Question about Wharfedale DVD-M3 DVD Player
Recording from Tuner
Hi I cannot get my tuner to work whan i enter the timer mode it offers the options of scart etc instead of chanels i have tried switching the machine off also changing the scart the E3570 comes up on the display
any ideas?
  • john7771 Apr 02, 2008
    Problem is it won't let me do anything I keep getting the error code it looks as if eveytime its swtiched on it starts recording to the HDD and locks everything out even unplugged it for a few days to see if that helped and re set to factory defaults with no luck
  • mikeharbour Jul 08, 2008
    Comment by mikeharbour, posted on Jul 08, 2008
    I had this error code E3750 and no freeview, tried the factory default restore and when it comes back on you do get the cahnce to change the clock - but.......... is still has no free view. I am taking it back to the shop.
I would suggest using the programme guide on the tuner and setting the record up from there rather than trying to set up the whole thing from timer mode.
Posted on Apr 01, 2008
SOURCE:
Record tv to dvd on Funai recorder
The Funai ZV427FX4 doesn't have a tuner. You'll need a set-top box (either a digital tuner or a cable box) that has a composite A/V out. Make sure to use a compatible DVD-R or DVD-RW disc (see page 27 of the manual given below). For basic recording, insert a DVD and press DVD to make sure that the recorder is ready to record to disc instead of video tape. (You may need to format the disc for DVD-RW.) Press Rec Mode until the correct mode is chosen. Then press Input to select composite input 1 or 2 (L1/L2). Set this source to the desired channel. Then press Rec. (For scheduled recording, make sure that the unit is set to DVD. Then press Timer. Follow the on-screen cues to set the time to start and end the recording. Otherwise the steps are the same. Then press Timer Set.) See the manual for screen-shots of the procedure.
The manual for this model is available on the product page: http://www.funaiamerica.com/product/product.php?id=877 . Click on the Downloads tab. The direct link is currently http://www.funaiport.com/download/download.php?id=3361&brand=FUNAI . For older Funai units with an NTSC tuner, you will probably still need the set-top box. However, you can either connect the box to the composite video or RF input. (If you want to record a program from a low-power analog station, you would skip the set-top box.)
I hope this helps.
Aug 28, 2016 | Funai ZV427FX4 DVD Recorder/VCR Combo
Tip
SERVICE MODE TO BEKO 23WL46G 30WL46G
Service Menu StructureThe service menu has three items: display, calibre and version 2.1 Display Display item has seven options:
a- Panel
Panel option gives information about the current panel resolution. It is a read only option and can not be set.
b- Power on time
Power on time gives information about the last update time of the SW running. It is a read only option and can not be set.
c- Backlight on time
Backlight on time option reserved.
d- Scart prescale
Scart prescale option sets the prescale values for the input sounds entering the scart input of the MSP(Micronas Sound Processor). Changing this value you can adjust the level of the output sound going to loudspeakers for all the sources except the Tuners. The range is between 0 and 100.
e- nicam prescale
Nicam prescale option sets the prescale values for the Nicam standard sounds for tuner inputs. Changing this value you can adjust the level of the output sound going to loudspeakers for Nicam sounds entering the analog sound input of MSP. The range is between 0 and 100.
f- fm/am prescale
fm/am prescale option sets the prescale values for the FM/AM standard sounds for tuner inputs. Changing this value you can adjust the level of the output sound going to loudspeakers for FM/AM sounds entering the analog sound input of MSP.
g- Agc(Automatic Gain Control) adjust
Agc adjust option sets the input voltage going to IF decoder AGC pin. Changing this value you can adjust this voltage for optimum Tuner performance. The range is between 0 and 31.
h- R/G/B Brightness/Contrast:
These are used for color bias adjustment. The range is Between 0 and 255
Calibrate
Calibrate item has nine options:
a- video format
Video format option force the video format to the desired format. Selectable formats are Auto, Pal, NTSC and SECAM.
FOR MORE CHECK THE LINK BELLOW
Electronics Equipment Repair Center
Ajin Gopakumar Google
on Feb 16, 2015 | Beko 17WLB450S 17 in. LCD TV
Where can I buy a digital tv tuner to replace the analog tuner in a DVDRHD04
Generally recording machines fitted with an analogue tuner can only continue to be used to record digital tv by using a digital set-top box.
It would not be practical or economic to remove the internal analogue tuner and replace it with a digital tuner unless the person is a highly skilled and experienced repairer.
Digital set-top boxes are available from all sorts of outlets at all sorts of prices. Many surplus boxes can be found at boot sales, garage or yard sales or charity shops at very low prices.
Most boxes have the minimum of connections and often offer only a scart output but some of the older, more expensive and usually better quality boxes also contained a UHF tuner in a similar way to the old vhs recorders so even older tv sets could be used with digital even though no scart input was fitted.
Dec 03, 2015 | iLO DVDRH04 DVD Recorder
When im recording im unable to watch any other channels
That can be normal with some DVR boxes as recording a program requires a tuner and watching requires a tuner. If the model of DVR you have only has one, then you can do one or the other but not both.
Some cable companies offer DVRs with more than one tuner in them that let's you do what you described. You could contact your provider and ask them about that option.
Mar 13, 2015 | Televison & Video
Connect VCR without tuner to record from television
If it has a scart, you can get a scart lead to connect it to your TV. You would need to set the VCR to the Scart socket, IE: AV1 etc.. to record. You wouldn't be able to change channel on the TV, to watch another channel while recording though. If you had a set-top box, you could connect that up to the scart of the video then record, while you watched another channel on your TV.
Feb 06, 2010 | Televison & Video
Satelite tv through my dvr-550h
satellite tuners and DVDs have different remote,unless your using a universal remote with satellite tuner command available.to program recording, you'll need to program the time especially the allotment.then make sure you sat tuner is tuned to the station you want to record.after setting the time and station, its all set.you don't need the DVD's remote to change the channel.
May 27, 2009 | Pioneer DVR-550HS HDD Recorder
Wharfedale DVDR24HD250 DVD Recorder When set up will not find any programmes on Automatic Programme Search (APS)
Products such as this will use an internal tuner to tune channels, this tuner will not detect your televisions freeview stations, to record from your television, connect scart out from tv to the scart in on the recorder, then select the scart A/V channel, use the television to select the channel you want to record, you will not be able to record 1 freeview channel and watch another freeview chanel as you only have 1 digital tuner (in the television) the recorder does not have freeview built in.. hope that helps
Mar 24, 2008 | Televison & Video
Recording DVB on this DVD recorder?
Have sorted this problem now, I purchased a SCART DVB TV Unit from Freecom, this did not work at first connection, but I then realised that it had to work as RGB into the SCART plug on the DVD, once I set the unit to RGB, all was fine.
I can now record Freeview on my DVD fine.
I do however have one prblem which this will not overcome, that is the addition of yet another remote control !!!
Byeeeeeee..
Nov 30, 2007 | Pioneer DVR-220 DVD Recorder
Wharfedale DVD-M3 DVD Player Logo
70 people viewed this question
Top Wharfedale Televison & Video Experts
Ekse
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Wharfedale Televison and Video Expert? Answer questions, earn points and help others
