Question about Toshiba 51H84 51" Rear Projection HDTV-Ready Television
Toshiba Theater View 65" Projection TV Blinking Power Indicator LED>
Recently the screen would show random lines, like a bad antenna connection, but it has digital dish, DVD and VCR and the symptoms were the same no matter which input was used. Now when turned on, the power LED light comes on for about one second, and then it blinks with no other functions working. The fuses are good in both circuit boards and it is very easy to remove them. Would it be a good idea to remove them and take to a Tech for testing, or would a house call be in order? Thanks, Mark.
  • 975 Answers
If your handy , I suggest to check for any DRY SOLDER in the PC BOARD around the power supply ,or check the Convergence area for some IC , its start with STK___ and numbers. hope it helps
Posted on Apr 26, 2008
Yellow blinking light on toshiba tv
http://aaaateva.com/tv-repair/tv-brands-serviced/toshiba-tv-repair/toshiba-tv-codes
the color and blink pattern of your tv led is a code that gives you the fault...check at the site above.
Jul 05, 2015 | Toshiba 65HM167 65" Projection Television
Blinking red light no picture
No picture or do u have a blue (or some other color) screen? And the blinking red light, is that the indicator light down by the power button that is blinking? I have the same tv and very similar problem, i have a blue screen and the red indicator light is blinking. If you have gotten ur problem fixed I would love to know how, or vise versa if I get mine fixed.
Sep 11, 2011 | Toshiba 65H84 65" Rear Projection HDTV
Toshiba 65H81 Displays static, however menu screens fine
Well in this case you may have an issue with your Video Board, if the static showed on the menu, then the issue would have been with your DMD Board, but not in this case.
Jul 27, 2009 | Toshiba Televison & Video
Power light blinking
I have a Toshiba 42H81 that has the power indicator light blinking and the TV will not turn on
Oct 14, 2008 | Toshiba 42H81 42" Rear Projection...
Casias.com does not exist
Your STK parts might not be your problem for blinking red led. As I have read throughout other forums, the first think to address is your power deflection board .....that's the first one that goes. If it is the first time, it might be that only a couple of fuses on that board go bad, I had the same problem with mine, as I remember correctly, F850 and F852 were bad....I replaced mine and had tv for 12 months when a storm caused the whole power to go on and off a few times and screwed up my set and now more parts on power board are messed up. I'll replace mine in totality.
Convergence STK's will tell you when they go bad because you will notice something with your picture right before they give in. But in your case, you can't turn your set on.
Try to put your hands on info that tells you about codes on that blinking light. I tried to find that kind of info but I didn't try hard enough. I wish I have it, it could save me a ton of headache.
Hope this helped.
Nic
Aug 03, 2008 | Toshiba 65H81 65" Rear Projection...
Power indicator light blinking
Check soldered in micro fuses...F850, F851 etc.....
1) solder jumper wires on signal board = 008,010,017,048,600
2) Check / replace STK392-110 convergence IC's with Toshiba
part # 23135090 or upgade to Hitachi part # CZ01341
Let me know....................T.
Jan 04, 2008 | Toshiba 65HX81 65" Rear Projection...
Toshiba 65"HD rear projection tv
is the light flashing? Many things will cause a no power condition, might be shorted Convergence IC's, Z801 Ic could cause trouble, might want to call service man.
Jun 02, 2007 | Toshiba 65HDX82 65" Rear Projection...
Toshiba 51H84 51" Rear Projection HDTV-Ready Television Logo
312 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
