Question about Canon PowerShot A75 Digital Camera
Displays Purple lines on Image
It was working fine, all of a sudden I started getting purplelish lines, Now I am not able to view the picture, nor download the same on to my computer. Can you help me if it is a CCD Problem,.
If you have the address to which Ihave to contact for correction, can you please help regarding this too.
Damodar
Email : [email protected]
  • Canon Master
  • 4,738 Answers
This certainly sounds like symptoms of a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Mar 21, 2008
SOURCE:
The camera took great pictures then all of a sudden the screen appears as a purple haze -- and the pictures come out as just a purple blurry haze. Adjusting brightness doesn't work. Yet, the shutt
If the LCD displays correctly on previous photos then the problem is more than likely a CCD or associated ribbon connector failure due to moisture/condensation or age/misuse. Good luck with finding a replacement part!
May 31, 2012 | Panasonic Lumix DMC-TZ3 Digital Camera
Toshiba Webcam image shows purple/green lines...
It might be a cause of software which you download or some malfunctioning in the hardware, try resetting first before reintsallation of driver or replacement of the cam.
Jan 22, 2012 | Toshiba satellite c660
My A70 video screen suddenly quit working and only shows blurred purple lines and will not take pictures. It has not been dropped or misused. Took a picture just fine, minutes before it happened. I used...
Hi there:
A CCD problem would explain the black or lines on your pictures and the lines on the LCD (since the CCD is used to feed the live image). CCD (Charge Coupled Device) is one of the two main types of image sensors used in digital cameras.
Some symptoms of a defective CCD include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
When a picture is taken, the CCD is struck by light coming through the camera's lens. Each of the thousands or millions of tiny pixels that make up the CCD convert this light into electrons. The number of electrons, usually described as the pixel's accumulated charge, is measured, then converted to a digital value. This last step occurs outside the CCD, in a camera component called an analog-to-digital converter.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details: Bad CCDs. This, isn't a good new, but hope helps to solve it.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Apr 19, 2011 | Canon PowerShot A70 Digital Camera
After I take picture, the picture is captured & shown but when I try to view,(by pressing playback) it displays 'Cannot playback Image' with a big question mark. When I downloaded & tried to view...
Check to make sure that you did not accidentally change image format from jpg to crw(camera raw). Your camera lcd will only display jpg files and you need special software to view raw files on the pc.
Dec 30, 2010 | Canon EOS 500D / Digital Rebel T1i Digital...
I had Fuji S5000 for about 3 years. It worked fine. Now all sudden, I can't see any image when trying to take a picture. Both image through view finder and on LCD are just blank. Someone told me that a...
Hi
I have got an S5000 that I can still view previously taken pictures from the card, but when trying to take pictures the screen and view finder shows a peculiar distorted purple and green picture and any picture taken is just a green blur.
I contacted Fuji and they say they can repair it for £90 (about $120)
Nov 02, 2009 | Fuji FinePix S5000 Digital Camera
HI All of a sudden, there is lets say no more image on the display or the image is purple and full of weird lines. No image at all and when I click to take a picture everything works out well: the flash...
BUT NOW U HAVE FOUND SOLUTION
CCD FAILURE !
but u will get it repaired Free of Charge as Fuji has taken notice as all manufac and i got my S5000 repaired Free from Fuji just call them tell them about BAD CCD it is a known manufac fault in thousands of cameras just call them quick
www.fujifilm.com
see this thousands suffer from this
http://www.imaging-resource.com/badccds.html
May 08, 2009 | Fuji FinePix S5000 Digital Camera
LCD show purple or violet cast on white areas when using auto mode
Have you tried viewing the photos on a computer or printing them? There should also be parts of the menu/setting displays that would be white. The text on the image info should be in white.
If you are getting white, it would suggest your whitebalance isn't set correctly. If everything has a purple tint to it, check your LCD display settings, otherwise it may be the screen is failing.
Dec 31, 2007 | Nikon D40x Digital Camera
Coloured lines on picture screen
I have the same issue, Although My camera is a samsung N46, It was working perfectly the night before, then my friend switched it on and it came up with a black backround and pink + purple vertical lines going through it.
Nov 12, 2007 | Olympus FE-120 Digital Camera
Camera not displaying image
after taking pictur. picture appear small or, technicolor screen
Jun 15, 2007 | Konica Minolta Maxxum 7D / Dynax 7D...
Vertical lines and purple artifacts when the camera is aimed at bright subjects
Current LCD display technology can reproduce about 300 different levels of brightness. Brightly lit scenes or light sources may exceed this brightness range, causing a temporary disruption (artifacts) in the live display. Artifacts are part of the display, but they are not part of your recorded image. If you take a picture while you see artifacts on the screen and then display the picture on the LCD, you will no longer see the artifacts.
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Canon PowerShot A75 Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
