Related Tags:
This problem should be removed because:
Problem with Brother HL-2040 Laser Printer
Brother HL 2140 does not pick up paper from tray
Solutions (1)
Best Solution
Make sure your pickup roller clean.
If it's clean and still jams the problem is inside.
- Remove left cover (where the USB connection is located);
- Remove big black gear with a spring on it (you may need to unscrew the PCB that partially covers it);
- There is a clutch that sticks to the rubber pad behind this gear. You may put a piece of scotch tape towards to a rubber pad, so the plastic from clutch mechanism would'n stick anymore. http://www.phillycopiers.com/fix/hl-2040-2070-fix.jpg
Oleg Andrukh IT Specialist
PhillyCopiers.com 215 364 3774
Paper jam in Brother HL-2140 printer
I have a paper jam in my printer (model HL-2140) and I cannot see any way of freeing the jammed paper. Very frustrating!
I have an HL-2140 - can I print with 8 1/2 X 14
I have an HL-2140 - can I print with 8 1/2 X 14 paper? I can't get it to fit in the tray. Need to print on longer paper.
how to remove paper jam in brother hl-2140
Can i set the Brother HL-2140 to print double
Can i set the Brother HL-2140 to print double sided. I cannot find it ?
My HL2140 would not pick
My HL2140 would not pick paper from the paper tray hence making the red error led to be on after a print order is given.
Add Your Solution
idele defauld printer for mac
idle default
hl-3040cn toner error wont reset
replaced toner and I still get the error
Faint print on Brother HL-2040
I am experiencing a sudden "ghost" print quality with my HL-2040. It was printing great and with no warning...
Fix-O-Meter
614
614 people viewed this problem
- 2 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Brother Printer Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
Make sure paper is lifted. After jam occurred remove the paper tray, press Go button and watch on the white gear located on the inner left side. If it spins the paper lifts. Then follow my next post.
