Question about Dell (0Y435) Internal 24x CD-ROM Drive
Problem with CD/DVD drive
I am facing a problem with my CD/DVD drive that it does not work. That is, when i plug it sometimes my pc is able to detect my drive and sometimes it is not. If it is able to detect the drive it can't read cd. How can i solve my problem?!
  • 133 Answers
U need to run a full virus scan, if it dosen't work u need to reinstall your operating system
Posted on Mar 18, 2008
    Scholar:
  • 41 Answers
Hi ,
if you still have the issues with the CD/DVD drive then follow these steps , it will certainly resolve your issues.
1. click on start , click on run and in the run box tyoe the following command " regedit " ( Note donot include quotations) and then click on OK.
2. it will open a new window called registry editor , in that in the left pane you will find 6 folders .
3. Click on the + sign beside the folder name HKEY-LOCAL_MACHINE, it gets expanded , look for the folder called SYSTEM , click on the + sign to the left of it.
4. Look for the folder called " CURRENT CONTROL SET " click on the + sign .
5. look for the folder called " CONTROL "click on the + sign .
6. Look for the folder called " CLASS "click on the + sign .
7. Look for the folder calledProblem with CD/DVD drive - moz-screenshot-1.jpg "{3D36E965-E325-11CE-BFC1-08002BE10318}" click on the folder and in the right pane you will find the Entry " LowerFilters " right click on that and then select the option delete and then restart your computer and this will resolve your issue...
Posted on Apr 21, 2008
Describe how you insert a dvd into a laptop
Hi Eunice, just want to clarify, for lenovo notebook if it doesn't have DVD drive you can use external DVD drive to access DVD CD. DVD external drive is just plug and play device once attached in your USB port, it will automatically detected and once detected you can use it already. Just install Burner application to burn some files if your DVD is capable of burning CD.
Jun 22, 2011 | Lenovo 3000 Y410 (59012354) PC Notebook
Hi my dvd drive does not work properly. sometimes it can detect a CD or DVD but many times it can not. for example if it can not detect a cd when I eject and insert it again or after several times it...
Recognising a CD /DVD by DVD drive is related to the lense condition.
You try to clean the lense with cleaner CD which is available in the market.
If the problem still not solve then you change the drive
May 02, 2011 | Sony Vaio VGN FE890 Laptop Universal AC...
Hdd and cd/dvd
One thing you can do is to reset the bios setting by clearing the bios. You will need to revothe battery and remove the jumper CMOS battery cc1 .
Note the setting before removing.Usullay ithe default is pin one and pin two.
One oher thing that you can do is to update the bios version
This is sure it will correct the problem oc cd/dvd.
Here are two links below for bios update try this
http://drivers.softpedia.com/get/BIOS/Msi/MSI-K8MM-V-Bios-18.shtml
http://drivers.softpedia.com/progDownload/MSI-K8MM-V-Bios-18-Download-45381.html
ok
Jun 24, 2010 | MSI K8MM-V Motherboard
No detection of hdd or cd/dvd rom
try to delete upper and lower filters on the registry to make your cd/dvd properly working
Jun 24, 2010 | MSI K9MM-V Motherboard
My DVD player can't detect DVD CD file, but it can play CD. i've tried to check on the device manager and its working properly. i also have tried reinstalling its driver but still not working... i am using...
i have faced this problem in my case DVD was working and cd not you problem is the lens of you cd/dvd drive has become worst and cant work any longer it needs to be replaced. Hopefully it might have helped you.
Jun 19, 2010 | Microsoft Windows XP Professional
KEYBOARD, MOUSE AND CD DRIVE DONT WORK
your operating system must be install for successful progress. cause, that OS can detect your K/B, mouse and you must plug in DVD-RW external to install, if your DVD-ROM still broken
Sep 21, 2009 | Dell Inspiron 9300 PC Notebook
When I put a CD in the DVD drive, it does not read.
1. If the CD/DVD drive tray not open.
Open "My computer" windowsand select the CD drive . "Right click" onthe CD drive.You will get apop up windows with the "Eject" option.
If it open that's means the power supply is ok
2. If the DVD drive is not showing on my computer windows or the DVD is not detect the CD/DVD disk
Tofix the problem we need to delete the UpperFilters andLowerFiltersregistry key for more details about the troubleshootingstep please follow the below link.
No longer access the CD drive or the DVD drive
3. After follow the above steps if you still face the same problem then need to contact the local hardware vendor.
Aug 06, 2009 | Dell Dimension 3000 PC Desktop
Cd-r dvd
Open "My computer" windows and select the CD drive . "Right click" onthe CD drive.You will get a pop up windows with the "Eject" option.
To fix the problem we need to delete the UpperFilters and LowerFiltersregistry key for more details about the troubleshooting step please follow the below link.
Jul 22, 2009 | Acer Aspire M1201 Athlon X2 320 Gb PC...
My sony dvd rw aw-g170a drive is not detecting certain DVD's!!!!!
if you have CD RAM and DVD ROM then change it to CD/DVD ram because in case of CD RAM and DVD ROM it may read CD but not DVD but sometimes it can read DVD also but when we copy data to computer it may freeze or give us error so i give you one suggest to buy a new CD/DVD RAM
Jun 26, 2009 | Sony (1-796-293-13) Plug-In Module DVD...
Dell (0Y435) Internal 24x CD-ROM Drive Logo
130 people viewed this question
Alun Cox
