SH-550T i bought this digatal cmera from techinika it is called "SH-550T" and it seems that on video AND AUDIO RECORDER there is no audio at all! how do i set up audio
The Camera has no speaker therefore you can't hear anything. I presume that when you play the recording back through your computer you should hear it through the computer's speakers.
Posted on Mar 26, 2008
SOURCE:
This dvd recorder worked PERFECTLY when I had digatal cable. As soon as I up graded to HD with a HD box from comcast, I cannot get the recorder to record anything. I hooked it up the same way as I did with...
The HD box from your cable company only sends High Definition Video signal which DVD does not support. Your DVD recorder "CANNOT RECORD THIS PICTURE" because it can not process (see) the High Definition (HD) Signal.
To record from an HD reviver you would need a HD recorder (Blu-ray) very expensive The standard practice for recording from a HD cable receiver id to use an DVR here is a link to one for about $100 some models will have a standard video output you could connect your dvd recorder to.
http://www.google.com/products/catalog?q=HD+Dvr&oe=utf-8&client=firefox-a&hl=en&cid=15241578777457062393&ei=puGPTNuoFIm4iwSJ2s1h&sa=title&ved=0CBcQ8wIwATgA#p
Sep 14, 2010 | Sony RDR-GX330
I have a digital audio processor technics sh ac500d without remote. This item is stayed at midnight mode. Have you a solution for a day listening.
Monday, september 7th 2009
Thank you but I have bought a remote control ; I think this is the best solution.
Friendly yours.
SR
Sep 05, 2009 | Technics SH-AC500D Receiver
Gz-mg335hek video cmera goes blurred when
go through ur menu and put the zoom/focus on manual, it sounds like its on auto.
Jul 22, 2009 | JVC Video Cameras
Can u record the audio of a Skype Call?
Hi Mike,
Here are a few options for you (I have not tested them, pls let me know how they work, reviews were not so bad on them):
Record Skype conversations with Skype Recorder!
http://www.extralabs.net/skype-recorder.htm
PowerGramo skype recorder is a perfect skype recording solution. With it you can easily record skype calls of any kind.
http://www.powergramo.com/
Mp3 My Mp3
May 08, 2009 | Skype IM
I have a DirectTV DVR HR10-250 that I stopped the monthly service, and use it to watch free Off-the-Air broadcast HD channels. I can not seem to record them by default. Is there any way or "hack" that I...
in feb when free air signels become digatal you should then be able to record your programs because your box is set to a digatal format and will not record the old analog signels
Dec 07, 2008 | Hughes HR10-250 DirecTV / TiVo 200-Hours...
Cannot render audio capture stream
On the "Audio Settings" in the Life View software, at the "Audio Input Source" on the drop down arrow, select "None". This settings will use the internal PCI Bus for listening and recording TV. The audio loop back cable in this case is not needed anymore.
Dec 06, 2008 | LifeView FlyVideo 2000 / FM (701013821030)...
HELP!!!!!!!!!!!!!
if you purchased it recently, your still under its warranty. have it replaced. try it first before purchasing it so that youll know if its working or not.
Mar 18, 2008 | Cameras
Souud delay on tv /amp
Instead of connecting each device (sky&dvd rec.) to the TV separately, I would simply hook up the sky to dvd recorder (connect the sky output and dvd recorder input), and then connect the dvd recorder output (must be called "play out") to one of the available recorder inputs (which could be a dvr, an empty tape input, etc)of your amp. However, you'll still have to establish a feedback between your dvd recorder and your amp. Therefore, if the dvd rec. supports it, you'll have to hook up the rec.out, which is on your amp.,to rec.in on your dvd recorder. After all these audio connections, you will only need to make a video connection among the sky, dvd rec., and tv. Get a video cable to hook up the sky video output to your dvd recorder's video input, then do the same thing between the dvd recorder's tv output and tv.
Apr 12, 2007 | Cambridge Audio Azur 540A Amplifier
79 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
