Have a problem with my Palm Z22 PDA.The stylus will do no action on the screen. After hot synching my Palm Z31 to the same Desktop program it now will not do any function correctly like it has a virus or something. any clues?
    Guru:
  • 1,894 Answers
Hello sir,
yes it may have a virus.
so please do a format and try again
Posted on Mar 18, 2008
SOURCE:
I have a palm z22 Pda the tochksrceen is no working
There are several answers listed in Fixya under Z22 and touchpad or touch screen. You can start by trying to clean under the edges of the face frame with a credit card or something similar. If that doesn't work, try a soft reset by pushing the reset button on the back of the device. If that doesn't work, you can do a hard reset, but it loses all the data in the device. If you have it stored on your desktop calendar, this might solve the problem. To do a hard reset, check this site for instructions. http://kb.palm.com/wps/portal/kb/common/article/42094_en.html
If those steps don't work, you may need to replace the digitizer. You can pay someone to do it, or you can buy the part on ebay for about $12. Get one that comes with the tools you will need. Unfortunately, they don't come with instructions. I have posted the instructions in several places on Fixya. If you can't find them, write again. Hopefully the easier steps will do the trick.
Jun 10, 2010 | Palm Z22 Handheld
Connection problem
Try doing a hot sync first. Here are the steps:
Hold down the power button and then depress the small hole in the back with the tip of your stylus. Continue to hold them both in until you see the Palm logo. Let go of both of them and then follow the onscreen directions. You will want to answer yes and use the 5 way navigation button on the bottom of your pda and hit up so that is completes the reset. After that you will have to set up your touch screen and go through the tapping the target. After you have gone through all this then do a hotsync. It should clear up your problem. Best wishes.
Sep 13, 2009 | Palm Z22 Handheld
Won't synch calendar from Palm Desktop!
Older palm products and vista aren't compatible. You either needs to transfer info via bluetooth or upgrade your palm if you wish to continue using vista.
May 26, 2009 | Palm Z22 Handheld
Z22 PDA downloads contacts but not calendar
If the file is moderately correct in your pda, dump your latop program. After reloading it, MAKE SURE it only scans from pda to pc so you don't lose anything else. Once this is done, change your settings back to what they were. If this is helpful, please post as such.
Mar 18, 2009 | Palm Z22 Handheld
Palm Pilot: Connection for Hot Sync
Has synch worked before on this set up?
Jan 01, 2009 | Palm Z22 Handheld
Cd doesnt install palm desktop software (palm z22)
You're saying you trying to install an appointment on your PDA. Has evrything worked before?
Dec 30, 2008 | Palm Z22 Handheld
Hot Synch an existing PalmVx data to a replacement palmVx
HI,
The first thing you want to do is to do a Hard Reset on the used PDA that you bought as a replacement. To do that follow these steps:
1. Hold down the power button and then depress the small hole in the back with the tip of your stylus.
2. Continue to hold them both in until you see the Palm logo.
3. Let go of both of them and then follow the onscreen directions. You will want to answer yes and use the 5 way navigation button on the bottom of your pda and hit up so that is completes the reset. After that you will have to set up your touch screen and go through the tapping the target. After you have gone through all this then do a hotsync2.gif. It should clear up your problem. Best wishes.
Dec 12, 2008 | Palm Vx Handheld
Can I hot sync z22 palm without the touchscreen?
The data on your old Z22 is very likely very secure, and the touch screen problem is very common - there are a few tricks to get the touch screen working long enough to transfer the data.
I have a web page entirely for maintaining, repairing, and interfacing your Z22 at:
kidbots.com/WEBADD/Z22_PALM_PILOT/Z22_PALM_PILOT.html
You can try these tricks, or just replace the screen for $9 U.S., since the screen only needs you take the unit apart and flip open a connector lock ...
I would strongly advise getting a solid plastic cover over your new Z22, since this is the key to keeping the screen working...
hope the information is of help to you
good luck
robin dusty graves
Z22 PALM PILOT hot-sync-z22-palm-without-touchscreen-ngl0e1lc0ft3j10pmz4xzklk-3-0.jpg hot-sync-z22-palm-without-touchscreen-ngl0e1lc0ft3j10pmz4xzklk-3-1.jpg hot-sync-z22-palm-without-touchscreen-ngl0e1lc0ft3j10pmz4xzklk-3-3.jpg
Nov 06, 2008 | Palm Z22 Handheld
Hotsyncing Z22 device with Palm Desktop
Check what is the action set to address book (contacts) conduit in the HotSync manager in System tray, make sure that it is set to "Synchronize the files" or you can change it to "desktop overwrite handheld" then perform a Sync.
Oct 23, 2008 | Palm Z22 Handheld
I just bought a palm Z22 PDA. I used the AC charger to charge the Z22 but when I attempted to attach the USB synch cable I noticed that the plug is different from the plug on the AC charger. The USB...
I have concluded that the USB synch cable is not the correct one for my Palm Z22 PDA. There is only one point of attachment on the PDA and it is different from the plug on the USB synch chord. This was the last Palm Z22 PDA in the store so I think that the store clerk rounded up leftover parts and components of previous PDA kits and tried to make a complete set out of it. I am going to return the PDA to the store (Staples) in the next day or two.
Thanks for your offer of help. I will contact you again in the future if I need help.
Oct 15, 2008 | Palm Z22 Handheld
Open Questions:
Computers & Internet Logo
51 people viewed this question
Ekse
Alun Cox
