fine, so anything there will be saved. However, if you have applications installed on the memory card, I recommend deleted those as well.
I always tell people to install applications and themes on the phone memory always! Your phone will run faster, as will the applications. Leave the memory card for your media.
Anyways, to perform a hard reset on the Nokia E71 you do this...
Type *#7370# from the standby screen while your phone is on. It will ask for the lock code which is 12345 unless you have previously changed it. Make sure you do this right, because if you do it too many times the wrong way you can lock up your phone.
And that's it. Have fun re-installing all of your applications and themes. Hopefully this helps you out if your having problems, or if you just want to clean out your phone.
Hope this helps.
Jan 25, 2011 | Nokia E71 Smartphone
My nokia x3 memory is almost full .how to format the phone memory
First remove the memory card...located at the left side of your phone. After removing your memory card, Go to your phone's menu, then select the settings then find the Restore Factory Settings, then there are two option restore settings only and restore all, select the restore all then your phone will ask for a code, the default code is 1234, if you have your own code then enter your code, after that select OK then your phone will restore to its original settings. but be sure to back up you contacts. Goodluck.
Sep 22, 2010 | Nokia X3 Cell Phone
How to unlock memory card password in Nokia 5310 expressmucis
to unlock memory card insert memory card in ngage mobile and format the memory card
recovery of memory card is not possible
Sep 13, 2010 | Nokia 5310 Cellular Phone
Once I changed my sim with another phone memory has got locked automatically. now it's asking for a security code and cannot access contacts in the phone memory
you should chek out your restore factory settings.create the backup of yuor contacts and then access the contacts easily
Feb 26, 2010 | Nokia 6300 Cellular Phone
I have nokia 5610 xpress music , today i did restore factory settings of handset and fount out that my mmc card has been locked automatically, i did try the default 12345 as password but it did not work......
If you forget your memory card password, there is nothing either you or a service point can do. It is not possible to read the password from the memory card or from the device. Passwords cannot be disabled.
When you lock your memory card with a password, your device will remember it. Therefore, the device does not have to ask for the password every time you access the memory card. However, when you insert your memory card to another Nokia device, you are asked to re-enter the password. The password is asked because the memory card remembers the password protection settings, including the password.
Note: After you reflash your Nokia device and re-insert the memory card, you are asked to re-enter the password, as it has been erased from the device during the flashing process. You have to re-enter the password to get access to the memory card, and after that the device will remember the password again for future use.
If you have forgotten the password but you still want to try to use the memory card, try formatting it. If the formatting process is successful, the memory card is usable but all data on the memory card is erased.
To avoid unnecessary risks, write down your password somewhere and backup your memory card data regularly.
Jun 20, 2009 | Nokia Cell Phones
How can format the phone memmory of NOKIA 3230
Download user guide from:
http://nds1.nokia.com/phones/files/guides/Nokia_3230_UG_en.pdf
Page 163
Formatting the memory card
When a memory card is formatted, all data on the card are permanently lost.
Some memory cards are supplied pre-formatted and others require formatting.
Consult your retailer to find out if you must format the memory card before you
can use it.
• Select Options→ Format mem. card.
Select Yes to confirm. When formatting is complete, enter a name for the
memory card (max. 11 letters or numbers).
Backing up and restoring information
To back up information from your phone’s memory to the memory card, select
Options→ Backup phone mem.
To restore information from the memory card to the phone’s memory, select
Options→ Restore from card.
You can only back up the phone memory and restore it to the same phone.
Locking the memory card
To set a password to lock your memory card to help prevent unauthorised use,
select Options→ Set password.
You are asked to enter and confirm your password. The password can be up to
eight characters long.
Your rating would be most appreciated.
Feb 20, 2009 | Nokia 3230
Nokia 3230 Logo
Top Nokia Computers & Internet Experts
Anthony Ward
Anthony Ward
k24674
Ekse
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
