Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
Fisher & Paykel DD603ZW DishDrawer - Leaking.
I wish to remove the entire unit from the cove to repair the water damage to the floor tiles. Both drawers can not be disconnected from the body of the unit, due to the hoses and elec cables.
What is the best way to remove the unit?
I removed all internal pieces from the drawers to make them as light as possible. Then removed the securing screws, 2 each side at lower drawers. (These secure the unit in position in its cove. Slide out bottom drawer and loosen height adjust screws each corner to lower unit and then slide out. I taped the drawers closed so they wouldn't open as I moved it. I lifted the front and put a heavy rag under the front legs which helped me draw it out. It helps if you have a second pair of hands. As you edge it out, ensure power and water supply hoses are clear of any obstructions. it's not that heavy just unwieldy. Chers, Craig from OZ.
Posted on Apr 27, 2008
Fisher and Paykel twin dishdrawer
there is water in the base setting off the flood sensor, you will need to remove the bottom draw and dry the water up with a towel (make sure the power is off and unplug it from the power point) then you will need to do a bit of testing to locate the cause of the leak, if your lucky the leak was caused by incorrect dish stacking or something too big in the draw
Jan 02, 2017 | Fisher and Paykel Dishwashers
How do I reset the f1 flood button . Dd603ss
Not sure if you have managed to fix the F1 problem with your dishdrawer. This is a common problem and occurs mainly due to water leaking into the base of the dishdrawer under the bottom drawer.
But if it is occuring only in one drawer then the power filter at the base of dishdrawer is faulty and needs replacement.
Otherwise make sure the mains power to dishdrawer is turned off. Pull out the bottom drawer and stack in some towels behind it if you can to remove the moisture sitting on the base. The flood switch is located there. Then take a hair dryer and run it down behind the drawer to dry things. Push drawer back and turn power back on. Now if you cannot reach the back of the drawer then you will have to pull the drawer out from its rail. Refer the installation manual for this. See link page 7.
You need to find the source of the lead, Fisher Paykel DishDrawer Installation Instructions ManualsOnline com
Jul 05, 2014 | Fisher and Paykel 24 in. DD603H W Built-in...
Please tell me where to find float swich in fisher and paykel dishwasher
is this dishwasher a dishdrawer unit or is it a freestanding unit. if it is a freestanding unit it has a pressure switch. if it is a dishdrawer it relies on how many amps it takes to turn pump. hope this helps. what is the problem with your unit? please reply 4 more help.
May 03, 2010 | Fisher and Paykel DS602 Dishwasher
Have Fisher and paykel Nautilus dishwasher showing F1 fault - what does this mean? Dishwasher was leaking water all over the floor dont think major problem as it starting draining when power was reset
f1 means u have a leak where pump and control module is. that is located under sump.the water has activated a flood switch near drain pump. need to find leak to fix problem. make sure power is off to unit b4 looking.please reply to how u go. good luck
Mar 16, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel dishdrawer, lid not retracting, no power.
By no power you may be implying there is no display etc and the swithces are not working. Most likely the controller of the top drawer has had it. The controller is mounted on the front of the drawer behind the door panel. Hope things are better than that.
Oct 16, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Water leaking from top dishdrawer
This is very rare in any dishwasher. I use to repair most all dishwahers. First check your door seal for any cracks, cuts or splits. The water inside is under great pressure and can push out from the top of the door if that is is weak, flat, or has anykind of cut or crack. If the leak indeed is coming from the top then you will need to get someone to help you pull out unit and check top for cracks or splits. This entire housing is plastic and may have come with crack. If your washer has a hose at the top, then check it good. While its out from under the counter run it and watch to see if you can tell where leak is coming from. I may have missed something. Remember, always unplug this from wall outlet or turn off breaker if you are indeed moving it in or out. Good luck.
Mar 09, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
How to reset my fisher and paykel dishwasher
you have to remove the bottom drawer and remove the water from the base.theres two push in tabs on the bottom sides dd603 or if its a dd602/601 theres plugs that pull out remove them and the front panel the drawer will lift out far enough to get access.but you may find its leaking.hope this helps.
Mar 20, 2008 | Dishwashers
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
785 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
