I have a washing machine TROMM Ultra drive system stainless steel drum quiet operation #WM2077CM This MACHINE FLOODS OUT MY WASH ROOM ONCE A WEEK CALLED IN PROBLEM GAVE ME A RESET CYCLE TO RESET MY WASHER I SPENT THE EXTRA MONEY ON THIS WASHER BECAUSE I THOUGHT IT WAS BETTER IT HAS BEEN A PROBLEM FROM THE START WATER COMES OUT OF THE FRONT OF THE WASHER NEVER KNOW WHEN IT GOING TO HAPPEN CAN YOU HELP ME PLEASE
    Scholar:
  • 74 Answers
Hiya ZEUS1009, judging by your symptoms, I feel certain that your problem is with the pump housing itself. It sounds as there is something stuck in the pump itself.
Normally a sock or similar....
If you feel confident with taking apart the pump.. please reply with make model etc.. and i will post you instructions. I stress that only if you feel confident!!! but is fairly straightforward... otherwise expect to pay around £30 upwards for the repair.. dependant on whre you live.
Regards Faggly
Posted on Mar 18, 2008
SOURCE:
The soap is not being flushed out of the dispenser
Be sure that the detergent tray is not overfilled. If so, it will prevent the detergent tray from opening to dispense the soap. You may want to try liquid detergent to see if it works any better.
May 29, 2016 | LG LDS5540ST Semi-Integrated Dishwasher...
Cycle stops at 12 minutes remaining in all cycles. Sounds like a grinding noise in unit. Then machine stops with Water remaining in drum. No blocks in pump. I run spin only to empty water. E11 code
Thanks for your post, Daniel!
Based off the information you have provided the cycles inside of your Frigidaire washer will stop at 12 minutes and making a grinding noise. I also see that you receive an E11 error code and that stands for a long fill time. I would recommend checking over the hoses to assure they are installed properly and not restricted. You may have an issue with your drain pump, motor, or water valve. I would recommend performing a reset on your washer and you can do that by disconnecting power from it for at least ten minutes. I hope this information is helpful to you. -Matt
Dec 22, 2015 | Frigidaire ATF8000FS Affinity 3.5 Cu. Ft....
That didn't work! What are some other options ? Machine has a child / pre-wash button but trying it did work either.
To activate or de-activate the child lock feature, press and hold the Child Lock button for three seconds.
Dec 29, 2014 | LG WM3001HWA Front Load Steam Washer,...
Power button will not turn on dishwasher.
Make sure that power is reaching the control panel of your machine. Many people are offended when I tell them to check the fuse or circuit breaker to make 100% sure that the machine is receiving power.
If it is receiving power and not switching on, you will have to have the main control PC Board checked, out as this controls the entire machine. This is rather left to experienced persons.
Jul 27, 2014 | LG LDS5540BB Semi-Integrated Dishwasher...
Loud clunking noise during wash cycle
Hi What machine is this? and is there play on the stainless steel inner drum?
Mar 11, 2013 | Washing Machines
LG Tromm Model WM2277HW washing machine not operating right
It is possible that the drum is off center, shifted in the alignment and had a friction at the base of the drive. It is possible that there is bearing failure or there is a fault in the drive. If you experience that there is friction manually even with a hand turn then the assembly must be reset. check this link for tips: Bearings
Feb 12, 2013 | Washing Machines
Parts of the clay
Did you mean parts for the machine, Click this link: Spares
Jan 23, 2013 | Frigidaire ATF6000FS Affinity 3.5 Cu. Ft....
I have a Speed Queen Heavy Duty Large capacity wash machine model:AWM 351-3062 I need to find out ifit has a steel drum
Yes, all Speed Queens have a stainless steel tub, some are coated, but underneath is stainless steel
Jun 12, 2010 | Washing Machines
Frigidare ultra quiet
You need a new wash motor, the impeller is stripped.
Dec 21, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Washing Machines Logo
69 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
