There will be a little light top right corner of your keyboard. Over above the numbers on the right side you'll see two indicator lights there's a number lock light and a caps lock light
google " on screen caps lock num lock" followed by the Operating system you have. scan the top results for sites that have the appropriate instructions. We'd need to know what OS you have to tell you exactly....
It depends on the keyboard model. Some have a number lock indicator light. There is no standard for location, either. The most common place for Caps lock, number lock, etc. on a desktop keyboard is behind the number key pad. However, some keyboards put the caps lock indicator right in the Caps lock key. There's probably at least one model that does the same for number lock. Many laptop models have no indicator, or a tiny one set somewhere in back bezel.
Some operating systems and applications have an option for displaying the status in the menu bar. If you can't find the number lock status indicator, you may have to resort to observing the behavior of the system when you hit a key on the number pad. If number lock is off, the even numbers (not including 0) will be arrow keys and the odd numbers will be page navigation keys.
most thinkpads use 'hold down shiftkey and press Numlk/Scrlk key' should also toggle a led off & on next to the caps lock led. looks similar to caps lock but the arrow has a 1 in it for number lock when the caps lock uses the letter 'A'
Your EX 110 receiver has 3 indicator lights (LEDs) that display the status of the Caps lock, Function key, and the Num lock during normal operating mode. These lights will also flash when the connect button on the receiver is pressed. LED A: Indicates that the Caps Lock (Capital lock) key is on when lit. LED F: Indicates that the F keys are in Standard F Keys Mode when lit and in Enhanced F Keys Mode when the LED is off.
Your EX 110 keyboard has an Enhanced F Keys Mode for F keys that provides additional functions you can program. See Knowledge Base article 9526.
LED 1: Indicates when the Num Lock (Number lock) key is on. This function allows the number pad to produce only numbers
