Question about Kitchen Ranges
We have a Westinghouse 600mm integrated freestanding cooker The fan is hitting something when we turn on the oven. The cooker is 15 months old. Is the fan accessible by us? Any ideas please?
    Master:
  • 351 Answers
Dear Chook1,
its mean your freestanding cooker needs service ,well my suggestion is ,you just contact to their service centre ,they will comes to your door and fix this . because its a very sensitive device so don't try anything with this. for your convenyence here i'm sending you the link of their services.
http://www.westinghouse.com.au/locator/search/service/
takecare
Posted on Mar 18, 2008
Westinghouse 808 cooktop clicking noises
Sometimes after a power failure the p c board needs re setting. Turn off the power for a few minutes that allows it time to re set. Turn it back on then individually turn on each element for a couple of minutes.
Apr 22, 2014 | Whirlpool Cooktops
Rangemaster victorians deluxe, double oven , duel fuel
Is there any sort of fan in there - could be some blades hitting surrounding.
Sep 14, 2017 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Smeg cooker SPA 42016 oven will not heat up although the fan is working and the oven light is on
This happened with my 42016 single oven. It was the element. They can be bought online and are easy to fit.
Mar 17, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Hi, the oven is not working in my Creda Collection freestanding cooker. I have had the element tested and proved to be ok. Also the fan does not move. The timer is set to manual. Can you assist?
If the element is okay and the element and fan aren't working together then it will be a problem further up the line. The next question I would normally ask is is the electronic timer in manual mode. When you turn the oven on does the oven indicator light come on?
Feb 17, 2011 | Ovens
The fan continues to run. How long and will it automatically shut off?
The fan you refer to should be the fan in the oven cavity. It removes hot air from the oven cavity and expels the air out the front of the oven. Once the oven is turned off the fan will continue to operate until the oven cavity has cooled sufficiently. It may run for 10 to 15 minutes and will turn off by itself.
Feb 12, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
The main fan assisted oven on a Hotpoint BD35 double oven stopped working so I replaced the element, thinking that would be the obvious answer. Unfortunately it is still not working and I notice that the...
Is there a black pole sticking out that goes in when you close the door, my Hotpoint freestanding cooker has it on the right hand side, once this is pressed in the fan and heat starts, i had to replace it on my cooker as it went faulty and stopped things working (all I had was the main oven light on, these are usually like a little black box that are situated on the side of the oven just behind the main metal panel on the outside and will normally have 2 pull off spade connectors connected to it.
i don't have the same model as you but hopefully this mig help you.
Oct 22, 2017 | Hotpoint DY46 Style Line Stainless Steel...
How do i turn the fan off.
If you mean the oven fan that will turn off on control switch.I think you may be talking about the cooling fan.This is to cool the electrical panel on the top front of cooker. It comes on after the oven heats up and may stay running for 15 or 20 minutes after cooker is turned off it will turn off after the unit has cooled down sufficiently for the controller.
Hope I helped.
Good Luck.
May 07, 2010 | Electrolux EOB6636X Ultrafan Electric...
1954 westinghouse stove/oven....has an odd burner that drops into the top of the stove..circa 1954?? looking for any info at all about it
That burner is a two-level speed cooker. There is a stock pot type insert that sits down in the burner that can be used to prepare stews or can be converted into a deep fryer.
Mar 26, 2010 | Westinghouse Protégé - 72189 Fan
Diplomat integrated oven- 13amp?
You need to get an electrician to wire it in to a 30amp cooker outlet. It is 30amp rather than 13amp (like most sockets). It should go to its own fuse in the fuebox
Feb 22, 2009 | Belling XOU592 / XOU593 Electric Double...
Westinghouse neptune freestanding oven-all plugged in and powered
where is the fuse box in a westighouse neotune cooker.I know it is in the back somewhere but i cant sme to find it.
Jan 28, 2009 | Neptune II Leaning Post
Kitchen Ranges Logo
95 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
